Which toolchain was used to obtain the Coremark scores in the ESP32-C6 and H2 datasheets??
Xliver
Postby Xliver » Thu Nov 20, 2025 2:54 am
I noticed ESP32-C6 and H2 scored 3.10 and 3.16 Coremark/MHz in datasheets.
I want to know which toolchain was used in this performance test.
Is GCC12 or GCC14? Seems IAR also support ESP32, maybe conducted by IAR? :?:
Xliver
Re: Which toolchain was used to obtain the Coremark scores in the ESP32-C6 and H2 datasheets??
Postby Xliver » Wed Dec 10, 2025 7:00 am
Does anyone know the toolchain version?
lichurbagan
Postby lichurbagan » Thu Dec 11, 2025 11:29 am
Espressif likely used its standard ESP-IDF toolchain for the ESP32-C6 and H2 CoreMark scores. The datasheets do not name a compiler. The company normally builds CoreMark with its own IDF setup. That setup uses the official RISC-V GCC cross toolchain. IAR support exists but is not used for these runs. Espressif maintains a CoreMark port inside ESP-IDF. The port includes tuned flags for performance. That makes it the probable source of the published scores. The toolchain version is not stated. It depends on the IDF release used. Espressif updates GCC versions across IDF releases.
Users browsing this forum: Amazon [Bot], ChatGPT-User, Google [Bot], PerplexityBot, Qwantbot and 1 guest
