The call to esp_sntp_setservername does not seem to work.
MickPF
Postby MickPF » Thu Jan 01, 2026 4:14 pm
I wrote the following code (snippet):
            /* Initialize and start SNTP client */
            if (cfg->client.sntp.server_no >= 1)
                esp_sntp_setoperatingmode(ESP_SNTP_OPMODE_POLL);
                esp_sntp_config_t sntp_config = ESP_NETIF_SNTP_DEFAULT_CONFIG(cfg->client.sntp.server[0]);
                sntp_config.sync_cb = time_sync_event_handler;
                sntp_config.start = false;
                esp_netif_sntp_init(&sntp_config);
                sntp_set_sync_interval(cfg->client.sntp.interval * 1000);
                sntp_set_sync_status(SNTP_SYNC_STATUS_RESET);
                for (i = 1; i < cfg->client.sntp.server_no; i++)
                    esp_sntp_setservername(i, cfg->client.sntp.server[i]);
                esp_netif_sntp_start();
            for (i = 0; i < cfg->client.sntp.server_no; i++)
                char const   *name;
                name = esp_sntp_getservername(i);
                ESP_LOGI(MODULE_TAG, "NTP server no. %d : %s", i, (name == NULL) ? "<NULL>" : name);
My server array contains two entries: "pool.ntp.org" and "time.microsoft.com" and the field cfg->client.sntp.server_no = 2.
Executing this code outputs:
I (3556) WIFI: NTP server no. 0 : pool.ntp.org
I (3566) WIFI: NTP server no. 1 : <NULL>
Is something wrong in my code? Is the order of esp_??? calls wrong?
Thanks in advance,
Michael
nopnop2002
Contact:
Re: The call to esp_sntp_setservername does not seem to work.
Postby nopnop2002 » Fri Jan 02, 2026 8:31 am
                //for (i = 1; i < cfg->client.sntp.server_no; i++)
MickPF
Postby MickPF » Fri Jan 02, 2026 10:38 am
First, I would like to point out that I use the following command to specify the first server:
I tried your suggestion, and it leads to the same result:
I (3387) WIFI: NTP server no. 0 : pool.ntp.org
I (3387) WIFI: NTP server no. 1 : <NULL>
I also tried using the macro
ESP_NETIF_SNTP_DEFAULT_CONFIG_MULTIPLE
, but it didn't work either!
MickPF
Postby MickPF » Fri Jan 02, 2026 10:40 am
nopnop2002
Contact:
Postby nopnop2002 » Fri Jan 02, 2026 11:34 am
                //esp_sntp_config_t sntp_config = ESP_NETIF_SNTP_DEFAULT_CONFIG(cfg->client.sntp.server[0]);
                esp_sntp_config_t sntp_config = ESP_NETIF_SNTP_DEFAULT_CONFIG_MULTIPLE(2,
                               ESP_SNTP_SERVER_LIST("ntp.nict.jp", "pool.ntp.org" ) );
MickPF
Postby MickPF » Fri Jan 02, 2026 1:06 pm
I'd like to end this discussion!
As I said, I'm perfectly happy with a sector size of 4096 bytes, and I have neither the time nor the inclination to play with all sorts of settings and code!
MicroController
Postby MicroController » Fri Jan 02, 2026 1:16 pm
(re: viewtopic.php?t=47410#p152847 )
There's nothing to play with :)
Wear-levelling implies sector:=4096
But documentation of this could be improved.
MickPF
Postby MickPF » Fri Jan 02, 2026 1:23 pm
!!! Sorry !!!
My last post belongs to an other discussion (about the sector size of FAT partitions)!!
I used the link in the email to reply to a post, but it led me to the wrong discussion!!
!!! Sorry !!!
MickPF
Postby MickPF » Fri Jan 02, 2026 1:34 pm
Unfortunately, I can't use the macro ESP_NETIF_SNTP_DEFAULT_CONFIG_MULTIPLE because my server list isn't fixed. It can contain between one and three servers.
It's no use to me to pass this macro two fixed servers just to test whether it works in general or not. In real-world operation, this list is variable!
MicroController
Postby MicroController » Fri Jan 02, 2026 1:54 pm
You have to provide the (maximum) number of servers you want to use to esp_netif_sntp_init().
You can try
                               3,
                               ESP_SNTP_SERVER_LIST( NULL, NULL, NULL ) );
for example to ensure there's space allocated for up to 3 servers.
- Or, don't initialize SNTP at all until you know at least one server's name, or how many servers you actually want to use.
