ADC input minimum current
To use ADC attenuation I need to buffer the pins with voltage dividers. To minimise battery power and use highest resistances what is the minimum input current for an ESP32 analog input pin?
Re: ADC input minimum current
ADC input current will be neglible. However, to get the most accurate results from a high impedance source (like a high value voltage divider) you can add a small buffer capacitor (approx 100nF) between the ADC pin and ground.
I have a similar problem, but not for ADC.ADC input current will be neglible. However, to get the most accurate results from a high impedance source (like a high value voltage divider) you can add a small buffer capacitor (approx 100nF) between the ADC pin and ground.
I need to detect the generation of very small current, through the transistor and optocoupler to form a simple detection circuit, output about 2uA logic level. Can ESP32 be confirmed with such a low current?
Datasheet says input leakage is 50nA max, which is an order of magnitude smaller than the 2uA you have, so it should work.I have a similar problem, but not for ADC.
Users browsing this forum: Bing [Bot], Bytespider, PetalBot and 2 guests
