源码:example-espressif__esp_coze-v0.6.0-coze_ws_app.zip
编译下载到驱动板(正点原子DNESP32S3开发板),配好了`Access token` 和 `BOT ID`,但是报错了,可能是哪里没配好吗?
报错如下:
I (9451) wifi:dp: 1, bi: 102400, li: 3, scale listen interval from 307200 us to 307200 us
I (9459) wifi:set rx beacon pti, rx_bcn_pti: 0, bcn_timeout: 25000, mt_pti: 0, mt_time: 10000
I (9467) wifi:dp: 2, bi: 102400, li: 4, scale listen interval from 307200 us to 409600 us
I (9475) wifi:AP's beacon interval = 102400 us, DTIM period = 2
I (9503) wifi:<ba-add>idx:0 (ifx:0, 26:c9:38:61:4f:5c), tid:0, ssn:1, winSize:64
I (10519) esp_netif_handlers: example_netif_sta ip: 192.168.40.141, mask: 255.255.255.0, gw: 192.168.40.168
I (10519) example_connect: Got IPv4 event: Interface "example_netif_sta" address: 192.168.40.141
I (10946) example_connect: Got IPv6 event: Interface "example_netif_sta" address: fe80:0000:0000:0000
I (10949) example_common: Connected to example_netif_sta
I (10954) example_common: - IPv4 address: 192.168.40.141,
I (10959) example_common: - IPv6 address: fe80:0000:0000:0000
I (10970) ESP_COZE_CHAT: wss_url: wss://ws.coze.cn/v1/chat?bot_id=7507157990282395648
I (10977) ESP_COZE_CHAT: token: Bearer pat_DzvQfAY1KJdMNV5Lv3TwvVAhZOF3GgfHrARzaALbeaiduyIOVt2WpAUVlcMEuFNJ
I (10987) ESP_COZE_CHAT: WEBSOCKET_EVENT_BEGIN
I (10991) websocket_client: Started
I (11946) example_connect: Got IPv6 event: Interface "example_netif_sta" address: 2409:892a
I (15295) ESP_COZE_CHAT: WEBSOCKET_EVENT_CONNECTED
I (15295) ESP_COZE_CHAT: WS connected
E (15295) HTTP_CLIENT: esp_http_client_init(801): Failed to convert addr type 1448036729
I (15297) ESP_COZE_CHAT: Log ID: 021762246147235fdbddc02002809120000000000000026561828
Guru Meditation Error: Core 0 panic'ed (StoreProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x421ba1af PS : 0x00060430 A0 : 0x8200f0f2 A1 : 0x3fcb27c0
--- 0x421ba1af: esp_http_client_set_method at D:/esp/esp/v5.5.1/esp-idf/components/esp_http_client/esp_http_client.c:1237
A2 : 0x00000000 A3 : 0x00000000 A4 : 0x00000094 A5 : 0x564f4979
A6 : 0x3fcc8bf0 A7 : 0x3fcb27f0 A8 : 0x821244fb A9 : 0x3fcb2780
A10 : 0x00000000 A11 : 0x3c1ee720 A12 : 0x3c1eeb94 A13 : 0x00003bbf
A14 : 0x3c1ee720 A15 : 0x3fcc8bd4 SAR : 0x0000001a EXCCAUSE: 0x0000001d
EXCVADDR: 0x0000006c LBEG : 0x400570e8 LEND : 0x400570f3 LCOUNT : 0x00000000
--- 0x400570e8: memset in ROM
--- 0x400570f3: memset in ROM
Backtrace: 0x421ba1ac:0x3fcb27c0 0x4200f0ef:0x3fcb27e0 0x4200eee9:0x3fcb28b0 0x4200c164:0x3fcb2980 0x4200bf27:0x3fcb2a10 0x421c40db:0x3fcb2a60
--- 0x421ba1ac: esp_http_client_set_method at D:/esp/esp/v5.5.1/esp-idf/components/esp_http_client/esp_http_client.c:1236
--- 0x4200f0ef: http_client_post at ??:?
--- 0x4200eee9: esp_coze_chat_start at ??:?
--- 0x4200c164: init_coze_chat at E:/01-work-svn/TCGDIR/work-ESP32/examples/01-back/coze_ws_app/main/coze_chat_app.c:81
--- (inlined by) coze_chat_app_init at E:/01-work-svn/TCGDIR/work-ESP32/examples/01-back/coze_ws_app/main/coze_chat_app.c:214
--- 0x4200bf27: app_main at E:/01-work-svn/TCGDIR/work-ESP32/examples/01-back/coze_ws_app/main/main.c:71
--- 0x421c40db: main_task at D:/esp/esp/v5.5.1/esp-idf/components/freertos/app_startup.c:208
