Firecracker Serial Board Interfacing Question
Back in another lifetime, X10 designed a RF interface to their powerline controllers ... the Firecracker had 2 versions one uses a comport the other a usb ... I have a Serial Port version that still works ... wrote a C code version to work with HA (home assistant) ... but thinking this could be more useful controlled by an esp32 instead of wasting resource on a PC ... at issue is this device DOESN'T actually use traditional TX/RX serial commands ... instead ... it pulses the RTS and DTR lines to effectively send an RF signal. As a PC RS232 basically doesn't use the Negative going part of a RS232 control or TX/RX, RTS and DTR could potentially be simulated with a 0 to 5V transitions ... MY QUESTION ... how does ESP32 control the CTRL lines on any of its 3 uarts? Should I just ignore these UART Features and just select 2 available GPIO's to drive 2N3906 transistors to the 5V rail? Thanks for any insight you can provide
MicroController
Re: Firecracker Serial Board Interfacing Question
Yes, you likely cannot use the UART to generate the required protocol at all.Should I just ignore these UART Features...
Manual GPIO may be ok. If you need more speed/timing accuracy you can look into the RMT or SPI.
I think you should also be able to output one signal to two pins while having the hardware invert one of them.
Users browsing this forum: Applebot, Barkrowler, Google [Bot] and 3 guests
