esp32p4 V3.1 SD卡写入速度慢
DevinKung
Postby DevinKung » Tue Mar 10, 2026 9:31 am
芯片版本:esp32p4 V3.1
ESP-IDF:V5.5.3
问题描述:
基于测试用例 \v5.5.3\esp-idf\examples\storage\sd_card\sdmmc 修改,加了一个测试SD卡写入速度的函数,发现芯片V3.1上的写入速度很慢。
现象:
同样的代码,仅在编译时配置了CONFIG_ESP32P4_SELECTS_REV_LESS_V3。在V1.0的芯片上,速度在10MB/s水平;在V3.1的芯片上,速度只有0.47MB/s。
截图:
代码:
/* SD card and FAT filesystem example.
// This example uses SDMMC peripheral to communicate with SD card.
#include <string.h>
#include <sys/unistd.h>
#include <sys/stat.h>
#include "esp_vfs_fat.h"
#include "sdmmc_cmd.h"
#include "driver/sdmmc_host.h"
#include "sd_test_io.h"
#if SOC_SDMMC_IO_POWER_EXTERNAL
#include "sd_pwr_ctrl_by_on_chip_ldo.h"
#endif
#define EXAMPLE_MAX_CHAR_SIZE    64
static const char *TAG = "example";
#define MOUNT_POINT "/sdcard"
#define EXAMPLE_IS_UHS1    (CONFIG_EXAMPLE_SDMMC_SPEED_UHS_I_SDR50 || CONFIG_EXAMPLE_SDMMC_SPEED_UHS_I_DDR50)
void test_sdcard_write_speed();
#ifdef CONFIG_EXAMPLE_DEBUG_PIN_CONNECTIONS
const char* names[] = {"CLK", "CMD", "D0", "D1", "D2", "D3"};
const int pins[] = {CONFIG_EXAMPLE_PIN_CLK,
                    CONFIG_EXAMPLE_PIN_CMD,
                    CONFIG_EXAMPLE_PIN_D0
                    #ifdef CONFIG_EXAMPLE_SDMMC_BUS_WIDTH_4
                    ,CONFIG_EXAMPLE_PIN_D1,
                    CONFIG_EXAMPLE_PIN_D2,
                    CONFIG_EXAMPLE_PIN_D3
                    #endif
const int pin_count = sizeof(pins)/sizeof(pins[0]);
#if CONFIG_EXAMPLE_ENABLE_ADC_FEATURE
const int adc_channels[] = {CONFIG_EXAMPLE_ADC_PIN_CLK,
                            CONFIG_EXAMPLE_ADC_PIN_CMD,
                            CONFIG_EXAMPLE_ADC_PIN_D0
                            ,CONFIG_EXAMPLE_ADC_PIN_D1,
                            CONFIG_EXAMPLE_ADC_PIN_D2,
                            CONFIG_EXAMPLE_ADC_PIN_D3
                            #endif
#endif //CONFIG_EXAMPLE_ENABLE_ADC_FEATURE
pin_configuration_t config = {
    .names = names,
    .pins = pins,
    .adc_channels = adc_channels,
#endif
#endif //CONFIG_EXAMPLE_DEBUG_PIN_CONNECTIONS
static esp_err_t s_example_write_file(const char *path, char *data)
    ESP_LOGI(TAG, "Opening file %s", path);
    FILE *f = fopen(path, "w");
    if (f == NULL) {
        ESP_LOGE(TAG, "Failed to open file for writing");
        return ESP_FAIL;
    fprintf(f, data);
    fclose(f);
    ESP_LOGI(TAG, "File written");
    return ESP_OK;
static esp_err_t s_example_read_file(const char *path)
    ESP_LOGI(TAG, "Reading file %s", path);
    FILE *f = fopen(path, "r");
    if (f == NULL) {
        ESP_LOGE(TAG, "Failed to open file for reading");
        return ESP_FAIL;
    char line[EXAMPLE_MAX_CHAR_SIZE];
    fgets(line, sizeof(line), f);
    fclose(f);
    // strip newline
    char *pos = strchr(line, '\n');
    if (pos) {
        *pos = '\0';
    ESP_LOGI(TAG, "Read from file: '%s'", line);
    return ESP_OK;
void app_main(void)
    esp_err_t ret;
    // Options for mounting the filesystem.
    // If format_if_mount_failed is set to true, SD card will be partitioned and
    // formatted in case when mounting fails.
    esp_vfs_fat_sdmmc_mount_config_t mount_config = {
#ifdef CONFIG_EXAMPLE_FORMAT_IF_MOUNT_FAILED
        .format_if_mount_failed = true,
#else
        .format_if_mount_failed = false,
#endif // EXAMPLE_FORMAT_IF_MOUNT_FAILED
        .max_files = 5,
        .allocation_unit_size = 16 * 1024
    sdmmc_card_t *card;
    const char mount_point[] = MOUNT_POINT;
    ESP_LOGI(TAG, "Initializing SD card");
    // Use settings defined above to initialize SD card and mount FAT filesystem.
    // Note: esp_vfs_fat_sdmmc/sdspi_mount is all-in-one convenience functions.
    // Please check its source code and implement error recovery when developing
    // production applications.
    ESP_LOGI(TAG, "Using SDMMC peripheral");
    // By default, SD card frequency is initialized to SDMMC_FREQ_DEFAULT (20MHz)
    // For setting a specific frequency, use host.max_freq_khz (range 400kHz - 40MHz for SDMMC)
    // Example: for fixed frequency of 10MHz, use host.max_freq_khz = 10000;
    sdmmc_host_t host = SDMMC_HOST_DEFAULT();
#if CONFIG_EXAMPLE_SDMMC_SPEED_HS
    host.max_freq_khz = SDMMC_FREQ_HIGHSPEED;
#elif CONFIG_EXAMPLE_SDMMC_SPEED_UHS_I_SDR50
    host.slot = SDMMC_HOST_SLOT_0;
    host.max_freq_khz = SDMMC_FREQ_SDR50;
    host.flags &= ~SDMMC_HOST_FLAG_DDR;
#elif CONFIG_EXAMPLE_SDMMC_SPEED_UHS_I_DDR50
    host.max_freq_khz = SDMMC_FREQ_DDR50;
#endif
    // For SoCs where the SD power can be supplied both via an internal or external (e.g. on-board LDO) power supply.
    // When using specific IO pins (which can be used for ultra high-speed SDMMC) to connect to the SD card
    // and the internal LDO power supply, we need to initialize the power supply first.
#if CONFIG_EXAMPLE_SD_PWR_CTRL_LDO_INTERNAL_IO
    sd_pwr_ctrl_ldo_config_t ldo_config = {
        .ldo_chan_id = CONFIG_EXAMPLE_SD_PWR_CTRL_LDO_IO_ID,
    sd_pwr_ctrl_handle_t pwr_ctrl_handle = NULL;
    ret = sd_pwr_ctrl_new_on_chip_ldo(&ldo_config, &pwr_ctrl_handle);
    if (ret != ESP_OK) {
        ESP_LOGE(TAG, "Failed to create a new on-chip LDO power control driver");
        return;
    host.pwr_ctrl_handle = pwr_ctrl_handle;
#endif
    // This initializes the slot without card detect (CD) and write protect (WP) signals.
    // Modify slot_config.gpio_cd and slot_config.gpio_wp if your board has these signals.
    sdmmc_slot_config_t slot_config = SDMMC_SLOT_CONFIG_DEFAULT();
#if EXAMPLE_IS_UHS1
    slot_config.flags |= SDMMC_SLOT_FLAG_UHS1;
#endif
    // Set bus width to use:
    slot_config.width = 4;
#else
    slot_config.width = 1;
#endif
    // On chips where the GPIOs used for SD card can be configured, set them in
    // the slot_config structure:
#ifdef CONFIG_SOC_SDMMC_USE_GPIO_MATRIX
    slot_config.clk = CONFIG_EXAMPLE_PIN_CLK;
    slot_config.cmd = CONFIG_EXAMPLE_PIN_CMD;
    slot_config.d0 = CONFIG_EXAMPLE_PIN_D0;
    slot_config.d1 = CONFIG_EXAMPLE_PIN_D1;
    slot_config.d2 = CONFIG_EXAMPLE_PIN_D2;
    slot_config.d3 = CONFIG_EXAMPLE_PIN_D3;
#endif  // CONFIG_EXAMPLE_SDMMC_BUS_WIDTH_4
#endif  // CONFIG_SOC_SDMMC_USE_GPIO_MATRIX
    // Enable internal pullups on enabled pins. The internal pullups
    // are insufficient however, please make sure 10k external pullups are
    // connected on the bus. This is for debug / example purpose only.
    slot_config.flags |= SDMMC_SLOT_FLAG_INTERNAL_PULLUP;
    ESP_LOGI(TAG, "Mounting filesystem");
    ret = esp_vfs_fat_sdmmc_mount(mount_point, &host, &slot_config, &mount_config, &card);
        if (ret == ESP_FAIL) {
            ESP_LOGE(TAG, "Failed to mount filesystem. "
                     "If you want the card to be formatted, set the EXAMPLE_FORMAT_IF_MOUNT_FAILED menuconfig option.");
            ESP_LOGE(TAG, "Failed to initialize the card (%s). "
                     "Make sure SD card lines have pull-up resistors in place.", esp_err_to_name(ret));
            check_sd_card_pins(&config, pin_count);
#endif
        return;
    ESP_LOGI(TAG, "Filesystem mounted");
    // Card has been initialized, print its properties
    sdmmc_card_print_info(stdout, card);
    // Use POSIX and C standard library functions to work with files:
    // First create a file.
    const char *file_hello = MOUNT_POINT"/hello.txt";
    char data[EXAMPLE_MAX_CHAR_SIZE];
    snprintf(data, EXAMPLE_MAX_CHAR_SIZE, "%s %s!\n", "Hello", card->cid.name);
    ret = s_example_write_file(file_hello, data);
        return;
    const char *file_foo = MOUNT_POINT"/foo.txt";
    // Check if destination file exists before renaming
    struct stat st;
    if (stat(file_foo, &st) == 0) {
        // Delete it if it exists
        unlink(file_foo);
    // Rename original file
    ESP_LOGI(TAG, "Renaming file %s to %s", file_hello, file_foo);
    if (rename(file_hello, file_foo) != 0) {
        ESP_LOGE(TAG, "Rename failed");
        return;
    ret = s_example_read_file(file_foo);
        return;
    // Format FATFS
#ifdef CONFIG_EXAMPLE_FORMAT_SD_CARD
    ret = esp_vfs_fat_sdcard_format(mount_point, card);
        ESP_LOGE(TAG, "Failed to format FATFS (%s)", esp_err_to_name(ret));
        return;
        ESP_LOGI(TAG, "file still exists");
        return;
        ESP_LOGI(TAG, "file doesn't exist, formatting done");
#endif // CONFIG_EXAMPLE_FORMAT_SD_CARD
    const char *file_nihao = MOUNT_POINT"/nihao.txt";
    memset(data, 0, EXAMPLE_MAX_CHAR_SIZE);
    snprintf(data, EXAMPLE_MAX_CHAR_SIZE, "%s %s!\n", "Nihao", card->cid.name);
    ret = s_example_write_file(file_nihao, data);
        return;
    //Open file for reading
    ret = s_example_read_file(file_nihao);
        return;
    // All done, unmount partition and disable SDMMC peripheral
    esp_vfs_fat_sdcard_unmount(mount_point, card);
    ESP_LOGI(TAG, "Card unmounted");
    // Deinitialize the power control driver if it was used
    ret = sd_pwr_ctrl_del_on_chip_ldo(pwr_ctrl_handle);
        ESP_LOGE(TAG, "Failed to delete the on-chip LDO power control driver");
        return;
#endif
/////////////////////////////////// Speed Test ///////////////////////////////////
#include <stdio.h>
#include <string.h>
#include <sys/time.h>
#include <unistd.h>
#include <fcntl.h>
#include <errno.h>
#define TEST_FILE_PATH "/sdcard/test.bin"
#define TEST_SIZE_MB 100
#define BLOCK_SIZE (128 * 1024)
    int fd = open(TEST_FILE_PATH, O_WRONLY | O_CREAT | O_TRUNC, 0666);
    if (fd < 0)
        printf("Failed to open file for writing, %s\n", strerror(errno));
        return;
    static char buf[BLOCK_SIZE];
    memset(buf, 0xAA, sizeof(buf));
    size_t total_bytes = TEST_SIZE_MB * 1024 * 1024;
    size_t written = 0;
    printf("Starting SD card write speed test\n");
    struct timeval start, end;
    gettimeofday(&start, NULL);
    // unsigned int tick = esp_timer_get_time() / 1000;
    while (written < total_bytes)
        size_t to_write = (total_bytes - written) > BLOCK_SIZE ? BLOCK_SIZE : (total_bytes - written);
        ssize_t ret = write(fd, buf, to_write);
        if (ret != to_write)
            printf("Write error\n");
        // unsigned int tick_temp = esp_timer_get_time() / 1000;
        // printf("Write %zu bytes, Time: %u ms\n", ret, tick_temp - tick);
        // tick = tick_temp;
        written += ret;
    fsync(fd); // 确保数据写入SD卡
    gettimeofday(&end, NULL);
    close(fd);
    double elapsed = (end.tv_sec - start.tv_sec) + (end.tv_usec - start.tv_usec) / 1e6;
    double speed = (double)written / 1024 / 1024 / elapsed;
    printf("SD write: %.2f MB written in %.2f s, speed: %.2f MB/s\n", (double)written / 1024 / 1024, elapsed, speed);
    return;
ESP_rrtandler
Re: esp32p4 V3.1 SD卡写入速度慢
Postby ESP_rrtandler » Thu Apr 02, 2026 12:59 pm
Hi @DevinKung ,
The problem may be caused by the write buffer not being 64 byte aligned.
Please check the address of the buffer and it's alignment to the 64 byte boundary - print the result of ((uintptr_t)buf % 64 == 0)
If the buffer is not 64 byte aligned, you can try to allocate the buffer from the heap using heap_caps_malloc(size, MALLOC_CAP_DMA) instead of doing it on stack.
