ESP-IDF v 5.5.1 and Arduino-ESP32 v3.3.3 not working with M5Unified
kondrat
Postby kondrat » Sun Nov 09, 2025 9:29 am
Hi. I use VS Code + ESP-IDF. I add Arduino ESP32 as Component.
I'm trying to flash the m5basic with this Example using the display.
I added arduino as a component, and M5Unified, M5GFX from component registry. When I flash the device, everything is fine, but it keeps restarting and the monitor displays an error and the device doesn't work.
But if I remove #include "Arduino.h", screen on the m5basic, it works.
Are there any examples of usage for ESP-IDF, sdkconfig and source code?
ESP-IDF v5.5.1
M5Unified v0.2.7 and a try with v0.2.10
M5GFX v0.2.9 and a try with v0.2.17
main.cpp
#include "M5Unified.h"
#include "M5GFX.h"
void setup()
    auto cfg = M5.config();
    M5.begin(cfg);
    delay(500);
    M5.Display.fillScreen(TFT_BLACK);
    M5.Display.setCursor(10, 10);
    M5.Display.setTextColor(WHITE);
    M5.Display.setTextSize(1);
    M5.Display.print("Initializing...");
void loop()
    M5.update();
    delay(1000);
Monitor
ets Jun  8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:6216
load:0x40078000,len:16004
load:0x40080400,len:4
--- 0x40080400: _init at ??:?
load:0x40080404,len:3620
entry 0x400805bc
W (29) boot: Unicore bootloader
I (163) cpu_start: Unicore app
I (163) cpu_start: Single core mode
I (171) cpu_start: Pro cpu start user code
I (171) cpu_start: cpu freq: 240000000 Hz
I (171) app_init: Application information:
I (176) app_init: Project name:     project-name1
I (181) app_init: App version:      1
I (186) app_init: Compile time:     Nov  6 2025 12:10:32
I (192) app_init: ELF file SHA256:  907198111...
I (197) app_init: ESP-IDF:          v5.3.1-dirty
I (202) efuse_init: Min chip rev:     v0.0
I (207) efuse_init: Max chip rev:     v3.99
I (212) efuse_init: Chip rev:         v1.0
I (217) heap_init: Initializing. RAM available for dynamic allocation:
I (224) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (230) heap_init: At 3FFB3448 len 0002CBB8 (178 KiB): DRAM
I (236) heap_init: At 3FFE0440 len 0001FBC0 (126 KiB): D/IRAM
I (243) heap_init: At 40078000 len 00008000 (32 KiB): IRAM
I (249) heap_init: At 4008F6D0 len 00010930 (66 KiB): IRAM
I (255) heap_init: At 3FF80000 len 00002000 (8 KiB): RTCRAM
I (262) spi_flash: detected chip: generic
I (266) spi_flash: flash io: qio
I (271) main_task: Started on CPU0
I (274) main_task: Calling app_main()
tart ========task: Returned =========== Bfrom app_mefore Setup Sain()
Chip Info:
  Model             : ESP32
  Package           : D0WD-Q6
  Revision          : 1.00
  Cores             : 2
  CPU Frequency     : 240 MHz
  XTAL Frequency    : 40 MHz
  Features Bitfield : 0x00000032
  Embedded Flash    : No
  Embedded PSRAM    : No
  2.4GHz WiFi       : Yes
  Classic BT        : Yes
  BT Low Energy     : Yes
  IEEE 802.15.4     : No
INTERNAL Memory Info:
  Total Size        :   428488 B ( 418.4 KB)
  Free Bytes        :   400904 B ( 391.5 KB)
  Allocated Bytes   :    23176 B (  22.6 KB)
  Minimum Free Bytes:   400872 B ( 391.5 KB)
  Largest Free Block:   163840 B ( 160.0 KB)
Flash Info:
  Chip Size         :  4194304 B (4 MB)
  Block Size        :    65536 B (  64.0 KB)
  Sector Size       :     4096 B (   4.0 KB)
  Page Size         :      256 B (   0.2 KB)
  Bus Speed         : 80 MHz
  Flash Frequency   : 80 MHz (source: 80 MHz, divider: 1)
  Bus Mode          : QIO
Partitions Info:
                nvs : addr: 0x00009000, size:    24.0 KB, type: DATA, subtype: NVS
           phy_init : addr: 0x0000F000, size:     4.0 KB, type: DATA, subtype: PHY
            factory : addr: 0x00010000, size:  1024.0 KB, type:  APP, subtype: FACTORY
Software Info:
  Compile Date/Time : Nov  6 2025 12:33:38
  ESP-IDF Version   : v5.3.1-dirty
  Arduino Version   : 3.3.2
Board Info:
  Arduino Board     : M5STACK_CORE_DEV
  Arduino Variant   : m5stack_core
  Arduino Runs Core : 0
  Arduino Events on : 0
  CDC On Boot       : 0
============ Before Setup End ============
�Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.
Core  0 register dump:
PC      : 0x400d9405  PS      : 0x00060f30  A0      : 0x800dc0fd  A1      : 0x3ffb78f0
--- 0x400d9405: unsigned long lgfx::v1::color_conv_t::convert<int, decltype(nullptr)>(int) at E:/<->/project-name1/managed_components/m5stack__m5gfx/src/lgfx/v1/misc/colortype.hpp:859
 (inlined by) void lgfx::v1::LGFXBase::setColor<int>(int) at E:/<->/project-name1/managed_components/m5stack__m5gfx/src/lgfx/v1/LGFXBase.hpp:123
 (inlined by) void lgfx::v1::LGFXBase::fillScreen<int>(int const&) at E:/<->/project-name1/managed_components/m5stack__m5gfx/src/lgfx/v1/LGFXBase.hpp:299
 (inlined by) setup() at E:/<->/project-name1/main/main.cpp:329
A2      : 0x00000001  A3      : 0x00000003  A4      : 0x00000001  A5      : 0xffffffff
A6      : 0x00000000  A7      : 0x3ffb2794  A8      : 0x800d9402  A9      : 0x3ffb78d0
A10     : 0x000003e8  A11     : 0x3ffb792c  A12     : 0x0000001c  A13     : 0x3ffb790c
A14     : 0x00000000  A15     : 0x00000080  SAR     : 0x0000001f  EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000040  LBEG    : 0x4000c2e0  LEND    : 0x4000c2f6  LCOUNT  : 0x00000000
--- 0x4000c2e0: memcpy in ROM
0x4000c2f6: memcpy in ROM
Backtrace: 0x400d9402:0x3ffb78f0 0x400dc0fa:0x3ffb7950 0x400889b2:0x3ffb7970
--- 0x400d9402: setup() at E:/<->/project-name1/main/main.cpp:329
0x400dc0fa: loopTask(void*) at E:/<->/project-name1/components/arduino/cores/esp32/main.cpp:67
0x400889b2: vPortTaskWrapper at E:/Espressif/frameworks/esp-idf-v5.3.1/components/freertos/FreeRTOS-Kernel/portable/xtensa/port.c:134
Rebooting...
Users browsing this forum: Baidu [Spider], Google [Bot] and 1 guest
