MIPI->ISP->PPA->H264->SD Card pipeline performance
try_except
Postby try_except » Wed Nov 19, 2025 2:04 pm
Hi all!
I've been working for a couple of months on a video capturing project on ESP32-P4 and so far I've managed to achieve 1080p@30 fps performance for the MIPI->ISP->H264->SD Card pipeline with no problem, but I'm experiencing framerate drops when including the PPA in my system. At first I thought PSRAM bandwidth limitations was slowing down the loop, because I was executing each step as a separate task and so every single step would read and write big buffers from the PSRAM, but now I've joined everything in a single task and achieved the same 20 fps as before.
Right now I'm using an OV5647 sensor running at 1280x960@45 fps, trying to scale down by a factor of 2 (so 640x480), PSRAM is running at 200 MHz, I'm not writing to SD and I'm printing the following message once every second:
I (709451) Video Manager: Bitrate = 997296 bps = 121 kB/s, Set bitrate= 1175040 bps, FPS=20, Set FPS=45
I (710481) Video Manager: Bitrate = 1028288 bps = 125 kB/s, Set bitrate= 1175040 bps, FPS=20, Set FPS=45
I (711501) Video Manager: Bitrate = 1025600 bps = 125 kB/s, Set bitrate= 1175040 bps, FPS=20, Set FPS=45
I (712521) Video Manager: Bitrate = 3149160 bps = 384 kB/s, Set bitrate= 1175040 bps, FPS=20, Set FPS=45
I (713541) Video Manager: Bitrate = 1777744 bps = 217 kB/s, Set bitrate= 1175040 bps, FPS=20, Set FPS=45
I (714561) Video Manager: Bitrate = 3067824 bps = 374 kB/s, Set bitrate= 1175040 bps, FPS=20, Set FPS=45
I (715581) Video Manager: Bitrate = 4489584 bps = 548 kB/s, Set bitrate= 1175040 bps, FPS=20, Set FPS=45
As you can see, FPS don't change with bitrate, so it's not about bandwidth (as far as I can tell).
I understand running the whole pipeline can take more than 22.2 ms (45 FPS), but since there's no information about expected PPA performance, I wanted to ask here if there's anything I could be doing wrong. I'm not using the esp_video library since it's terribly memory-hungry, so I used esp_cam_sensor and esp_h264 to configure the sensor and the encoder.
Code snippets
Component initialization
//--------Camera Sensor and SCCB Init-----------//
  example_sensor_handle_t sensor_handle = {
      .sccb_handle    = NULL,
      .i2c_bus_handle = NULL,
  example_sensor_config_t cam_sensor_config = {
      .i2c_port_num   = I2C_NUM_0,
      .i2c_sda_io_num = GPIO_NUM_7,
      .i2c_scl_io_num = GPIO_NUM_8,
      .port           = ESP_CAM_SENSOR_MIPI_CSI,
      .format_name    = "MIPI_2lane_24Minput_RAW10_1280x960_binning_45fps",
  example_sensor_init(&cam_sensor_config, &sensor_handle);
  // Configure and create the CSI controller
  esp_cam_ctlr_csi_config_t cfg = {
      .ctlr_id                = 0,
      .h_res                  = HRES,
      .v_res                  = VRES,
      .lane_bit_rate_mbps     = CSI_LANE_BITRATE_MBPS,
      .input_data_color_type  = CSI_INPUT_COLOR,
      .output_data_color_type = CSI_OUTPUT_COLOR,
      .data_lane_num          = CSI_LANES,
      .byte_swap_en           = false,
      .queue_items            = FRAME_BUF_COUNT,  // >1 helps continuous capture
  ESP_ERROR_CHECK(esp_cam_new_csi_ctlr(&cfg, &s_cam));
  // Register callbacks that hand buffers to the driver and notify on completion
  esp_cam_ctlr_evt_cbs_t cbs = {.on_trans_finished = on_trans_finished};
  //---------------ISP Init------------------//
  isp_proc_handle_t       isp_proc   = NULL;
  esp_isp_processor_cfg_t isp_config = {
      .clk_hz                 = 80 * 1000 * 1000,
      .input_data_source      = ISP_INPUT_DATA_SOURCE_CSI,
      .input_data_color_type  = ISP_COLOR_RAW10,
      .output_data_color_type = ISP_COLOR_YUV420,
      .has_line_start_packet  = false,
      .has_line_end_packet    = false,
      .h_res                  = HRES,
      .v_res                  = VRES,
      .bayer_order            = COLOR_RAW_ELEMENT_ORDER_GBRG,
  ESP_ERROR_CHECK(esp_isp_new_processor(&isp_config, &isp_proc));
  ESP_ERROR_CHECK(esp_isp_enable(isp_proc));
  //---------------PPA Client Init------------------//
  /// TODO: Go to a fail tag instead of using ESP_ERROR_CHECK
  ppa_client_config_t ppa_srm_config = {
      .oper_type             = PPA_OPERATION_SRM,
      .max_pending_trans_num = PPA_BUF_COUNT,
      .data_burst_length     = PPA_DATA_BURST_LENGTH_128,
  ESP_ERROR_CHECK(ppa_register_client(&ppa_srm_config, &s_ppa));
  ppa_event_callbacks_t ppa_cbs = {
      .on_trans_done = on_frame_scaled,
  ESP_ERROR_CHECK(ppa_client_register_event_callbacks(s_ppa, &ppa_cbs));
Pipeline loop
static void capture_task(void *arg) {
  uint32_t                  frame_idx         = 0;
  uint8_t                  *frame             = NULL;
  uint64_t                  now               = esp_timer_get_time();
  uint64_t                  encoded           = 0;
  int                       frames_per_second = 0;
  esp_h264_enc_out_frame_t *out               = {0};
  // Encoder parameter values (useful for debugging)
  esp_h264_enc_param_hw_handle_t param_hd;
  uint32_t                       set_bitrate = 0;
  uint8_t                        set_fps     = 0;
  while (1) {
    ESP_LOGV(TAG, "[%s] Receiving frame from s_free_frame_q", pcTaskGetName(NULL));
    xQueueReceive(s_free_frame_q, &frame, portMAX_DELAY);
    ESP_LOGV(TAG, "[%s] Got frame", pcTaskGetName(NULL));
    esp_cam_ctlr_trans_t trans = {
        .buffer = frame,
        .buflen = FRAME_BYTES,
    // Ask the camera sensor to fill the buffer
    ESP_LOGV(TAG, "[%s] Receiving transaction from sensor", pcTaskGetName(NULL));
    ESP_ERROR_CHECK(esp_cam_ctlr_receive(s_cam, &trans, ESP_CAM_CTLR_MAX_DELAY));
    ESP_LOGV(TAG, "[%s] Receiving buffer from s_free_encoded_q", pcTaskGetName(NULL));
    xQueueReceive(s_free_encoded_q, &out, portMAX_DELAY);  // Get a free encoded buffer
    s_srm_cfg.in.buffer       = frame;
    s_srm_cfg.out.buffer      = out->raw_data.buffer;
    s_srm_cfg.out.buffer_size = out->raw_data.len;
    ESP_LOGV(TAG, "[%s] Scaling", pcTaskGetName(NULL));
    ppa_do_scale_rotate_mirror(s_ppa, &s_srm_cfg);
    ESP_LOGV(TAG, "[%s] PPA scaling started", pcTaskGetName(NULL));
    xSemaphoreTake(ppa_semphr, portMAX_DELAY);
    xQueueSendToBack(s_free_frame_q, &frame, portMAX_DELAY);  // Return the sensor buffer
    esp_h264_enc_in_frame_t in = {0};
    in.pts             = (frame_idx * 1000U) / H264_FPS;  // ms timebase is fine for raw stream
    in.raw_data.buffer = s_srm_cfg.out.buffer;
    in.raw_data.len    = SCALED_BYTES;
    esp_h264_err_t er  = esp_h264_enc_process(s_enc, &in, out);  // Ask the encoder to fill it
    // Check for encoder errors
    if (er != ESP_H264_ERR_OK) {
      ESP_LOGE(TAG, "[%s] H264 process failed (%d)", pcTaskGetName(NULL), (int)er);
      xQueueSendToBack(s_free_encoded_q, &out, portMAX_DELAY);
      /// TODO: Handle errors
      // Print stream information every second
      if (esp_timer_get_time() - now > 1000000ULL) {
        esp_h264_enc_hw_get_param_hd(s_enc, &param_hd);
        esp_h264_enc_get_bitrate(&param_hd->base, &set_bitrate);
        esp_h264_enc_get_fps(&param_hd->base, &set_fps);
        ESP_LOGI(TAG, "Bitrate = %lld bps = %lld kB/s, Set bitrate= %ld bps, FPS=%d, Set FPS=%d",
                 encoded * 8, encoded >> 10, set_bitrate, frames_per_second, set_fps);
        encoded = frames_per_second = 0;
      encoded += out->length;
      frames_per_second++;
      // Send the encoded buffer to the queue to be written to the staging buffer
      ESP_LOGV(TAG, "[%s] Sending buffer to s_filled_encoded_q", pcTaskGetName(NULL));
      xQueueSendToBack(s_filled_encoded_q, &out, portMAX_DELAY);
    frame_idx++;
    ESP_LOGV(TAG, "[%s] Loop done, back to the beginning", pcTaskGetName(NULL));
PPA configuration
static ppa_srm_oper_config_t s_srm_cfg = {
    .in.pic_h           = VRES,
    .in.pic_w           = HRES,
    .in.block_h         = VRES,
    .in.block_w         = HRES,
    .in.block_offset_x  = 0,
    .in.block_offset_y  = 0,
    .in.srm_cm          = PPA_SRM_COLOR_MODE_YUV420,
    .out.pic_h          = 480,
    .out.pic_w          = 640,
    .out.buffer_size    = SCALED_BYTES,
    .out.block_offset_x = 0,
    .out.block_offset_y = 0,
    .out.srm_cm         = PPA_SRM_COLOR_MODE_YUV420,
    .rotation_angle     = PPA_SRM_ROTATION_ANGLE_0,
    .rgb_swap           = 0,
    .byte_swap          = 0,
    .mode               = PPA_TRANS_MODE_NON_BLOCKING,
    .scale_x            = 0.5,
    .scale_y            = 0.5,
try_except
Re: MIPI->ISP->PPA->H264->SD Card pipeline performance
Postby try_except » Wed Nov 19, 2025 2:24 pm
I added logging in between steps and found that scaling takes around five times more time than encoding:
V (152431) Video Manager: [vman.capture.lo] Scaling
V (152481) Video Manager: [vman.capture.lo] PPA scaling done
V (152481) Video Manager: [vman.capture.lo] Encoding
V (152491) Video Manager: [vman.capture.lo] Encoding done
Is this reasonable? I know logging adds a lot of overhead (FPS dropped to 11) so it's not exactly five times slower, but still feels like it shouldn't take so much.
Users browsing this forum: Google [Bot], Semrush [Bot] and 1 guest
