Flashing ESP32 with another ESP32
larsli
Postby larsli » Mon Dec 01, 2025 1:37 pm
i want to flash an ESP32-WROOM-32UE (Target) with another ESP32-WROOM-32UE (Host) over a serial connection (Serial1 Host).
I connected both with eachother like following:
Host | Target
Rx1 | Tx0
Tx1 | Rx0
IO25 | En
IO26 | IO0 (Reset)
My programm works like following:
1. Set Target into bootloader mode with (EN and IO0) (Working)
2. Send SYNC to the bootloader (no response from Target)
3. Send FLASH_BEGIN
4. Sending FLASH_DATA
5. Send FLASH_END
I have the problem that the bootloader isn't answering to my SYNC-paket. I used the espressif dokumentation for communikation [https://docs.espressif.com/projects/esp ... tocol.html] with the bootloader and tried to adapt it into the Arduino IDE. I also checked the communication when im flashing an ESP32 with the Arduino IDE and it looks the same besides the checksum bytes are all "0x00". (I tried both checksum variants and both didn't work)
The SYNC-paket looks like this:
0xc0 0x0 0x8 0x24 0x0 0x20 0x0 0x0 0x0 0x7 0x7 0x12 0x20 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0xc0
// --------- Konfiguration ---------
// Programmer UART → Target-ESP32
#define TX_PIN 17
#define RX_PIN 16
// Bootloder Pins
#define EN_PIN   25  // Reset Pin for Targets
#define GPIO0_PIN 26 // Bootloader Pin for Targets
// Firmware Dummy
#define FW_SIZE 4096
uint8_t firmware[FW_SIZE];
void setup()
  Serial1.begin(115200, SERIAL_8N1, RX_PIN, TX_PIN);
  pinMode(EN_PIN, OUTPUT);
  pinMode(GPIO0_PIN, OUTPUT);
  // Dummy-Firmware
  for(int i=0;i<FW_SIZE;i++) firmware[i] = i & 0xFF;
  Serial.println("ESP32 Programmer starting...");
  //set Target into Bootloader-mode
  enterBootloader();
  //Bootloader SYNC
  if(!ESPsync()) { Serial.println("SYNC failed"); return; }
  //FLASH_BEGIN
  if(!flashBegin(FW_SIZE, 0x10000)) { Serial.println("FLASH_BEGIN failed"); return; }
  //FLASH_DATA
  if(!flashData()) { Serial.println("FLASH_DATA failed"); return; }
  //FLASH_END
  if(!flashEnd()) { Serial.println("FLASH_END failed"); return; }
  Serial.println("Flashing completed!");
void loop() {}
// Bootloader-Modus
void enterBootloader() {
  Serial.println("Setting Target into Bootloader mode...");
  digitalWrite(GPIO0_PIN, LOW);
  digitalWrite(EN_PIN, LOW);
  delay(100);
  digitalWrite(EN_PIN, HIGH);
  delay(200);
  digitalWrite(GPIO0_PIN, HIGH);
//SYNC
bool ESPsync()
  Serial.println("SYNC...");
  const uint8_t payloadLen = 36;
  uint8_t payload[payloadLen + 1];  //payload + 0xC0
  // Checksum: 0xEF XOR Payload Bytes
  uint32_t checksum = 0xEF;
  for(int i=0;i<payloadLen;i++) checksum ^= payload[i];
  //Header
  uint8_t header[9];
  header[0] = 0xc0;
  header[1] = 0x00;
  header[2] = 0x08; // SYNC command
  header[3] = 0x24;
  header[4] = 0x00;
  header[5] = checksum;
  header[6] = (checksum >> 8) & 0xFF;
  header[7] = (checksum >> 16) & 0xFF;
  header[8] = (checksum >> 24) & 0xFF;
  // Payload: 0x07 0x07 0x12 0x20 + Padding 0x55 x 32
  payload[0] = 0x07;
  payload[1] = 0x07;
  payload[2] = 0x12;
  payload[3] = 0x20;
  for(int i=4;i<payloadLen;i++) payload[i] = 0x55;
  payload[payloadLen] = 0xc0;           //End with 0xC0
  // RX-Puffer clear
  while(Serial1.available()) Serial.printf("Bootloader Message: %02X\n", Serial1.read());
  Serial.println("Sending SYNC packets...");
  // send SYNC 8x
  for(int i=0;i<8;i++){
    Serial1.write(header,9);
    Serial1.write(payload,payloadLen+1);
    Serial1.flush();
    delay(50);
  // wait 2 secounds for response
  unsigned long t0 = millis();
  while(millis()-t0 < 2000)
    if(Serial1.available())
      uint8_t b = Serial1.read();
      Serial.print("Bootloader Rx: 0x");      //print incomming data to test for a response
      Serial.println(b, HEX);
      //return true;      //ESP32 response to SYNC
  return false;
MicroController
Re: Flashing ESP32 with another ESP32
Postby MicroController » Sun Dec 07, 2025 11:25 pm
You may want to have a look at (or use) the esp-serial-flasher (IDF) library.
Users browsing this forum: Google [Bot], Qwantbot and 2 guests
