Arduino ESP32 core 3.3.8 shows ~55kB less available internal RAM comparing to 3.3.7
copych
Postby copych » Fri Apr 24, 2026 12:15 pm
uint32_t dram_free  = heap_caps_get_free_size(MALLOC_CAP_INTERNAL);
uint32_t dram_largest = heap_caps_get_largest_free_block(MALLOC_CAP_INTERNAL);
For my project (audio) it is critical to fit as much data as possible into the fast DRAM, while PSRAM is still available.
The same code for ESP32S3 shows:
3.3.7 : Internal RAM free: 259984 bytes (largest block: 204788)
3.3.8 : Internal RAM free: 204888 bytes (largest block: 188404)
You can see that it is a more than 20% free DRAM drop.
So I wonder, is there any information on this situation? Is it forever, and can only get worse, or is it temporarily not-optimized new features like USB audio card? Or can it be resolved right now with some magic?
Surely I can revert to 3.3.7 (which I did) , but I also wait for the fixes and new features...
MicroController
Re: Arduino ESP32 core 3.3.8 shows ~55kB less available internal RAM comparing to 3.3.7
Postby MicroController » Mon Apr 27, 2026 7:05 am
Dunno where your DRAM went, but PSRAM (with the help of the ESP's cache) is probably more than fast enough for any kind of audio processing.
