Hi everyone,
I recently bought an ESP32-CAM module from an online store, and I found it quite interesting because unlike the traditional ESP32-CAM boards (which require an external USB-to-TTL programmer), this one actually comes with an onboard Micro USB port and a CH340 USB-to-serial converter.
It’s definitely more convenient, but I haven’t been able to find the schematic for this particular board.
Does anyone have the schematic or know where I can find it?
Thanks in advance!
Got an ESP32-CAM with USB & CH340—Does Anyone Have the Schematic?
rifat.projects
nopnop2002
- Contact:
Re: Got an ESP32-CAM with USB & CH340—Does Anyone Have the Schematic?
There are several CAM boards that use the CH340 USB-serial converter.
Can you post photos?
rifat.projects
nopnop2002
- Contact:
Schematic is here.
https://drive.google.com/file/d/1Qy1myk ... sp=sharing
The camera connection will likely be the same as that of the Ai Thinker ESP32Cam.
Be careful of the cameras on board.
'OV2640' supports 'PIXFORMAT_JPEG', while 'OV7670' is compatible with 'PIXFORMAT_RGB565'.
#define CAM_PIN_PWDN 32
#define CAM_PIN_RESET -1 //software reset will be performed
#define CAM_PIN_XCLK 0
#define CAM_PIN_SIOD 26
#define CAM_PIN_SIOC 27
#define CAM_PIN_D7 35 // Y9
#define CAM_PIN_D6 34 // Y8
#define CAM_PIN_D5 39 // Y7
#define CAM_PIN_D4 36 // Y6
#define CAM_PIN_D3 21 // Y5
#define CAM_PIN_D2 19 // Y4
#define CAM_PIN_D1 18 // Y3
#define CAM_PIN_D0 5 // Y2
#define CAM_PIN_VSYNC 25
#define CAM_PIN_HREF 23
#define CAM_PIN_PCLK 22
rifat.projects
Oh!!! Nice this look quite convincing!
Users browsing this forum: Amazon [Bot], Bing [Bot], Bytespider, ChatGPT-User, Google [Bot] and 1 guest
