esp32s3 桥接和4g联网问题
cjs123456
esp32s3 桥接和4g联网问题
Postby cjs123456 » Sat Dec 06, 2025 3:22 am
使用esp32s3,wifi和网口桥接后,添加了一个4g模块,用于给wifi上网,dns给了桥接接口,nat使用的是桥接接口的ip,运营商已经给ppp分配ip了,dns addr是211.138.21.66,wifi无法上网
lichurbagan
Re: esp32s3 桥接和4g联网问题
Postby lichurbagan » Mon Dec 08, 2025 5:53 pm
PPP 有自己的 DNS(运营商下发的),桥接接口设置独立 DNS 可能会导致冲突。
一般 PPP 报告得到的 DNS 更可靠,你可以用:
esp_netif_get_dns_info(ppp_netif, ESP_NETIF_DNS_MAIN, &dns);
esp_netif_set_dns_info(wifi_netif, ESP_NETIF_DNS_MAIN, &dns);
不要手动写死 DNS,除非确认无效。
cjs123456
Postby cjs123456 » Thu Dec 11, 2025 9:31 am
我这里只有get_dns_info变量才会修改,下面是我的log
Executing action: monitor
Serial port COM7
Connecting....
Detecting chip type... ESP32-S3
Running idf_monitor in directory D:\esp32_code\2025-9-04-16-00esp32-S3-wifi\esp32-S3-wifi
Executing "D:\software\Espressif\python_env\idf5.4_py3.11_env\Scripts\python.exe D:/software/Espressif/frameworks/esp-idf-v5.4.1/tools/idf_monitor.py -p COM7 -b 115200 --toolchain-prefix xtensa-esp32s3-elf- --target esp32s3 --revision 0 D:\esp32_code\2025-9-04-16-00esp32-S3-wifi\esp32-S3-wifi\build\esp32-S3-wifi.elf --force-color -m 'D:\software\Espressif\python_env\idf5.4_py3.11_env\Scripts\python.exe' 'D:/software/Espressif/frameworks/esp-idf-v5.4.1/\tools\idf.py'"...
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce2820,len:0x170c
load:0x403c8700,len:0x4
load:0x403c8704,len:0xec4
load:0x403cb700,len:0x318c
entry 0x403c8950
I (27) boot: ESP-IDF v5.4.1-dirty 2nd stage bootloader
I (27) boot: compile time Dec 9 2025 14:58:15
I (27) boot: Multicore bootloader
I (28) boot: chip revision: v0.2
I (30) boot: efuse block revision: v1.3
I (34) qio_mode: Enabling default flash chip QIO
I (38) boot.esp32s3: Boot SPI Speed : 80MHz
I (42) boot.esp32s3: SPI Mode : QIO
I (46) boot.esp32s3: SPI Flash Size : 4MB
I (50) boot: Enabling RNG early entropy source...
I (54) boot: Partition Table:
I (57) boot: ## Label Usage Type ST Offset Length
I (63) boot: 0 nvs WiFi data 01 02 00009000 00004000
I (70) boot: 1 otadata OTA data 01 00 0000d000 00002000
I (76) boot: 2 phy_init RF data 01 01 0000f000 00001000
I (83) boot: 3 factory factory app 00 00 00010000 00100000
I (89) boot: 4 ota_0 OTA app 00 10 00110000 00100000
I (96) boot: 5 ota_1 OTA app 00 11 00210000 00100000
I (102) boot: End of partition table
I (106) boot: Defaulting to factory image
I (109) esp_image: segment 0: paddr=00010020 vaddr=3c0b0020 size=29948h (170312) map
I (142) esp_image: segment 1: paddr=00039970 vaddr=3fca2f00 size=04ec8h ( 20168) load
I (146) esp_image: segment 2: paddr=0003e840 vaddr=40378000 size=017d8h ( 6104) load
I (147) esp_image: segment 3: paddr=00040020 vaddr=42000020 size=adad4h (711380) map
I (259) esp_image: segment 4: paddr=000edafc vaddr=403797d8 size=19678h (104056) load
I (279) esp_image: segment 5: paddr=0010717c vaddr=600fe100 size=0001ch ( 28) load
I (289) boot: Loaded app from partition at offset 0x10000
I (290) boot: Disabling RNG early entropy source...
I (300) esp_psram: Found 2MB PSRAM device
I (300) esp_psram: Speed: 40MHz
I (300) cpu_start: Multicore app
I (719) esp_psram: SPI SRAM memory test OK
I (728) cpu_start: Pro cpu start user code
I (728) cpu_start: cpu freq: 240000000 Hz
I (728) app_init: Application information:
I (728) app_init: Project name: esp32-S3-wifi
I (732) app_init: App version: 1
I (735) app_init: Compile time: Dec 10 2025 16:52:15
I (741) app_init: ELF file SHA256: df5063c2e...
I (745) app_init: ESP-IDF: v5.4.1-dirty
I (749) efuse_init: Min chip rev: v0.0
I (753) efuse_init: Max chip rev: v0.99
I (757) efuse_init: Chip rev: v0.2
I (761) heap_init: Initializing. RAM available for dynamic allocation:
I (767) heap_init: At 3FCAD2C8 len 0003C448 (241 KiB): RAM
I (772) heap_init: At 3FCE9710 len 00005724 (21 KiB): RAM
I (777) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM
I (783) heap_init: At 600FE11C len 00001ECC (7 KiB): RTCRAM
I (788) esp_psram: Adding pool of 2048K of PSRAM memory to heap allocator
I (795) spi_flash: detected chip: generic
I (798) spi_flash: flash io: qio
I (801) sleep_gpio: Configure to isolate all GPIO pins in sleep state
I (807) sleep_gpio: Enable automatic switching of GPIO sleep configuration
I (814) main_task: Started on CPU0
I (838) esp_psram: Reserving pool of 32K of internal memory for DMA/internal allocations
I (838) main_task: Calling app_main()
I (839) gpio: GPIO[9]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (859) ------------: ETHIP:192.168.4.1
I (859) ------------: ETHIP:192.168.1.101
I (892) pp: pp rom version: e7ae62f
I (892) net80211: net80211 rom version: e7ae62f
I (894) wifi:wifi driver task: 3fcc1ec8, prio:23, stack:6656, core=0
I (899) wifi:wifi firmware version: 79fa3f41ba
I (900) wifi:wifi certification version: v7.0
I (903) wifi:config NVS flash: enabled
I (906) wifi:config nano formatting: disabled
I (910) wifi:Init data frame dynamic rx buffer num: 64
I (915) wifi:Init static rx mgmt buffer num: 5
I (919) wifi:Init management short buffer num: 32
I (924) wifi:Init dynamic tx buffer num: 64
I (928) wifi:Init static tx FG buffer num: 2
I (932) wifi:Init static rx buffer size: 1600
I (936) wifi:Init static rx buffer num: 16
I (940) wifi:Init dynamic rx buffer num: 64
I (944) wifi_init: rx ba win: 32
I (946) wifi_init: accept mbox: 6
I (949) wifi_init: tcpip mbox: 64
I (953) wifi_init: udp mbox: 64
I (955) wifi_init: tcp mbox: 64
I (958) wifi_init: tcp tx win: 65535
I (962) wifi_init: tcp rx win: 65535
I (965) wifi_init: tcp mss: 1440
I (968) wifi_init: WiFi IRAM OP enabled
I (971) wifi_init: WiFi RX IRAM OP enabled
I (976) phy_init: phy_version 700,8582a7fd,Feb 10 2025,20:13:11
I (1040) wifi:mode : sta (b8:f8:62:d8:dc:90)
I (1040) wifi:enable tsf
I (4841) wifi:flush txq
I (4841) wifi:stop sw txq
I (4841) wifi:lmac stop hw txq
I (4843) modem_board: iot_usbh_modem, version: 1.2.0
I (4843) modem_board: Force reset modem board....
I (4846) gpio: GPIO[0]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (4855) modem_board: Resetting modem using io=0, level=0
I (5060) modem_board: Waiting for modem initialize ready
I (10060) USBH_CDC: iot usbh cdc version: 2.0.1
base_ret 1
I (10090) esp-modem: --------- Modem PreDefined Info ------------------
I (10090) esp-modem: Model: User Defined
I (10090) esp-modem: Modem itf 2
I (10093) esp-modem: ----------------------------------------------------
Found NOTIF endpoint: 136
Found IN endpoint: 129
Found OUT endpoint: 10
*** Device descriptor ***
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0xef
bDeviceSubClass 0x2
bDeviceProtocol 0x1
bMaxPacketSize0 64
idVendor 0x2ecc
idProduct 0x3012
bcdDevice 1.00
iManufacturer 1
iProduct 2
iSerialNumber 3
bNumConfigurations 1
*** Configuration descriptor ***
bLength 9
bDescriptorType 2
wTotalLength 196
bNumInterfaces 5
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
bMaxPower 500mA
*** Interface Association Descriptor ***
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 0xe0
bFunctionSubClass 0x1
bFunctionProtocol 0x3
iFunction 5
*** Interface descriptor ***
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 0xe0
bInterfaceSubClass 0x1
bInterfaceProtocol 0x3
iInterface 5
*** Endpoint descriptor ***
bLength 7
bDescriptorType 5
bEndpointAddress 0x87 EP 7 IN
bmAttributes 0x3 INT
wMaxPacketSize 64
bInterval 16
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 0xa
bInterfaceSubClass 0x0
bInterfaceProtocol 0x0
iInterface 5
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 0x2 BULK
wMaxPacketSize 64
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0xc EP 12 OUT
wMaxPacketSize 64
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 0xff
iInterface 8
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
wMaxPacketSize 64
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0xb EP 11 OUT
wMaxPacketSize 64
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 3
iInterface 11
bLength 7
bDescriptorType 5
bEndpointAddress 0x89 EP 9 IN
wMaxPacketSize 64
bInterval 16
bLength 7
bDescriptorType 5
bEndpointAddress 0x86 EP 6 IN
wMaxPacketSize 64
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0xf EP 15 OUT
wMaxPacketSize 64
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 3
iInterface 11
bLength 7
bDescriptorType 5
bEndpointAddress 0x88 EP 8 IN
wMaxPacketSize 64
bInterval 16
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
wMaxPacketSize 64
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0xa EP 10 OUT
wMaxPacketSize 64
bInterval 0
bit 0100
I (10778) modem_board: DTE reconnect, reconnecting ...
I (10783) USBH_CDC: Opened cdc device: 1
I (10786) USBH_CDC: New device connected, address: 1
I (11783) modem_board: reconnect after 5s...
I (12783) modem_board: reconnect after 4s...
I (13783) modem_board: reconnect after 3s...
I (14783) modem_board: reconnect after 2s...
I (15783) modem_board: reconnect after 1s...
I (15783) modem_board: Modem state STAGE_SYNC, Start
modem_stage 1
I (15803) modem_board: Network Auto reconnecting ...
I (15803) modem_board: Modem state STAGE_SYNC, Success!
bit 0200
I (15904) modem_board: Modem state STAGE_CHECK_SIM, Start
modem_stage 3
I (15910) modem_board: SIM Card Ready
I (15910) modem_board: Modem state STAGE_CHECK_SIM, Success!
bit 0200
I (16010) modem_board: Modem state STAGE_CHECK_SIGNAL, Start
modem_stage 4
I (16016) modem_board: Signal quality: rssi=21, ber=99
I (16016) modem_board: Modem state STAGE_CHECK_SIGNAL, Success!
bit 0200
I (16117) modem_board: Modem state STAGE_CHECK_REGIST, Start
modem_stage 5
I (16123) modem_board: Network registered, Operator: "CHINA MOBILE"
I (16123) modem_board: Modem state STAGE_CHECK_REGIST, Success!
bit 0200
I (16225) modem_board: Modem state STAGE_START_PPP, Start
modem_stage 6
I (16236) modem_board: Modem state STAGE_START_PPP, Success!
bit 0200
I (16336) modem_board: Modem state STAGE_WAIT_IP, Start
modem_stage 7
W (16336) modem_board: Modem event! 0
I (18088) esp-netif_lwip-ppp: Connected
I (18089) modem_board: IP event! 6
I (18089) modem_board: Modem Connected to PPP Server
I (18089) modem_board: ppp ip: 10.11.23.141, mask: 255.255.255.255, gw: 10.64.64.64
I (18096) modem_board: Main DNS: 211.138.21.66
I (18100) modem_board: Backup DNS: 211.138.23.66
I (18105) modem_board: Modem state STAGE_WAIT_IP, Success!
I (18105) esp-modem-netif: PPP state changed event 0: (NETIF_PPP_ERRORNONE)
I (18117) esp_eth.netif.netif_glue: dc:32:62:61:8a:e8
I (18121) esp_eth.netif.netif_glue: ethernet attached to netif
I (18128) esp_netif_lwip: DHCP server esp_netif->ip_info 192.168.1.101
I (18133) esp_netif_lwip: DHCP server esp_netif->ip_info 192.168.1.1
I (18140) esp_netif_br_glue: b8:f8:62:d8:dc:93
I (18143) esp_netif_br_glue: bridge netif glue attached
I (18149) esp_netif_lwip: DHCP server esp_netif->ip_info 192.168.4.1
I (18155) esp_netif_lwip: DHCP server esp_netif->ip_info 192.168.4.1
bridgeif does not need tcpip_input, use netif_input/ethernet_input instead
I (18163) wifi:mode : softAP (b8:f8:62:d8:dc:91)
I (18172) wifi:Total power save buffer number: 32
I (18176) wifi:Init max length of beacon: 752/752
I (18181) wifi:Init max length of beacon: 752/752
I (18185) wifi:Set ps type: 0, coexist: 0
I (18186) esp_netif_lwip: DHCP server started on interface WIFI_AP_DEF with IP: 192.168.4.1
I (18198) RS485: Start RS485 application test and configure UART.
I (18203) uart: ESP_INTR_FLAG_IRAM flag not set while CONFIG_UART_ISR_IN_IRAM is enabled, flag updated
I (18213) esp_netif_lwip: DHCP server esp_netif->ip_info 192.168.4.1
I (18218) esp_netif_lwip: DHCP server esp_netif->ip_info 192.168.4.1
I (20164) esp_netif_lwip: DHCP server esp_netif->ip_info 192.168.1.101
I (23889) wifi:new:<11,2>, old:<11,2>, ap:<11,2>, sta:<255,255>, prof:11, snd_ch_cfg:0x0
I (23889) wifi:station: 42:6c:98:88:2d:5f join, AID=1, bgn, 40D
net ap 17082560
net br 1694607552
net en 0
net pp 2367097610
net lo 16777343
I (23900) modem_wifi: NAT is enabled
I (24145) wifi:<ba-add>idx:2 (ifx:1, 42:6c:98:88:2d:5f), tid:7, ssn:0, winSize:64
I (24148) wifi:<ba-add>idx:3 (ifx:1, 42:6c:98:88:2d:5f), tid:0, ssn:2, winSize:64
I (24165) esp_netif_lwip: DHCP server assigned IP to a client, IP is: 192.168.1.103
I (24165) modem_board: IP event! 2
I (24170) IP_CONNECT: IP_CONNECT
I (24457) esp_netif_lwip: DHCP server assigned IP to a client, IP is: 192.168.1.102
I (24457) modem_board: IP event! 2
Users browsing this forum: Applebot, Bytespider and 3 guests
