Info
Debug
Warn
Error
断开
I (8981) ESP_GMF_FILE: No more data, ret: 0
I (8981) ESP_GMF_TASK: Job is done, [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x3c66399c, job:0x3c6628b4-aud_simp_dec_proc]
I (8982) ESP_GMF_TASK: Job is done, [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x3c663cfc, job:0x3c6629b4-rate_cvt_proc]
I (8982) ESP_GMF_TASK: Job is done, [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x3c663ddc, job:0x3c662b04-ch_cvt_proc]
I (8982) ESP_GMF_TASK: Job is done, [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x3c663e48, job:0x3c662c54-bit_cvt_proc]
I (8982) ESP_GMF_FILE: CLose, 0x3c663858, pos = 49005/49005
I (8983) ESP_GMF_TASK: One times job is complete, del[wk:0x3c663cfc,ctx:0x3c6628b4, label:aud_simp_dec_close]
I (8983) ESP_GMF_TASK: One times job is complete, del[wk:0x3c663ddc,ctx:0x3c6629b4, label:rate_cvt_close]
I (8983) ESP_GMF_TASK: One times job is complete, del[wk:0x3c663e5c,ctx:0x3c662b04, label:ch_cvt_close]
I (8983) ESP_GMF_TASK: One times job is complete, del[wk:0x3c6639b0,ctx:0x3c662c54, label:bit_cvt_close]
I (8984) AUDIO_PROCESSOR: Get State, 4,ESP_AUD_SIMPLE_PLAYER_FINISHED
I (8984) AUDIO_PROCESSOR: audio_prompt_play_mute, enable_mute: 1
I (9085) AUDIO_PROCESSOR: audio_prompt_play_mute, enable_mute: 0
I (9086) ESP_GMF_TASK: Waiting to run... [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x0, run:0]
W (9893) anim_player: Player deleted
I (9918) mmap_assets: Partition 'anim_emotion' successfully created, version: 1.3.1
I (9940) mmap_assets: Partition 'anim_icon' successfully created, version: 1.3.1
I (9942) BS:Speaker: [esp_brookesia_speaker_ai_buddy.cpp:0521](processAudioEvent): Play audio: file://spiffs/wifi_need_connect.mp3(create_time_ms: 7938, last_play_time_ms: 0) with timeout_ms: 0
I (9943) AUDIO_PROCESSOR: audio_prompt_play_with_block, url: file://spiffs/wifi_need_connect.mp3, timeout_ms: -1
W (9942) BS:Speaker: [esp_brookesia_speaker_manager.cpp:0122](begin): No touch device is set, try to use default touch device
I (9943) MODEL_LOADER: The storage free size is 13824 KB
W (9943) BS:Speaker: [esp_brookesia_speaker_manager.cpp:0126](begin): Using default touch device(@0x0x3c591f00)
I (9944) ESP_GMF_FILE: Open, dir:1, uri:file://spiffs/wifi_need_connect.mp3
I (9944) BS:AnimPlayer: [esp_brookesia_anim_player.cpp:0363](processEvent): Update animation: 10, start(0), end(61), fps(15), is_repeat(1)
I (9944) MODEL_LOADER: The partition size is 300 KB
I (9945) MODEL_LOADER: Successfully load srmodels
I (9946) AFE_CONFIG: Set WakeNet Model: wn9_hilexin
/********** General AFE (Audio Front End) Parameter **********/
pcm_config.total_ch_num: 4
pcm_config.mic_num: 2: [ ch1, ch3 ]
pcm_config.ref_num: 1: [ ch0 ]
pcm_config.sample_rate: 16000
afe_type: SR
afe_mode: HIGH PERF
afe_perferred_core: 0
afe_perferred_priority: 5
afe_ringbuf_size: 50
memory_alloc_mode: 3
afe_linear_gain: 1.0
debug_init: false
fixed_first_channel: false
/********** AEC (Acoustic Echo Cancellation) **********/
aec_init: true
aec mode: SR_HIGH_PERF
aec_filter_length: 4
/********** SE (Speech Enhancement, Microphone Array Processing) **********/
se_init: true, model: BSS
/********** NS (Noise Suppression) **********/
ns_init: false
ns model name: WEBRTC
/********** VAD (Voice Activity Detection) **********/
vad_init: true
vad_mode: 3
vad_model_name: NULL
vad_min_speech_ms: 64
vad_min_noise_ms: 1000
vad_delay_ms: 128
vad_mute_playback: false
vad_enable_channel_trigger: false
/********** WakeNet (Wake Word Engine) **********/
wakenet_init: true
wakenet_model_name: wn9_hilexin
wakenet_model_name_2: NULL
wakenet_mode: 0
/********** AGC (Automatic Gain Control) **********/
agc_init: true
agc_mode: WAKENET
agc_compression_gain_db: 9
agc_target_level_dbfs: 9
I (9954) Main: [main.cpp:0248](operator()): Dummy draw: 1
I (9960) ESP_GMF_FILE: File size: 27981 byte, file position: 0
I (9961) ESP_GMF_TASK: One times job is complete, del[wk:0x3c66ab48,ctx:0x3c6628b4, label:aud_simp_dec_open]
I (9965) ESP_GMF_ASMP_DEC: NOTIFY Info, rate: 0, bits: 0, ch: 0 --> rate: 16000, bits: 16, ch: 1
I (9966) ESP_GMF_TASK: One times job is complete, del[wk:0x3c66ab48,ctx:0x3c6629b4, label:rate_cvt_open]
I (9966) ESP_GMF_TASK: One times job is complete, del[wk:0x3c71ac38,ctx:0x3c662b04, label:ch_cvt_open]
I (9967) ESP_GMF_PORT: ACQ OUT, new self payload:0x3c71ac38, port:0x3c662d20, el:0x3c662b04-ch_cvt
I (9967) AUDIO_PROCESSOR: Get info, rate:16000, channels:2, bits:32
I (9967) AUDIO_PROCESSOR: Get State, 1,ESP_AUD_SIMPLE_PLAYER_RUNNING
I (9967) ESP_GMF_TASK: One times job is complete, del[wk:0x3c71aca0,ctx:0x3c662c54, label:bit_cvt_open]
I (9971) BS:AnimPlayer: [esp_brookesia_anim_player.cpp:0363](processEvent): Update animation: 2, start(0), end(118), fps(30), is_repeat(1)
I (9988) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:1465](forceWlanOperation): Force WLAN operation(INIT) in 0 ms (general state:DEINIT, scan state:STOPPED)
I (9989) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:1437](triggerWlanOperation): Trigger WLAN operation(INIT) (general state:DEINIT, scan state:STOPPED)
I (9990) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:1984](processOnWlanOperationThread): Process on wlan operation(INIT) start
I (9991) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:1465](forceWlanOperation): Force WLAN operation(START) in 0 ms (general state:DEINIT, scan state:STOPPED)
W (9991) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:1730](doWlanOperationInit): Default event loop already created
I (9991) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:1465](forceWlanOperation): Force WLAN operation(INIT) in 5000 ms (general state:DEINIT, scan state:STOPPED)
I (9992) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:1437](triggerWlanOperation): Trigger WLAN operation(INIT) (general state:DEINIT, scan state:STOPPED)
I (9994) pp: pp rom version: e7ae62f
I (9995) net80211: net80211 rom version: e7ae62f
I (9997) wifi:wifi driver task: 3fcce6b0, prio:23, stack:6656, core=0
I (10001) wifi:wifi firmware version: 956d811
I (10001) wifi:wifi certification version: v7.0
I (10001) wifi:config NVS flash: enabled
I (10001) wifi:config nano formatting: disabled
I (10001) wifi:Init data frame dynamic rx buffer num: 32
I (10002) wifi:Init dynamic rx mgmt buffer num: 5
I (10002) wifi:Init management short buffer num: 32
I (10002) wifi:Init static tx buffer num: 16
I (10003) wifi:Init tx cache buffer num: 32
I (10003) wifi:Init static tx FG buffer num: 2
I (10003) wifi:Init static rx buffer size: 1600
I (10004) wifi:Init static rx buffer num: 16
I (10004) wifi:Init dynamic rx buffer num: 32
I (10006) wifi_init: rx ba win: 6
I (10008) wifi_init: accept mbox: 8
I (10008) wifi_init: tcpip mbox: 32
I (10008) wifi_init: udp mbox: 6
I (10008) wifi_init: tcp mbox: 10
I (10008) wifi_init: tcp tx win: 65535
I (10008) wifi_init: tcp rx win: 5760
I (10008) wifi_init: tcp mss: 1440
I (10008) wifi_init: WiFi/LWIP prefer SPIRAM
I (10010) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:1437](triggerWlanOperation): Trigger WLAN operation(START) (general state:INIT, scan state:STOPPED)
I (10012) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:1984](processOnWlanOperationThread): Process on wlan operation(INIT) start
I (10013) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:1984](processOnWlanOperationThread): Process on wlan operation(START) start
I (10014) phy_init: phy_version 701,f4f1da3a,Mar 3 2025,15:50:10
I (10045) wifi:mode : sta (90:e5:b1:cc:60:ec)
I (10045) wifi:enable tsf
I (10046) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:2630](processOnWlanEventHandler): Process WLAN event(UNKNOWN) start
I (10047) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:2630](processOnWlanEventHandler): Process WLAN event(WIFI_EVENT_STA_START) start
I (10048) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:2690](processOnWlanEventHandler): Set WLAN general state(STARTED)
I (10050) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:2060](processOnWlanUI_Thread): Process on wlan UI thread start (event: WIFI_EVENT_STA_START)
MC Quantized wakenet9: wakenet9_v1h24_嗨,乐鑫_3_0.608_0.615, tigger:v3, mode:4, p:0, (May 6 2025 20:45:04)
I (10073) AFE: AFE Version: (2MIC_V250113)
I (10073) AFE: Input PCM Config: total 4 channels(2 microphone, 1 playback), sample rate:16000
I (10074) AFE: AFE Pipeline: [input] -> |AEC(SR_HIGH_PERF)| -> |SE(BSS)| -> |VAD(WebRTC)| -> |WakeNet(wn9_hilexin,)| -> |AGC(WakeNet)| -> [output]
I (10074) AFE_MANAGER: Feed task, ch 4, chunk 1024, buf size 8192
I (10074) GMF_AFE: Create AFE, ai_afe-0x3c76bac0
I (10075) GMF_AFE: Create AFE, ai_afe-0x3c76bc30
I (10075) GMF_AFE: New an object,ai_afe-0x3c76bc30
I (10075) ESP_GMF_TASK: Waiting to run... [tsk:TSK_0x3c76b99c-0x3c76b99c, wk:0x0, run:0]
I (10074) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:1437](triggerWlanOperation): Trigger WLAN operation(SCAN_START) (general state:STARTED, scan state:STOPPED)
I (10076) NEW_DATA_BUS: New ringbuffer:0x3c785048, num:2, item_cnt:8192, db:0x3c7852b8
I (10077) NEW_DATA_BUS: New ringbuffer:0x3c785320, num:1, item_cnt:20480, db:0x3c780f38
I (10077) AFE_MANAGER: AFE manager suspend 1
I (10078) AFE_MANAGER: AFE manager suspend 0
I (10078) ESP_GMF_TASK: One times job is complete, del[wk:0x3c76ba08,ctx:0x3c76bc30, label:ai_afe_open]
I (10078) ESP_GMF_PORT: ACQ IN, new self payload:0x3c76ba08, port:0x3c76b95c, el:0x3c76bc30-ai_afe
I (10102) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:1984](processOnWlanOperationThread): Process on wlan operation(SCAN_START) start
I (10104) main_task: Returned from app_main()
I (10076) ASP_POOL: Dest rate:16000
I (10228) ASP_POOL: Dest channels:2
I (10228) ASP_POOL: Dest bits:32
I (10229) ESP_GMF_BLOCK: The block buf:0x3c7ba424, end:0x3c7bf424
I (10230) NEW_DATA_BUS: New block buf, num:1, item_cnt:20480, db:0x3c76bff4
I (10230) ESP_GMF_TASK: Waiting to run... [tsk:http-0x3c7811b8, wk:0x0, run:0]
I (10230) ESP_GMF_TASK: Waiting to run... [tsk:http-0x3c7811b8, wk:0x3c781210, run:0]
I (10231) AUD_SIMP_PLAYER: Reconfig decoder by music info, rate:16000, channels:1, bits:16, bitrate:0
I (10231) ESP_GMF_TASK: Waiting to run... [tsk:TSK_0x3c722a3c-0x3c722a3c, wk:0x3c76c804, run:0]
W (10232) AUD_SDEC: Not find default parser for 9
W (10243) ESP_OPUS_DEC: Frame duration is not set, out pcm buffer size is counted as the length of 60ms.
I (10244) ESP_GMF_TASK: One times job is complete, del[wk:0x3c76c804,ctx:0x3c721c98, label:aud_simp_dec_open]
I (10244) ESP_GMF_PORT: ACQ IN, new self payload:0x3c76c804, port:0x3c76c770, el:0x3c721c98-aud_simp_dec
I (10265) ESP_GMF_PORT: ACQ OUT, new self payload:0x3c76c89c, port:0x3c76bdb0, el:0x3c76bc30-ai_afe
I (10267) ESP_GMF_TASK: One times job is complete, del[wk:0x3c780f90,ctx:0x3c76bd04, label:rate_cvt_open]
I (10269) ESP_GMF_AENC: Open, type:4, acquire in frame: 320, out frame: 320
I (10269) ESP_GMF_TASK: One times job is complete, del[wk:0x3c76cb10,ctx:0x3c76b830, label:encoder_open]
I (12508) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:2630](processOnWlanEventHandler): Process WLAN event(WIFI_EVENT_SCAN_DONE) start
I (12509) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:2688](processOnWlanEventHandler): Set WLAN scan state(SCAN_DONE)
I (12509) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:2060](processOnWlanUI_Thread): Process on wlan UI thread start (event: WIFI_EVENT_SCAN_DONE)
I (12612) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:2140](operator()): Connect to default AP(QKvip)
I (12612) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:1465](forceWlanOperation): Force WLAN operation(CONNECT) in 0 ms (general state:STARTED, scan state:SCAN_DONE)
I (12612) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:1465](forceWlanOperation): Force WLAN operation(SCAN_STOP) in 1000 ms (general state:STARTED, scan state:SCAN_DONE)
I (12613) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:1437](triggerWlanOperation): Trigger WLAN operation(SCAN_STOP) (general state:STARTED, scan state:SCAN_DONE)
I (12613) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:1984](processOnWlanOperationThread): Process on wlan operation(SCAN_STOP) start
I (12613) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:1437](triggerWlanOperation): Trigger WLAN operation(CONNECT) (general state:STARTED, scan state:SCAN_DONE)
I (12614) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:1984](processOnWlanOperationThread): Process on wlan operation(CONNECT) start
W (12615) wifi:Password length matches WPA2 standards, authmode threshold changes from OPEN to WPA2
I (12622) wifi
I (12623) wifi:state: init -> auth (0xb0)
I (12623) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:2630](processOnWlanEventHandler): Process WLAN event(UNKNOWN) start
I (12627) wifi:state: auth -> assoc (0x0)
I (12633) wifi:state: assoc -> run (0x10)
I (12642) wifi:connected with QKvip, aid = 18, channel 6, 40D, bssid = 2c:c5:46:ef:53:7c
I (12642) wifi:security: WPA2-PSK, phy: bgn, rssi: -32
I (12643) wifi:pm start, type: 1
I (12643) wifi:dp: 1, bi: 102400, li: 3, scale listen interval from 307200 us to 307200 us
I (12643) wifi:set rx beacon pti, rx_bcn_pti: 0, bcn_timeout: 25000, mt_pti: 0, mt_time: 10000
I (12645) BS:Speaker: [esp_brookesia_speaker_ai_buddy.cpp:0521](processAudioEvent): Play audio: file://spiffs/wifi_connect_success.mp3(create_time_ms: 10640, last_play_time_ms: 0) with timeout_ms: 4000
I (12645) AUDIO_PROCESSOR: audio_prompt_play_with_block, url: file://spiffs/wifi_connect_success.mp3, timeout_ms: -1
I (12645) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:2630](processOnWlanEventHandler): Process WLAN event(WIFI_EVENT_STA_CONNECTED) start
I (12646) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:2690](processOnWlanEventHandler): Set WLAN general state(CONNECTED)
I (12647) BS:Agent: [coze_chat_app.cpp:0336](coze_get_access_token): payload_str: {"iss":"1138342588443","aud":"api.coze.cn","iat":1761993066,"exp":1761999066,"jti":"naoZyPi3JhUfk7emQkLQH37lX8iyjDj8","session_name":"ESP_90E5B1CC60EC","session_context":{"device_info":{"device_id":"ESP_90E5B1CC60EC","custom_consumer":""}}}
I (12648) BS:Agent: [coze_chat_app.cpp:0339](coze_get_access_token): formatted_payload_str: {
"iss": "1138342588443",
"aud": "api.coze.cn",
"iat": 1761993066,
"exp": 1761999066,
"jti": "naoZyPi3JhUfk7emQkLQH37lX8iyjDj8",
"session_name": "ESP_90E5B1CC60EC",
"session_context": {
"device_info": {
"device_id": "ESP_90E5B1CC60EC",
"custom_consumer": ""
I (12648) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:2060](processOnWlanUI_Thread): Process on wlan UI thread start (event: WIFI_EVENT_STA_CONNECTED)
I (12653) BS:App:Settings: [esp_brookesia_app_settings_manager.cpp:2244](processOnWlanUI_Thread): Connected to AP(QKvip, 3)
I (12671) BS:AnimPlayer: [esp_brookesia_anim_player.cpp:0363](processEvent): Update animation: 6, start(0), end(76), fps(15), is_repeat(1)
I (12697) wifi:AP's beacon interval = 102400 us, DTIM period = 1
I (13301) ESP_GMF_FILE: No more data, ret: 0
I (13376) ESP_GMF_FILE: No more data, ret: 0
I (13376) ESP_GMF_TASK: Job is done, [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x3c66ab6c, job:0x3c6628b4-aud_simp_dec_proc]
I (13377) ESP_GMF_TASK: Job is done, [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x3c71ab58, job:0x3c6629b4-rate_cvt_proc]
I (13377) ESP_GMF_TASK: Job is done, [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x3c71ac6c, job:0x3c662b04-ch_cvt_proc]
I (13377) ESP_GMF_TASK: Job is done, [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x3c71acd8, job:0x3c662c54-bit_cvt_proc]
I (13378) ESP_GMF_FILE: CLose, 0x3c663858, pos = 27981/27981
I (13378) ESP_GMF_TASK: One times job is complete, del[wk:0x3c71ac6c,ctx:0x3c6628b4, label:aud_simp_dec_close]
I (13378) ESP_GMF_TASK: One times job is complete, del[wk:0x3c71ab70,ctx:0x3c6629b4, label:rate_cvt_close]
I (13378) ESP_GMF_TASK: One times job is complete, del[wk:0x3c66ab6c,ctx:0x3c662b04, label:ch_cvt_close]
I (13379) ESP_GMF_TASK: One times job is complete, del[wk:0x3c66ab90,ctx:0x3c662c54, label:bit_cvt_close]
I (13379) AUDIO_PROCESSOR: Get State, 4,ESP_AUD_SIMPLE_PLAYER_FINISHED
I (13379) AUDIO_PROCESSOR: audio_prompt_play_mute, enable_mute: 1
I (13491) AUDIO_PROCESSOR: audio_prompt_play_mute, enable_mute: 0
I (13492) ESP_GMF_FILE: Open, dir:1, uri:file://spiffs/wifi_connect_success.mp3
I (13700) esp_netif_handlers: sta ip: 192.168.3.246, mask: 255.255.255.0, gw: 192.168.3.1
I (13817) ESP_GMF_FILE: File size: 13581 byte, file position: 0
I (13817) ESP_GMF_TASK: One times job is complete, del[wk:0x3c66ab94,ctx:0x3c6628b4, label:aud_simp_dec_open]
I (13817) BS:Speaker: [esp_brookesia_speaker_ai_buddy.cpp:0521](processAudioEvent): Play audio: file://spiffs/server_connecting.mp3(create_time_ms: 10640, last_play_time_ms: 0) with timeout_ms: 2000
I (13818) AUDIO_PROCESSOR: audio_prompt_play_with_block, url: file://spiffs/server_connecting.mp3, timeout_ms: -1
I (13819) ESP_GMF_ASMP_DEC: NOTIFY Info, rate: 0, bits: 0, ch: 0 --> rate: 16000, bits: 16, ch: 1
I (13820) ESP_GMF_TASK: One times job is complete, del[wk:0x3c66ab94,ctx:0x3c6629b4, label:rate_cvt_open]
I (13820) ESP_GMF_TASK: One times job is complete, del[wk:0x3c66ae70,ctx:0x3c662b04, label:ch_cvt_open]
I (13820) AUDIO_PROCESSOR: Get info, rate:16000, channels:2, bits:32
I (13821) AUDIO_PROCESSOR: Get State, 1,ESP_AUD_SIMPLE_PLAYER_RUNNING
I (13821) ESP_GMF_TASK: One times job is complete, del[wk:0x3c66aec8,ctx:0x3c662c54, label:bit_cvt_open]
I (14104) wifi:<ba-add>idx:0 (ifx:0, 2c:c5:46:ef:53:7c), tid:0, ssn:6, winSize:64
W (14479) HTTP_CLIENT: This request requires authentication, but does not provide header information for that
E (14480) HTTP_CLIENT: Error response
E (14480) HTTP_CLIENT_POST: HTTP request failed: ESP_ERR_NOT_SUPPORTED
E (14481) BS:Agent: [coze_chat_app.cpp:0392](coze_get_access_token): HTTP POST failed
E (14481) BS:Agent: [coze_chat_app.cpp:0551](coze_chat_app_start): Failed to get access token
E (14482) BS:Agent: [esp_brookesia_ai_agent.cpp:0362](processChatEvent): Start chat failed, retry 1/30
I (15412) ESP_GMF_FILE: No more data, ret: 0
I (15431) ESP_GMF_FILE: No more data, ret: 0
I (15431) ESP_GMF_TASK: Job is done, [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x3c66ab20, job:0x3c6628b4-aud_simp_dec_proc]
I (15432) ESP_GMF_TASK: Job is done, [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x3c71ac5c, job:0x3c6629b4-rate_cvt_proc]
I (15432) ESP_GMF_TASK: Job is done, [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x3c66ae94, job:0x3c662b04-ch_cvt_proc]
I (15432) ESP_GMF_TASK: Job is done, [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x3c66af00, job:0x3c662c54-bit_cvt_proc]
I (15432) ESP_GMF_FILE: CLose, 0x3c663858, pos = 13581/13581
I (15433) ESP_GMF_TASK: One times job is complete, del[wk:0x3c71ac5c,ctx:0x3c6628b4, label:aud_simp_dec_close]
I (15433) ESP_GMF_TASK: One times job is complete, del[wk:0x3c66ab20,ctx:0x3c6629b4, label:rate_cvt_close]
I (15433) ESP_GMF_TASK: One times job is complete, del[wk:0x3c66b158,ctx:0x3c662b04, label:ch_cvt_close]
I (15433) ESP_GMF_TASK: One times job is complete, del[wk:0x3c7c62ec,ctx:0x3c662c54, label:bit_cvt_close]
I (15434) AUDIO_PROCESSOR: Get State, 4,ESP_AUD_SIMPLE_PLAYER_FINISHED
I (15434) AUDIO_PROCESSOR: audio_prompt_play_mute, enable_mute: 1
I (15486) BS:Agent: [coze_chat_app.cpp:0336](coze_get_access_token): payload_str: {"iss":"1138342588443","aud":"api.coze.cn","iat":1761993068,"exp":1761999068,"jti":"68EIdHqdWThAmEUDuSSyWzcSAx0fB0Lk","session_name":"ESP_90E5B1CC60EC","session_context":{"device_info":{"device_id":"ESP_90E5B1CC60EC","custom_consumer":""}}}
I (15487) BS:Agent: [coze_chat_app.cpp:0339](coze_get_access_token): formatted_payload_str: {
"iat": 1761993068,
"exp": 1761999068,
"jti": "68EIdHqdWThAmEUDuSSyWzcSAx0fB0Lk",
"device_info": {
I (15535) AUDIO_PROCESSOR: audio_prompt_play_mute, enable_mute: 0
I (15536) ESP_GMF_FILE: Open, dir:1, uri:file://spiffs/server_connecting.mp3
I (15864) ESP_GMF_FILE: File size: 19629 byte, file position: 0
I (15864) ESP_GMF_TASK: One times job is complete, del[wk:0x3c71ac5c,ctx:0x3c6628b4, label:aud_simp_dec_open]
I (15865) BS:Speaker: [esp_brookesia_speaker_ai_buddy.cpp:0129](operator()): Stop audio: file://spiffs/wifi_connect_success.mp3
I (15867) ESP_GMF_ASMP_DEC: NOTIFY Info, rate: 0, bits: 0, ch: 0 --> rate: 16000, bits: 16, ch: 1
I (15868) ESP_GMF_TASK: One times job is complete, del[wk:0x3c71ac5c,ctx:0x3c6629b4, label:rate_cvt_open]
I (15868) ESP_GMF_TASK: One times job is complete, del[wk:0x3c66aa54,ctx:0x3c662b04, label:ch_cvt_open]
I (15869) AUDIO_PROCESSOR: Get info, rate:16000, channels:2, bits:32
I (15869) AUDIO_PROCESSOR: Get State, 1,ESP_AUD_SIMPLE_PLAYER_RUNNING
I (15869) ESP_GMF_TASK: One times job is complete, del[wk:0x3c7c5190,ctx:0x3c662c54, label:bit_cvt_open]
W (16259) HTTP_CLIENT: This request requires authentication, but does not provide header information for that
E (16259) HTTP_CLIENT: Error response
E (16259) HTTP_CLIENT_POST: HTTP request failed: ESP_ERR_NOT_SUPPORTED
E (16260) BS:Agent: [coze_chat_app.cpp:0392](coze_get_access_token): HTTP POST failed
E (16261) BS:Agent: [coze_chat_app.cpp:0551](coze_chat_app_start): Failed to get access token
E (16261) BS:Agent: [esp_brookesia_ai_agent.cpp:0362](processChatEvent): Start chat failed, retry 2/30
I (17264) BS:Agent: [coze_chat_app.cpp:0336](coze_get_access_token): payload_str: {"iss":"1138342588443","aud":"api.coze.cn","iat":1761993070,"exp":1761999070,"jti":"RMBKVeO68R7W0ePYuH028A266GtPAbiB","session_name":"ESP_90E5B1CC60EC","session_context":{"device_info":{"device_id":"ESP_90E5B1CC60EC","custom_consumer":""}}}
I (17265) BS:Agent: [coze_chat_app.cpp:0339](coze_get_access_token): formatted_payload_str: {
"iat": 1761993070,
"exp": 1761999070,
"jti": "RMBKVeO68R7W0ePYuH028A266GtPAbiB",
"device_info": {
W (18051) HTTP_CLIENT: This request requires authentication, but does not provide header information for that
E (18052) HTTP_CLIENT: Error response
E (18052) HTTP_CLIENT_POST: HTTP request failed: ESP_ERR_NOT_SUPPORTED
E (18053) BS:Agent: [coze_chat_app.cpp:0392](coze_get_access_token): HTTP POST failed
E (18053) BS:Agent: [coze_chat_app.cpp:0551](coze_chat_app_start): Failed to get access token
E (18053) BS:Agent: [esp_brookesia_ai_agent.cpp:0362](processChatEvent): Start chat failed, retry 3/30
I (18232) ESP_GMF_FILE: No more data, ret: 0
I (18236) ESP_GMF_FILE: No more data, ret: 0
I (18236) ESP_GMF_TASK: Job is done, [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x3c66ab20, job:0x3c6628b4-aud_simp_dec_proc]
I (18237) ESP_GMF_TASK: Job is done, [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x3c78535c, job:0x3c6629b4-rate_cvt_proc]
I (18237) ESP_GMF_TASK: Job is done, [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x3c66aa88, job:0x3c662b04-ch_cvt_proc]
I (18237) ESP_GMF_TASK: Job is done, [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x3c7c51b4, job:0x3c662c54-bit_cvt_proc]
I (18238) ESP_GMF_FILE: CLose, 0x3c663858, pos = 19629/19629
I (18238) ESP_GMF_TASK: One times job is complete, del[wk:0x3c78535c,ctx:0x3c6628b4, label:aud_simp_dec_close]
I (18238) ESP_GMF_TASK: One times job is complete, del[wk:0x3c66ab20,ctx:0x3c6629b4, label:rate_cvt_close]
I (18239) ESP_GMF_TASK: One times job is complete, del[wk:0x3c722804,ctx:0x3c662b04, label:ch_cvt_close]
I (18239) ESP_GMF_TASK: One times job is complete, del[wk:0x3c7c6204,ctx:0x3c662c54, label:bit_cvt_close]
I (18239) AUDIO_PROCESSOR: Get State, 4,ESP_AUD_SIMPLE_PLAYER_FINISHED
I (18239) AUDIO_PROCESSOR: audio_prompt_play_mute, enable_mute: 1
I (18351) AUDIO_PROCESSOR: audio_prompt_play_mute, enable_mute: 0
I (18353) ESP_GMF_TASK: Waiting to run... [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x0, run:0]
I (19056) BS:Agent: [coze_chat_app.cpp:0336](coze_get_access_token): payload_str: {"iss":"1138342588443","aud":"api.coze.cn","iat":1761993072,"exp":1761999072,"jti":"HY63eOvYI5cAVf5wJP5R1WZFFsd0iCXO","session_name":"ESP_90E5B1CC60EC","session_context":{"device_info":{"device_id":"ESP_90E5B1CC60EC","custom_consumer":""}}}
I (19068) BS:Agent: [coze_chat_app.cpp:0339](coze_get_access_token): formatted_payload_str: {
"iat": 1761993072,
"exp": 1761999072,
"jti": "HY63eOvYI5cAVf5wJP5R1WZFFsd0iCXO",
"device_info": {
W (19847) HTTP_CLIENT: This request requires authentication, but does not provide header information for that
E (19847) HTTP_CLIENT: Error response
E (19848) HTTP_CLIENT_POST: HTTP request failed: ESP_ERR_NOT_SUPPORTED
E (19848) BS:Agent: [coze_chat_app.cpp:0392](coze_get_access_token): HTTP POST failed
E (19849) BS:Agent: [coze_chat_app.cpp:0551](coze_chat_app_start): Failed to get access token
E (19849) BS:Agent: [esp_brookesia_ai_agent.cpp:0362](processChatEvent): Start chat failed, retry 4/30
I (20851) BS:Agent: [coze_chat_app.cpp:0336](coze_get_access_token): payload_str: {"iss":"1138342588443","aud":"api.coze.cn","iat":1761993074,"exp":1761999074,"jti":"xDcH9mdWtrmHcWHB9CWvYjY0gFZ0DE1Q","session_name":"ESP_90E5B1CC60EC","session_context":{"device_info":{"device_id":"ESP_90E5B1CC60EC","custom_consumer":""}}}
I (20852) BS:Agent: [coze_chat_app.cpp:0339](coze_get_access_token): formatted_payload_str: {
"iat": 1761993074,
"exp": 1761999074,
"jti": "xDcH9mdWtrmHcWHB9CWvYjY0gFZ0DE1Q",
"device_info": {
W (21619) HTTP_CLIENT: This request requires authentication, but does not provide header information for that
E (21620) HTTP_CLIENT: Error response
E (21620) HTTP_CLIENT_POST: HTTP request failed: ESP_ERR_NOT_SUPPORTED
E (21621) BS:Agent: [coze_chat_app.cpp:0392](coze_get_access_token): HTTP POST failed
E (21621) BS:Agent: [coze_chat_app.cpp:0551](coze_chat_app_start): Failed to get access token
E (21622) BS:Agent: [esp_brookesia_ai_agent.cpp:0362](processChatEvent): Start chat failed, retry 5/30
I (22624) BS:Agent: [coze_chat_app.cpp:0336](coze_get_access_token): payload_str: {"iss":"1138342588443","aud":"api.coze.cn","iat":1761993076,"exp":1761999076,"jti":"X05AVhie0bZcadao0MN3xNVnbmADQ9Po","session_name":"ESP_90E5B1CC60EC","session_context":{"device_info":{"device_id":"ESP_90E5B1CC60EC","custom_consumer":""}}}
I (22625) BS:Agent: [coze_chat_app.cpp:0339](coze_get_access_token): formatted_payload_str: {
"iat": 1761993076,
"exp": 1761999076,
"jti": "X05AVhie0bZcadao0MN3xNVnbmADQ9Po",
"device_info": {
W (23407) HTTP_CLIENT: This request requires authentication, but does not provide header information for that
E (23407) HTTP_CLIENT: Error response
E (23407) HTTP_CLIENT_POST: HTTP request failed: ESP_ERR_NOT_SUPPORTED
E (23420) BS:Agent: [coze_chat_app.cpp:0392](coze_get_access_token): HTTP POST failed
E (23421) BS:Agent: [coze_chat_app.cpp:0551](coze_chat_app_start): Failed to get access token
E (23421) BS:Agent: [esp_brookesia_ai_agent.cpp:0362](processChatEvent): Start chat failed, retry 6/30
I (24424) BS:Agent: [coze_chat_app.cpp:0336](coze_get_access_token): payload_str: {"iss":"1138342588443","aud":"api.coze.cn","iat":1761993077,"exp":1761999077,"jti":"xQHH382ml6D0QyQ8D5xtpSXY1TJPxlDF","session_name":"ESP_90E5B1CC60EC","session_context":{"device_info":{"device_id":"ESP_90E5B1CC60EC","custom_consumer":""}}}
I (24425) BS:Agent: [coze_chat_app.cpp:0339](coze_get_access_token): formatted_payload_str: {
"iat": 1761993077,
"exp": 1761999077,
"jti": "xQHH382ml6D0QyQ8D5xtpSXY1TJPxlDF",
"device_info": {
W (25303) HTTP_CLIENT: This request requires authentication, but does not provide header information for that
E (25303) HTTP_CLIENT: Error response
E (25303) HTTP_CLIENT_POST: HTTP request failed: ESP_ERR_NOT_SUPPORTED
E (25305) BS:Agent: [coze_chat_app.cpp:0392](coze_get_access_token): HTTP POST failed
E (25305) BS:Agent: [coze_chat_app.cpp:0551](coze_chat_app_start): Failed to get access token
E (25305) BS:Agent: [esp_brookesia_ai_agent.cpp:0362](processChatEvent): Start chat failed, retry 7/30
I (26309) BS:Agent: [coze_chat_app.cpp:0336](coze_get_access_token): payload_str: {"iss":"1138342588443","aud":"api.coze.cn","iat":1761993079,"exp":1761999079,"jti":"UHf09NVqvhQiRbT5iQRZzEmIfwiYqxF8","session_name":"ESP_90E5B1CC60EC","session_context":{"device_info":{"device_id":"ESP_90E5B1CC60EC","custom_consumer":""}}}
I (26310) BS:Agent: [coze_chat_app.cpp:0339](coze_get_access_token): formatted_payload_str: {
"iat": 1761993079,
"exp": 1761999079,
"jti": "UHf09NVqvhQiRbT5iQRZzEmIfwiYqxF8",
"device_info": {
W (27070) HTTP_CLIENT: This request requires authentication, but does not provide header information for that
E (27070) HTTP_CLIENT: Error response
E (27070) HTTP_CLIENT_POST: HTTP request failed: ESP_ERR_NOT_SUPPORTED
E (27071) BS:Agent: [coze_chat_app.cpp:0392](coze_get_access_token): HTTP POST failed
E (27071) BS:Agent: [coze_chat_app.cpp:0551](coze_chat_app_start): Failed to get access token
E (27072) BS:Agent: [esp_brookesia_ai_agent.cpp:0362](processChatEvent): Start chat failed, retry 8/30
I (28074) BS:Agent: [coze_chat_app.cpp:0336](coze_get_access_token): payload_str: {"iss":"1138342588443","aud":"api.coze.cn","iat":1761993081,"exp":1761999081,"jti":"W8ehZOgK0tiBOEvQqTcIw29FfaVTYnon","session_name":"ESP_90E5B1CC60EC","session_context":{"device_info":{"device_id":"ESP_90E5B1CC60EC","custom_consumer":""}}}
I (28075) BS:Agent: [coze_chat_app.cpp:0339](coze_get_access_token): formatted_payload_str: {
"iat": 1761993081,
"exp": 1761999081,
"jti": "W8ehZOgK0tiBOEvQqTcIw29FfaVTYnon",
"device_info": {
W (28879) HTTP_CLIENT: This request requires authentication, but does not provide header information for that
E (28879) HTTP_CLIENT: Error response
E (28879) HTTP_CLIENT_POST: HTTP request failed: ESP_ERR_NOT_SUPPORTED
E (28880) BS:Agent: [coze_chat_app.cpp:0392](coze_get_access_token): HTTP POST failed
E (28880) BS:Agent: [coze_chat_app.cpp:0551](coze_chat_app_start): Failed to get access token
E (28881) BS:Agent: [esp_brookesia_ai_agent.cpp:0362](processChatEvent): Start chat failed, retry 9/30
I (29885) BS:Agent: [coze_chat_app.cpp:0336](coze_get_access_token): payload_str: {"iss":"1138342588443","aud":"api.coze.cn","iat":1761993083,"exp":1761999083,"jti":"d6NFt0O2mok6sSoienN85TSbBfRvmDNb","session_name":"ESP_90E5B1CC60EC","session_context":{"device_info":{"device_id":"ESP_90E5B1CC60EC","custom_consumer":""}}}
I (29886) BS:Agent: [coze_chat_app.cpp:0339](coze_get_access_token): formatted_payload_str: {
"iat": 1761993083,
"exp": 1761999083,
"jti": "d6NFt0O2mok6sSoienN85TSbBfRvmDNb",
"device_info": {
W (30657) HTTP_CLIENT: This request requires authentication, but does not provide header information for that
E (30658) HTTP_CLIENT: Error response
E (30658) HTTP_CLIENT_POST: HTTP request failed: ESP_ERR_NOT_SUPPORTED
E (30659) BS:Agent: [coze_chat_app.cpp:0392](coze_get_access_token): HTTP POST failed
E (30659) BS:Agent: [coze_chat_app.cpp:0551](coze_chat_app_start): Failed to get access token
E (30659) BS:Agent: [esp_brookesia_ai_agent.cpp:0362](processChatEvent): Start chat failed, retry 10/30
I (31662) BS:Agent: [coze_chat_app.cpp:0336](coze_get_access_token): payload_str: {"iss":"1138342588443","aud":"api.coze.cn","iat":1761993085,"exp":1761999085,"jti":"omVjtqcSJhuGhHbbzFsNdTFzhLTqScVc","session_name":"ESP_90E5B1CC60EC","session_context":{"device_info":{"device_id":"ESP_90E5B1CC60EC","custom_consumer":""}}}
I (31663) BS:Agent: [coze_chat_app.cpp:0339](coze_get_access_token): formatted_payload_str: {
"iat": 1761993085,
"exp": 1761999085,
"jti": "omVjtqcSJhuGhHbbzFsNdTFzhLTqScVc",
"device_info": {
W (32450) HTTP_CLIENT: This request requires authentication, but does not provide header information for that
E (32451) HTTP_CLIENT: Error response
E (32451) HTTP_CLIENT_POST: HTTP request failed: ESP_ERR_NOT_SUPPORTED
E (32452) BS:Agent: [coze_chat_app.cpp:0392](coze_get_access_token): HTTP POST failed
E (32452) BS:Agent: [coze_chat_app.cpp:0551](coze_chat_app_start): Failed to get access token
E (32452) BS:Agent: [esp_brookesia_ai_agent.cpp:0362](processChatEvent): Start chat failed, retry 11/30
I (33455) BS:Agent: [coze_chat_app.cpp:0336](coze_get_access_token): payload_str: {"iss":"1138342588443","aud":"api.coze.cn","iat":1761993086,"exp":1761999086,"jti":"tZUwWbG1x2bdYYkI3gvlMdYPcSGjhjZc","session_name":"ESP_90E5B1CC60EC","session_context":{"device_info":{"device_id":"ESP_90E5B1CC60EC","custom_consumer":""}}}
I (33466) BS:Agent: [coze_chat_app.cpp:0339](coze_get_access_token): formatted_payload_str: {
"iat": 1761993086,
"exp": 1761999086,
"jti": "tZUwWbG1x2bdYYkI3gvlMdYPcSGjhjZc",
"device_info": {
W (34222) HTTP_CLIENT: This request requires authentication, but does not provide header information for that
E (34222) HTTP_CLIENT: Error response
E (34222) HTTP_CLIENT_POST: HTTP request failed: ESP_ERR_NOT_SUPPORTED
E (34233) BS:Agent: [coze_chat_app.cpp:0392](coze_get_access_token): HTTP POST failed
E (34234) BS:Agent: [coze_chat_app.cpp:0551](coze_chat_app_start): Failed to get access token
E (34234) BS:Agent: [esp_brookesia_ai_agent.cpp:0362](processChatEvent): Start chat failed, retry 12/30
I (35237) BS:Agent: [coze_chat_app.cpp:0336](coze_get_access_token): payload_str: {"iss":"1138342588443","aud":"api.coze.cn","iat":1761993088,"exp":1761999088,"jti":"kzF3KOdqVeP6ud5Ihpvi108xwVVQhVlE","session_name":"ESP_90E5B1CC60EC","session_context":{"device_info":{"device_id":"ESP_90E5B1CC60EC","custom_consumer":""}}}
I (35238) BS:Agent: [coze_chat_app.cpp:0339](coze_get_access_token): formatted_payload_str: {
"iat": 1761993088,
"exp": 1761999088,
"jti": "kzF3KOdqVeP6ud5Ihpvi108xwVVQhVlE",
"device_info": {
I (35884) BS:Speaker: [esp_brookesia_speaker_ai_buddy.cpp:0521](processAudioEvent): Play audio: file://spiffs/server_connecting.mp3(create_time_ms: 10640, last_play_time_ms: 13861) with timeout_ms: 3000
I (35885) AUDIO_PROCESSOR: audio_prompt_play_with_block, url: file://spiffs/server_connecting.mp3, timeout_ms: -1
I (35888) ESP_GMF_FILE: Open, dir:1, uri:file://spiffs/server_connecting.mp3
I (35889) ESP_GMF_FILE: File size: 19629 byte, file position: 0
I (35889) ESP_GMF_TASK: One times job is complete, del[wk:0x3c7160d0,ctx:0x3c6628b4, label:aud_simp_dec_open]
I (35892) ESP_GMF_ASMP_DEC: NOTIFY Info, rate: 0, bits: 0, ch: 0 --> rate: 16000, bits: 16, ch: 1
I (35892) ESP_GMF_TASK: One times job is complete, del[wk:0x3c7160d0,ctx:0x3c6629b4, label:rate_cvt_open]
I (35893) ESP_GMF_TASK: One times job is complete, del[wk:0x3c7cf130,ctx:0x3c662b04, label:ch_cvt_open]
I (35893) AUDIO_PROCESSOR: Get info, rate:16000, channels:2, bits:32
I (35894) AUDIO_PROCESSOR: Get State, 1,ESP_AUD_SIMPLE_PLAYER_RUNNING
I (35894) ESP_GMF_TASK: One times job is complete, del[wk:0x3c7cf198,ctx:0x3c662c54, label:bit_cvt_open]
W (36154) HTTP_CLIENT: This request requires authentication, but does not provide header information for that
E (36154) HTTP_CLIENT: Error response
E (36154) HTTP_CLIENT_POST: HTTP request failed: ESP_ERR_NOT_SUPPORTED
E (36155) BS:Agent: [coze_chat_app.cpp:0392](coze_get_access_token): HTTP POST failed
E (36155) BS:Agent: [coze_chat_app.cpp:0551](coze_chat_app_start): Failed to get access token
E (36156) BS:Agent: [esp_brookesia_ai_agent.cpp:0362](processChatEvent): Start chat failed, retry 13/30
I (37158) BS:Agent: [coze_chat_app.cpp:0336](coze_get_access_token): payload_str: {"iss":"1138342588443","aud":"api.coze.cn","iat":1761993090,"exp":1761999090,"jti":"P9Zp84qIBNcJXnD9DhXvdWBZsSCbDbQM","session_name":"ESP_90E5B1CC60EC","session_context":{"device_info":{"device_id":"ESP_90E5B1CC60EC","custom_consumer":""}}}
I (37159) BS:Agent: [coze_chat_app.cpp:0339](coze_get_access_token): formatted_payload_str: {
"iat": 1761993090,
"exp": 1761999090,
"jti": "P9Zp84qIBNcJXnD9DhXvdWBZsSCbDbQM",
"device_info": {
W (37958) HTTP_CLIENT: This request requires authentication, but does not provide header information for that
E (37958) HTTP_CLIENT: Error response
E (37958) HTTP_CLIENT_POST: HTTP request failed: ESP_ERR_NOT_SUPPORTED
E (37960) BS:Agent: [coze_chat_app.cpp:0392](coze_get_access_token): HTTP POST failed
E (37960) BS:Agent: [coze_chat_app.cpp:0551](coze_chat_app_start): Failed to get access token
E (37960) BS:Agent: [esp_brookesia_ai_agent.cpp:0362](processChatEvent): Start chat failed, retry 14/30
I (38257) ESP_GMF_FILE: No more data, ret: 0
I (38261) ESP_GMF_FILE: No more data, ret: 0
I (38261) ESP_GMF_TASK: Job is done, [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x3c7c8210, job:0x3c6628b4-aud_simp_dec_proc]
I (38262) ESP_GMF_TASK: Job is done, [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x3c7c81d0, job:0x3c6629b4-rate_cvt_proc]
I (38262) ESP_GMF_TASK: Job is done, [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x3c7cf164, job:0x3c662b04-ch_cvt_proc]
I (38262) ESP_GMF_TASK: Job is done, [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x3c7cf1d0, job:0x3c662c54-bit_cvt_proc]
I (38263) ESP_GMF_FILE: CLose, 0x3c663858, pos = 19629/19629
I (38263) ESP_GMF_TASK: One times job is complete, del[wk:0x3c7cf164,ctx:0x3c6628b4, label:aud_simp_dec_close]
I (38263) ESP_GMF_TASK: One times job is complete, del[wk:0x3c719fd8,ctx:0x3c6629b4, label:rate_cvt_close]
I (38264) ESP_GMF_TASK: One times job is complete, del[wk:0x3c7c8054,ctx:0x3c662b04, label:ch_cvt_close]
I (38264) ESP_GMF_TASK: One times job is complete, del[wk:0x3c7c8078,ctx:0x3c662c54, label:bit_cvt_close]
I (38264) AUDIO_PROCESSOR: Get State, 4,ESP_AUD_SIMPLE_PLAYER_FINISHED
I (38264) AUDIO_PROCESSOR: audio_prompt_play_mute, enable_mute: 1
I (38391) AUDIO_PROCESSOR: audio_prompt_play_mute, enable_mute: 0
I (38392) ESP_GMF_TASK: Waiting to run... [tsk:TSK_0x3c65f1e4-0x3c65f1e4, wk:0x0, run:0]
I (38974) BS:Agent: [coze_chat_app.cpp:0336](coze_get_access_token): payload_str: {"iss":"1138342588443","aud":"api.coze.cn","iat":1761993092,"exp":1761999092,"jti":"YQh907Cizn0ypopYYNUxzrNUsejpVmyX","session_name":"ESP_90E5B1CC60EC","session_context":{"device_info":{"device_id":"ESP_90E5B1CC60EC","custom_consumer":""}}}
I (38975) BS:Agent: [coze_chat_app.cpp:0339](coze_get_access_token): formatted_payload_str: {
"iat": 1761993092,
"exp": 1761999092,
"jti": "YQh907Cizn0ypopYYNUxzrNUsejpVmyX",
"device_info": {
W (39721) HTTP_CLIENT: This request requires authentication, but does not provide header information for that
E (39722) HTTP_CLIENT: Error response
E (39722) HTTP_CLIENT_POST: HTTP request failed: ESP_ERR_NOT_SUPPORTED
E (39723) BS:Agent: [coze_chat_app.cpp:0392](coze_get_access_token): HTTP POST failed
E (39723) BS:Agent: [coze_chat_app.cpp:0551](coze_chat_app_start): Failed to get access token
E (39723) BS:Agent: [esp_brookesia_ai_agent.cpp:0362](processChatEvent): Start chat failed, retry 15/30
I (40726) BS:Agent: [coze_chat_app.cpp:0336](coze_get_access_token): payload_str: {"iss":"1138342588443","aud":"api.coze.cn","iat":1761993094,"exp":1761999094,"jti":"PhywBsRCmiquNRF5w6YGAwHNQSoj5vmI","session_name":"ESP_90E5B1CC60EC","session_context":{"device_info":{"device_id":"ESP_90E5B1CC60EC","custom_consumer":""}}}
I (40727) BS:Agent: [coze_chat_app.cpp:0339](coze_get_access_token): formatted_payload_str: {
"iat": 1761993094,
"exp": 1761999094,
"jti": "PhywBsRCmiquNRF5w6YGAwHNQSoj5vmI",
"device_info": {
W (41521) HTTP_CLIENT: This request requires authentication, but does not provide header information for that
E (41521) HTTP_CLIENT: Error response
E (41521) HTTP_CLIENT_POST: HTTP request failed: ESP_ERR_NOT_SUPPORTED
E (41523) BS:Agent: [coze_chat_app.cpp:0392](coze_get_access_token): HTTP POST failed
E (41523) BS:Agent: [coze_chat_app.cpp:0551](coze_chat_app_start): Failed to get access token
E (41523) BS:Agent: [esp_brookesia_ai_agent.cpp:0362](processChatEvent): Start chat failed, retry 16/30
I (42526) BS:Agent: [coze_chat_app.cpp:0336](coze_get_access_token): payload_str: {"iss":"1138342588443","aud":"api.coze.cn","iat":1761993095,"exp":1761999095,"jti":"QBZbuR4vlKFzky1yB1jFuYmyay6TvjWn","session_name":"ESP_90E5B1CC60EC","session_context":{"device_info":{"device_id":"ESP_90E5B1CC60EC","custom_consumer":""}}}
I (42527) BS:Agent: [coze_chat_app.cpp:0339](coze_get_access_token): formatted_payload_str: {
"iat": 1761993095,
"exp": 1761999095,
"jti": "QBZbuR4vlKFzky1yB1jFuYmyay6TvjWn",
"device_info": {
W (43420) HTTP_CLIENT: This request requires authentication, but does not provide header information for that
E (43421) HTTP_CLIENT: Error response
E (43421) HTTP_CLIENT_POST: HTTP request failed: ESP_ERR_NOT_SUPPORTED
E (43422) BS:Agent: [coze_chat_app.cpp:0392](coze_get_access_token): HTTP POST failed
E (43422) BS:Agent: [coze_chat_app.cpp:0551](coze_chat_app_start): Failed to get access token
E (43422) BS:Agent: [esp_brookesia_ai_agent.cpp:0362](processChatEvent): Start chat failed, retry 17/30
I (44425) BS:Agent: [coze_chat_app.cpp:0336](coze_get_access_token): payload_str: {"iss":"1138342588443","aud":"api.coze.cn","iat":1761993097,"exp":1761999097,"jti":"aDAijZDNQvIyidp6udG23h5Lt9YP4kgk","session_name":"ESP_90E5B1CC60EC","session_context":{"device_info":{"device_id":"ESP_90E5B1CC60EC","custom_consumer":""}}}
I (44426) BS:Agent: [coze_chat_app.cpp:0339](coze_get_access_token): formatted_payload_str: {
"iat": 1761993097,
"exp": 1761999097,
"jti": "aDAijZDNQvIyidp6udG23h5Lt9YP4kgk",
"device_info": {
W (45184) HTTP_CLIENT: This request requires authentication, but does not provide header information for that
E (45184) HTTP_CLIENT: Error response
E (45184) HTTP_CLIENT_POST: HTTP request failed: ESP_ERR_NOT_SUPPORTED
E (45185) BS:Agent: [coze_chat_app.cpp:0392](coze_get_access_token): HTTP POST failed
E (45185) BS:Agent: [coze_chat_app.cpp:0551](coze_chat_app_start): Failed to get access token
E (45186) BS:Agent: [esp_brookesia_ai_agent.cpp:0362](processChatEvent): Start chat failed, retry 18/30
I (46188) BS:Agent: [coze_chat_app.cpp:0336](coze_get_access_token): payload_str: {"iss":"1138342588443","aud":"api.coze.cn","iat":1761993099,"exp":1761999099,"jti":"AxoA4yYGmUECo96At9c0F385nPynozO8","session_name":"ESP_90E5B1CC60EC","session_context":{"device_info":{"device_id":"ESP_90E5B1CC60EC","custom_consumer":""}}}
I (46189) BS:Agent: [coze_chat_app.cpp:0339](coze_get_access_token): formatted_payload_str: {
"iat": 1761993099,
"exp": 1761999099,
"jti": "AxoA4yYGmUECo96At9c0F385nPynozO8",
"device_info": {
W (46976) HTTP_CLIENT: This request requires authentication, but does not provide header information for that
E (46976) HTTP_CLIENT: Error response
E (46976) HTTP_CLIENT_POST: HTTP request failed: ESP_ERR_NOT_SUPPORTED
Guru Meditation Error: Core 1 panic'ed (StoreProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x403893c9 PS : 0x00060b33 A0 : 0x80388f98 A1 : 0x3fcc6ec0
A2 : 0x3c5c56dc A3 : 0x3c7c8858 A4 : 0x00060720 A5 : 0x00060b23
A6 : 0x3c7c8850 A7 : 0x3c7c8850 A8 : 0xa5a5a5a5 A9 : 0x3c7c885b
A10 : 0x0000001a A11 : 0x00000017 A12 : 0x3c5c5748 A13 : 0x00000005
A14 : 0x3a2266f0 A15 : 0x00000004 SAR : 0x0000001b EXCCAUSE: 0x0000001d
EXCVADDR: 0xa5a5a5b1 LBEG : 0x400570e8 LEND : 0x400570f3 LCOUNT : 0x00000000
Backtrace: 0x403893c6:0x3fcc6ec0 0x40388f95:0x3fcc6ee0 0x40376b15:0x3fcc6f00 0x4223c22d:0x3fcc6f20 0x4223a0c2:0x3fcc6f40 0x42233608:0x3fcc6f60 0x42232eaf:0x3fcc6f80 0x4222a87d:0x3fcc6fa0 0x4222b2f4:0x3fcc6fc0 0x4222cbb8:0x3fcc6fe0 0x42224e21:0x3fcc7000 0x42224e31:0x3fcc7020 0x42224758:0x3fcc7040 0x42225807:0x3fcc7060 0x422dae71:0x3fcc7080 0x422278b5:0x3fcc70a0 0x4200c3fd:0x3fcc70d0 0x4209f4eb:0x3fcc71a0 0x4206783d:0x3fcc7290 0x42067ec7:0x3fcc7300 0x420a5063:0x3fcc7390 0x42009074:0x3fcc73d0
ELF file SHA256: 65471eb90
Rebooting...
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0xc (RTC_SW_CPU_RST),boot:0x2b (SPI_FAST_FLASH_BOOT)
Saved PC:0x403760de
SPIWP:0xee
Octal Flash Mode Enabled
For OPI Flash, Use Default Flash Boot Mode
mode:SLOW_RD, clock div:1
load:0x3fce2820,len:0x1710
load:0x403c8700,len:0xe1c
load:0x403cb700,len:0x31e0
entry 0x403c8938
I (33) boot: ESP-IDF v5.5-beta1-213-gadb3f2a580 2nd stage bootloader
I (33) boot: compile time Jul 8 2025 01:29:11
I (33) boot: Multicore bootloader
I (34) boot: chip revision: v0.2
I (34) boot: efuse block revision: v1.3
I (34) boot.esp32s3: Boot SPI Speed : 80MHz
I (34) boot.esp32s3: SPI Mode : SLOW READ
I (34) boot.esp32s3: SPI Flash Size : 16MB
I (34) boot: Enabling RNG early entropy source...
I (35) boot: Partition Table:
I (35) boot: ## Label Usage Type ST Offset Length
I (35) boot: 0 nvs WiFi data 01 02 00009000 00004000
I (36) boot: 1 otadata OTA data 01 00 0000d000 00002000
I (36) boot: 2 phy_init RF data 01 01 0000f000 00001000
I (36) boot: 3 model Unknown data 01 82 00010000 0004b000
I (37) boot: 4 ota_0 OTA app 00 10 00060000 005dc000
I (37) boot: 5 spiffs_data Unknown data 01 82 0063c000 004e2000
I (38) boot: 6 anim_emotion Unknown data 01 82 00b1e000 00145000
I (38) boot: 7 anim_icon Unknown data 01 82 00c63000 00118000
I (38) boot: 8 anim_boot Unknown data 01 82 00d7b000 000a0000
I (39) boot: 9 storage Unknown data 01 81 00e1b000 00040000
I (39) boot: End of partition table
I (40) esp_image: segment 0: paddr=00060020 vaddr=3c2f0020 size=29b134h (2732340) map
I (682) esp_image: segment 1: paddr=002fb15c vaddr=3fc9d800 size=04ebch ( 20156) load
I (688) esp_image: segment 2: paddr=00300020 vaddr=42000020 size=2eb354h (3060564) map
I (1408) esp_image: segment 3: paddr=005eb37c vaddr=3fca26bc size=054d4h ( 21716) load
I (1414) esp_image: segment 4: paddr=005f0858 vaddr=40374000 size=19768h (104296) load
I (1443) esp_image: segment 5: paddr=00609fc8 vaddr=600fe000 size=00020h ( 32) load
I (1455) boot: Loaded app from partition at offset 0x60000
I (1455) boot: Disabling RNG early entropy source...
I (1456) MSPI Timing: Flash timing tuning index: 3
I (1457) octal_psram: vendor id : 0x0d (AP)
I (1457) octal_psram: dev id : 0x03 (generation 4)
I (1457) octal_psram: density : 0x05 (128 Mbit)
I (1457) octal_psram: good-die : 0x01 (Pass)
I (1457) octal_psram: Latency : 0x01 (Fixed)
I (1458) octal_psram: VCC : 0x00 (1.8V)
I (1458) octal_psram: SRF : 0x01 (Fast Refresh)
I (1458) octal_psram: BurstType : 0x01 (Hybrid Wrap)
I (1458) octal_psram: BurstLen : 0x01 (32 Byte)
I (1459) octal_psram: Readlatency : 0x02 (10 cycles@Fixed)
I (1459) octal_psram: DriveStrength: 0x00 (1/1)
联系我们
GitHub
用户社区
下载教程
Copyright © 2025 wmnologo
Connected
