Help on connecting ESP32 to 64*32 hub75 led matrix
drdomert
Postby drdomert » Sun Dec 21, 2025 7:05 pm
Hi!
I have a project where i want to connect my ESP32 to a HUb75 led matrix. The matrix will be powered by a 5V 6A power supply. What i would like help with is if it is enough to connect the matrix to the power source, and the matrix to the ESP32 (using a ribbon band with jumper wires in one end).
Or do i also need a cable from - on the power source to a GND pin on the ESP32? There will be a common ground from GND pin on the matrix to GND pin on ESP32, but is that enough? I am just trying to figure out how to make the connections as easy as possible.
Thanks in advance.
drdomert
Re: Help on connecting ESP32 to 64*32 hub75 led matrix
Postby drdomert » Tue Dec 23, 2025 10:03 pm
I can answer my own question now if anyone wonders in the future: no, it is enough with the internal GND from matrix to ESP32. After some ups and down i managed to get the matrix to work and just managed to play breakout on it from my phone.
Users browsing this forum: PetalBot and 2 guests
