Unstable 50% Duty Cycle using LEDC on ESP32-C2
shai_tpl
Postby shai_tpl » Tue Nov 25, 2025 11:04 am
We are interested in generating multiple various high frequency clocks using ESP32-C2. We tried using different methods and currently stopped at using the LEDC (LED Control) peripheral to generate the output clocks.
Our implementation is as follows (and uses ESP-IDF V5.4.0):
set_frequence(ledc_timer_w, LEDC_TIMER_W, LEDC_CHANNEL, freq);
void set_frequence(ledc_timer_config_t number_conn, ledc_timer_t number_timer, ledc_channel_t number_channel, int freq_q)
ESP_ERROR_CHECK(ledc_timer_config(&number_conn));
ESP_ERROR_CHECK(ledc_set_duty(LEDC_MODE, number_channel, LEDC_DUTY));
ESP_ERROR_CHECK(ledc_set_freq(LEDC_MODE, number_timer, freq_q));
ESP_ERROR_CHECK(ledc_update_duty(LEDC_MODE, number_channel));
At some frequencies, such as 5 MHz and 10 MHz, we are able to generate a stable output with a 50% duty cycle.
However, at other frequencies, the duty cycle becomes unstable and fluctuates around 50%.
1. Is our implementation correct for generating high-frequency signals using the LEDC peripheral?
2. Is it technically possible to use the LEDC peripheral to generate frequencies in the 1 MHz – 20 MHz range with a stable 50% duty cycle?
If not, what would be the recommended alternative method or peripheral for generating such frequencies?
3. What is the maximum achievable frequency on the ESP32-C2 that can maintain a precise 50% duty cycle using LEDC or any other method?
Thanks in advance.
MicroController
Re: Unstable 50% Duty Cycle using LEDC on ESP32-C2
Postby MicroController » Fri Nov 28, 2025 12:43 pm
ESP8684 TRM v1.3, "22.3.2.2 Clock Divider Configuration":
[Depending on the configured PWM frequency,] LEDC_CLK_DIV becomes a non-integer divisor. The [LEDC's] clock divider implements non-integer frequency division by alternating between A and (A+1) LEDC_CLKx clock pulses per ref_pulsex clock pulse. This will result in the average frequency of ref_pulsex clock pulse being the desired frequency
Users browsing this forum: ChatGPT-User, Google [Bot], Semrush [Bot] and 1 guest
