ESP32-P4 USB JTAG Problem
panovich
Postby panovich » Sat Apr 18, 2026 8:08 am
Good afternoon. I don’t understand how USB works on this platform. The chip revision is 1.3. When I hold the BOOT button and connect USB, I see a JTAG controller and a COM port. I cannot flash firmware via JTAG — it shows:
Info : esp_usb_jtag: VID set to 0x303a and PID to 0x
1001
Info : esp_usb_jtag: capabilities descriptor set to 0x2000
❌ Error: esp_usb_jtag: could not find or open device!
Error: [esp32p4.hp.cpu0] Unsupported DTM version: -1
Error: [esp32p4.hp.cpu0] Could not identify target type.
Error: [esp32p4.hp.cpu1] Unsupported DTM version: -1
Error: [esp32p4.hp.cpu1] Could not identify target type.
I can flash firmware via the COM port, and it runs — I even managed to bring up a MIPI DSI display. However, no matter what I do, in normal (non-BOOT) mode neither JTAG nor the COM port appears in the device list. There is not even a sound indicating that a new device has been connected.
nickyytsrb
Re: ESP32-P4 USB JTAG Problem
Postby nickyytsrb » Tue May 12, 2026 11:43 am
I know that v1.3 is NRND but I have no other choice now, I already got the modules.
I'm having exactly the same issue which is "fixed" by connecting both USBs at gpio 24/25 and 26/27 but that is not solution to the issue. But when only 24/25 are connected there are issues. In non-boot mode there is no usb enumeration at all, and in boot mode it enumerates on usb as ttyACM0 but as soon as i try to use it it reenumerates as new ttyACM1. Sometimes I can get it to flash via usb-serial in boot mode but jtag does not work at all.
Did you find a fix to your issue?
Users browsing this forum: Bing [Bot], meta-externalagent, Qwantbot, YisouSpider and 2 guests
