So I have been researching very intensively about the ESP32-S3 Mini 1 N4R2 module and could not find a proper pinout. What pin is the safest to use to control my 8 relays, and all those 8 pins must be LOW at startup. May I know what pins have low-level glitches and high-level glitches, strapping pins, and what are not recommended to use for outputs?
my target config:
8 relays, total of 8 pins (MUST BE LOW AT STARTUP).
12 pins are just used to drive segment display (dont care if output pin glitches for a moment since it is harmless).
4 input pins for push button. BOOT and EN is not counted. pins must not interfere with boot process
2 input pins for optocoupler; pins must not interfere with boot process
GPIO 1 is used for voltage measurement.
I am very sorry for my grammar. Thankyou very much!
