Esp32S3 : How to update partition table using OTA ?
ThomasESP32
Postby ThomasESP32 » Fri Nov 07, 2025 12:51 pm
Good afternoon,
I am working with an Esp32S3 and I manage to do OTA firmware update.
In order to do that, I have defined two partitions ota_0 and ota_1 in the partitions.csv file and I use the :
esp_ota_begin();
esp_ota_write();
methods in order to do OTA Update.
In my partitions.csv file, I have a partition called storage defined this way :
storage, data, fat, , 512K,
I would like to change the way it is defined like that :
storage, data, littlefs, , 512K,
So, in the next version of firmware, I will be able to use this partition as littlefs.
is it possible to update the partition table in OTA before updating the firmware please ?
If the answer is yes, could you please explain me how to do it ?
best regards,
thnak you for your help,
Thomas TRUILHE
leschge
Re: Esp32S3 : How to update partition table using OTA ?
Postby leschge » Wed Mar 25, 2026 9:13 am
To my knowledge there is no API available for that which means you have to rewrite the flash on that address (default 0x8000) by yourself. https://docs.espressif.com/projects/esp ... ion-tables
However this causes risk of breaking your devices on powerloss or similar. In addition you may have to enable dangerous flash writes in the menuconfig.
ESP_rrtandler
Postby ESP_rrtandler » Tue Apr 07, 2026 1:16 pm
Hi @ThomasESP32 ,
There is an example showing OTA manipulating partition table in ESP-IDF repo: https://github.com/espressif/esp-idf/tr ... ta-example
Hope it helps you.
Users browsing this forum: Bing [Bot], ChatGPT-User and 1 guest
