Setting GPIO as High Impedance
hgptamn
Postby hgptamn » Thu Feb 22, 2018 2:31 pm
Hi!
Is there a way to set a GPIO pin as a high impedance pin?
I'm trying to program an ESP32 (board 1) external flash, using another ESP32 (board 2) conected via SPI.
I can access board 1 external flash using board 2, but once I do that board 1 is not able to boot anymore, as the SPI lines seem to not switch to a high impedance state on board 2 (the programmer). To put it in another way: board 2 (the programmer) latches on board 1 flash SPI lines, not releasing them.
What I've tried:
void loop(void)
  Serial.println("Disabling Board 2 CPU");
  delay(4500);
  digitalWrite(CPU, LOW);
  Serial.println("Board 2 CPU disabled!");
  delay(4000);
  //select proper pinMode for SPI flash access
  pinMode(CSPIN, OUTPUT);
  pinMode(MISO, INPUT);
  pinMode(MOSI, OUTPUT);
  pinMode(SCK, OUTPUT);
  Serial.println("Reading flash ID");
  Serial.print("ID bytes: ");
  uint16_t id[3];
  digitalWrite(CSPIN, LOW);
  SPI.transfer(0x9F);
  id[0] = SPI.transfer(0);
  id[1] = SPI.transfer(0);
  id[2] = SPI.transfer(0);
  digitalWrite(CSPIN, HIGH);
  SPI.endTransaction();
  Serial.print(id[0], HEX); Serial.print(" "); Serial.print(id[1], HEX);  Serial.print(" ");  Serial.println(id[2], HEX);
  delay(2000);
  //put SPI lines back in HIGH IMPEDANCE state in order for board 1 to boot from flash
  Serial.println("put Chip Select pin in high impedance");
  pinMode(CSPIN, INPUT);
  delay(3000);
  Serial.println("put MISO in high impedance");
  digitalWrite(MISO, LOW);
  delay(3000);
  Serial.println("put MOSI in high impedance");
  pinMode(MOSI, INPUT);
  digitalWrite(MOSI, LOW);
  delay(3000);
  Serial.println("put SCK in high impedance");
  pinMode(SCK, INPUT);
  digitalWrite(SCK, LOW);
  Serial.println("Wake up CPU on board 1");
  digitalWrite(CPU, HIGH);
  delay(6000);
At the end of this sequence board 2 doesn't boot anymore.
Users browsing this forum: Bytespider, Qwantbot and 2 guests
