May I know what's reason why serial monitor not display anything ? Sorry, I'm newbie
Device: ESP32S3
Compile: Arduino IDE
My Code
* This sketch demonstrates how to scan WiFi networks. For chips that support 5GHz band, separate scans are done for all bands.
* The API is based on the Arduino WiFi Shield library, but has significant changes as newer WiFi functions are supported.
* E.g. the return value of `encryptionType()` different because more modern encryption is supported.
#include "WiFi.h"
// Enable Station Interface
WiFi.STA.begin();
Serial.println("Setup done");
void ScanWiFi() {
Serial.println("Scan start");
// WiFi.scanNetworks will return the number of networks found.
int n = WiFi.scanNetworks();
Serial.println("Scan done");
if (n == 0) {
Serial.println("no networks found");
Serial.print(n);
Serial.println(" networks found");
Serial.println("Nr | SSID | RSSI | CH | Encryption");
for (int i = 0; i < n; ++i) {
// Print SSID and RSSI for each network found
Serial.printf("%2d", i + 1);
Serial.print(" | ");
Serial.printf("%-32.32s", WiFi.SSID(i).c_str());
Serial.printf("%4ld", WiFi.RSSI(i));
Serial.printf("%2ld", WiFi.channel(i));
switch (WiFi.encryptionType(i)) {
case WIFI_AUTH_OPEN: Serial.print("open"); break;
case WIFI_AUTH_WEP: Serial.print("WEP"); break;
case WIFI_AUTH_WPA_PSK: Serial.print("WPA"); break;
case WIFI_AUTH_WPA2_PSK: Serial.print("WPA2"); break;
case WIFI_AUTH_WPA_WPA2_PSK: Serial.print("WPA+WPA2"); break;
case WIFI_AUTH_WPA2_ENTERPRISE: Serial.print("WPA2-EAP"); break;
case WIFI_AUTH_WPA3_PSK: Serial.print("WPA3"); break;
case WIFI_AUTH_WPA2_WPA3_PSK: Serial.print("WPA2+WPA3"); break;
case WIFI_AUTH_WAPI_PSK: Serial.print("WAPI"); break;
default: Serial.print("unknown");
Serial.println();
delay(10);
// Delete the scan result to free memory for code below.
WiFi.scanDelete();
Serial.println("-------------------------------------");
Serial.println("Default wifi band mode scan:");
#if ESP_IDF_VERSION >= ESP_IDF_VERSION_VAL(5, 4, 2)
WiFi.setBandMode(WIFI_BAND_MODE_AUTO);
#endif
ScanWiFi();
#if CONFIG_SOC_WIFI_SUPPORT_5G
// Wait a bit before scanning again.
delay(1000);
Serial.println("2.4 Ghz wifi band mode scan:");
WiFi.setBandMode(WIFI_BAND_MODE_2G_ONLY);
ScanWiFi();
delay(1000);
Serial.println("5 Ghz wifi band mode scan:");
WiFi.setBandMode(WIFI_BAND_MODE_5G_ONLY);
ScanWiFi();
#endif
delay(10000);
WiFiScan
Return to “General Discussion”
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- ESP32-S31
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- ESP32-S31 中文讨论版
- 喵伴 中文讨论版
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
- All times are UTC
- Top
- Delete cookies
About Us
Information
