Custom esp8266 board with error: A fatal error occurred: (Failed to connect to ESP8266: Timed out waiting for packet hea
theshbbl
Postby theshbbl » Sat Dec 13, 2025 9:19 am
Hi, I designed recently a custom esp8266 (ESP12E) with usb-c (used ch340c) that controls multiple triacs via optoisolators. My question is when I try uploading code into the custom pcb the output keep saying Connecting…._…. and in the end it says A fatal error occurred: Failed to connect to ESP8266: Timed out waiting for packet header. The below image is the schematic I hope someone could figure out any missing/wrong connections.
Edit: When I connected gpio15 and gpio0 to gnd it won't flash either but it got connected to HTerm (standalone serial monitor program)
after pressing RTS the output is
ets Jan  8 2013,rst cause:2, boot mode:(3,6)
load 0x40100000, len 1856, room 16
tail 0
chksum 0x63
load 0x3ffe8000, len 776, room 8
tail 0
chksum 0x02
load 0x3ffe8310, len 552, room 8
tail 0
chksum 0x79
csum 0x79
2nd boot version : 1.5
  SPI Speed      : 40MHz
  SPI Mode       : DIO
  SPI Flash Size & Map: 32Mbit(512KB+512KB)
jump to run user1 @ 1000
rf cal sector: 1017
rf\[112\] : 00
rf\[113\] : 00
rf\[114\] : 01
SDK ver: 1.5.4.1(39cb9a32) compiled @ Jul  1 2016 20:04:35
phy ver: 972, pp ver: 10.1
)<\\f>‚ÐQéP1,ŠYÊY<15>'<3>)§Ã<\\b>)ÍPí<2>ü
SW1 with DTR outputs
<\r><\n> ets Jan 8 2013,rst cause:2, boot mode:(1,7)<\r><\n><\r><\n>
connecting gpio0 to gnd with RTS shows
<\r><\n> ets Jan 8 2013,rst cause:2, boot mode:(1,6)<\r><\n><\r><\n>
my schematic:
