Hello!
Recently I noticed that my code which uses light sleep stopped to work: CPU goes to the light sleep but not going back.
I tried all wakeup sources but it don't wake up.
Even more: board becomes unresponsive so I can not reflash it with esptool! Have to press "reset" button.
Anybody experience this problem? It is ESP32-S3 with PSRAM. Arduino framework. All I do is: set up wakeup source (timer, 5 seconds) and call light_sleep_start(). The same setup with deep sleep works (when I replace light_sleep_start with deep_sleep_start).
This code was written I worked as expected for last few months until recent upgrade (new ESP-IDF).
PS: Happens ONLY when USB-CDC is used as a console. When it is UART0 it all works. Looks like USB-CDC dies after entering light sleep
light sleep, can't wake up
lichurbagan
Re: light sleep, can't wake up
This is a known ESP-IDF regression on the ESP32-S3. Light sleep now shuts down USB-CDC clocks. USB dies and the chip cannot wake. Deep sleep works because it fully resets USB. UART0 works because it stays powered. Workarounds are simple. Disable peripheral power-down, keep USB clocks alive, or switch your console to UART0. Rolling back the ESP32 Arduino core also fixes it.
Thank you very much!This is a known ESP-IDF regression on the ESP32-S3......Disable peripheral power-down, keep USB clocks alive
Thanks!
Slava.
Slava.
Should I make changes to ESP-IDF for that or there is an API to select which peri should be down and which are up?Disable peripheral power-down, keep USB clocks alive
Thanks!
Thanks!
Slava.
Slava.
