Precision Resistance Measurement on 40-pin Cable Tester (ESP32 / 3.3V)
Honzaa
Postby Honzaa » Wed Dec 17, 2025 10:44 am
Hi everyone,
I am building a universal cable tester using an ESP32 (3.3V logic/power).
The continuity and short-circuit testing is fully functional using 5x MCP23017 I/O expanders to handle 40 pins.
The Goal:
I want to add resistance measurement to detect degraded contacts or bad solders (mΩ to Ω range), while sticking to 3.3V and limited GPIOs.
Proposed Architecture:
Since a full 4-wire Kelvin setup for 40 pins is too complex, I am considering a 2-wire method with software calibration (tare):
1. Routing: 2 sets of CD74HC4067 (16-ch Analog Mux) to select Source/Sink pins, controlled by an MCP23017.
2. Injection: 10mA Constant Current Source (OpAmp + MOSFET @ 3.3V).
3. Measurement:ADS1115 (16-bit I2C ADC) in differential mode across the Mux inputs.
My Questions:
1. Mux R(on) At 3.3V, the CD74HC4067 has a significant R(on) (~70Ω). Do you think software calibration (subtracting the path resistance) is enough to get reliable readings, or will thermal drift make it useless for measuring low resistances?
2. Alternatives: Are there any affordable I2C Crosspoint Switches suitable for this (40 pins, low R(on) that I might have missed?
I need something for make measure inside the cable that i test
Thanks for your insights!
itsbebbo
Re: Precision Resistance Measurement on 40-pin Cable Tester (ESP32 / 3.3V)
Postby itsbebbo » Sun Jul 05, 2026 3:48 pm
Very late response, but did you look at the MAX14661? Very low on resistance, 16 : 2 analog mux.
Users browsing this forum: Amazon [Bot], ChatGPT-User, Semrush [Bot] and 3 guests
