I’m trying to build an ESP32-based MAVLink-to-MSP bridge to use an ARK Flow optical flow sensor (MAVLink over UART) with INAV 9.0.0 via MSP (Optical Flow + Rangefinder).
Goal
ARK Flow outputs MAVLink (OPTICAL_FLOW_RAD + DISTANCE_SENSOR) over UART
ESP32 reads MAVLink and converts to:
MSP2_SENSOR_OPTIC_FLOW
MSP2_SENSOR_RANGEFINDER
INAV receives MSP over UART3 for altitude hold / position hold
Hardware
ESP32 dev board (EzSBC ESP32U-01)
TBS Lucid H7 FC running INAV 9.0.0
Issue
I cannot get Arduino IDE (2.x) to compile any sketch that includes MAVLink headers.
I installed MAVLink by Oleg Kalachev via Library Manager.
My sketchbook location is:
C:\Users\John\Documents\Arduino
MAVLink headers exist at:
C:\Users\John\Documents\Arduino\libraries\MAVLink\mavlink\common\mavlink.h
But compiling even a minimal test sketch fails with:
fatal error: mavlink/common/mavlink.h: No such file or directory
Any help would be greatly appreciated!
ESP32 MAVLink → MSP Bridge Compile Issue (MAVLink Headers Not Found)
johntbernard475
nopnop2002
- Contact:
Re: ESP32 MAVLink → MSP Bridge Compile Issue (MAVLink Headers Not Found)
An example of ESP32-based MAVLink-to-UDP bridge can be found here.
I used ESP-IDF.
https://github.com/nopnop2002/esp-idf-mavlink-monitor
I used ESP-IDF.
Users browsing this forum: Baidu [Spider], Qwantbot and 1 guest
