ESP-IDF v6.0 refuses to initialize MIPI on Waveshare ESP32-P4 Dev Kit Module
andromeda92
Postby andromeda92 » Sat May 02, 2026 11:09 pm
I have waveshare ESP32-P4 Dev Kit module with waveshare LCD 10.1" 1280x800,
I can't see anything on the screen, the screen is initialized with the correct values, there are no errors in the monitor, the backlight is working, but nothing appears on the screen.
#include <stdio.h>
#include <string.h>
#include "freertos/task.h"
#include "esp_log.h"
#include "driver/i2c_master.h"
#include "driver/gpio.h"
#include "driver/ledc.h"
#include "esp_ldo_regulator.h"
#include "esp_lcd_mipi_dsi.h"
#include "esp_lcd_panel_ops.h"
#include "esp_lcd_panel_io.h"
#include "esp_lcd_jd9365_10_1.h"
#include "esp_heap_caps.h"
static const char *TAG = "WAVESHARE_P4_COMPLETE";
// --- CONFIGURATION MATÉRIELLE ---
#define I2C_SDA_IO          7
#define I2C_SCL_IO          8
#define LCD_RST_IO          23
#define LCD_BK_LIGHT_IO     38
#define LCD_H_RES           1280
#define LCD_V_RES           800
#define I2C_FREQ_HZ         100000
// --- TIMINGS MIPI DPI (ALIGNÉS SUR TES VALEURS ARDUINO) ---
#define VAL_PIXEL_CLK_MHZ   60      // ESP_PANEL_BOARD_LCD_MIPI_DPI_CLK_MHZ
#define VAL_BITRATE_MBPS    1500
#define VAL_H_PULSE         20      // HPW
#define VAL_H_BACK          20      // HBP
#define VAL_H_FRONT         40      // HFP
#define VAL_V_PULSE         4       // VPW
#define VAL_V_BACK          10      // VBP
#define VAL_V_FRONT         30      // VFP
#define MIPI_LDO_ID         3       // ESP_PANEL_BOARD_LCD_MIPI_PHY_LDO_ID
// --- SÉQUENCE D'INITIALISATION JD9365 ---
static const jd9365_lcd_init_cmd_t vendor_specific_init[] = {
    {0xE0, (uint8_t[]){0x00}, 1, 0}, {0xE1, (uint8_t[]){0x93}, 1, 0}, {0xE2, (uint8_t[]){0x65}, 1, 0}, {0xE3, (uint8_t[]){0xF8}, 1, 0}, {0x80, (uint8_t[]){0x01}, 1, 0},
    {0xE0, (uint8_t[]){0x01}, 1, 0}, {0x00, (uint8_t[]){0x00}, 1, 0}, {0x01, (uint8_t[]){0x38}, 1, 0}, {0x03, (uint8_t[]){0x10}, 1, 0}, {0x04, (uint8_t[]){0x38}, 1, 0},
    {0x0C, (uint8_t[]){0x74}, 1, 0}, {0x17, (uint8_t[]){0x00}, 1, 0}, {0x18, (uint8_t[]){0xAF}, 1, 0}, {0x19, (uint8_t[]){0x00}, 1, 0}, {0x1A, (uint8_t[]){0x00}, 1, 0},
    {0x1B, (uint8_t[]){0xAF}, 1, 0}, {0x1C, (uint8_t[]){0x00}, 1, 0}, {0x35, (uint8_t[]){0x26}, 1, 0}, {0x37, (uint8_t[]){0x09}, 1, 0}, {0x38, (uint8_t[]){0x04}, 1, 0},
    {0x39, (uint8_t[]){0x00}, 1, 0}, {0x3A, (uint8_t[]){0x01}, 1, 0}, {0x3C, (uint8_t[]){0x78}, 1, 0}, {0x3D, (uint8_t[]){0xFF}, 1, 0}, {0x3E, (uint8_t[]){0xFF}, 1, 0},
    {0x3F, (uint8_t[]){0x7F}, 1, 0}, {0x40, (uint8_t[]){0x06}, 1, 0}, {0x41, (uint8_t[]){0xA0}, 1, 0}, {0x42, (uint8_t[]){0x81}, 1, 0}, {0x43, (uint8_t[]){0x1E}, 1, 0},
    {0x44, (uint8_t[]){0x0D}, 1, 0}, {0x45, (uint8_t[]){0x28}, 1, 0}, {0x55, (uint8_t[]){0x02}, 1, 0}, {0x57, (uint8_t[]){0x69}, 1, 0}, {0x59, (uint8_t[]){0x0A}, 1, 0},
    {0x5A, (uint8_t[]){0x2A}, 1, 0}, {0x5B, (uint8_t[]){0x17}, 1, 0}, {0x5D, (uint8_t[]){0x7F}, 1, 0}, {0x5E, (uint8_t[]){0x6A}, 1, 0}, {0x5F, (uint8_t[]){0x5B}, 1, 0},
    {0x60, (uint8_t[]){0x4F}, 1, 0}, {0x61, (uint8_t[]){0x4A}, 1, 0}, {0x62, (uint8_t[]){0x3D}, 1, 0}, {0x63, (uint8_t[]){0x41}, 1, 0}, {0x64, (uint8_t[]){0x2A}, 1, 0},
    {0x65, (uint8_t[]){0x44}, 1, 0}, {0x66, (uint8_t[]){0x43}, 1, 0}, {0x67, (uint8_t[]){0x44}, 1, 0}, {0x68, (uint8_t[]){0x62}, 1, 0}, {0x69, (uint8_t[]){0x52}, 1, 0},
    {0x6A, (uint8_t[]){0x59}, 1, 0}, {0x6B, (uint8_t[]){0x4C}, 1, 0}, {0x6C, (uint8_t[]){0x48}, 1, 0}, {0x6D, (uint8_t[]){0x3A}, 1, 0}, {0x6E, (uint8_t[]){0x26}, 1, 0},
    {0x6F, (uint8_t[]){0x00}, 1, 0}, {0x70, (uint8_t[]){0x7F}, 1, 0}, {0x71, (uint8_t[]){0x6A}, 1, 0}, {0x72, (uint8_t[]){0x5B}, 1, 0}, {0x73, (uint8_t[]){0x4F}, 1, 0},
    {0x74, (uint8_t[]){0x4A}, 1, 0}, {0x75, (uint8_t[]){0x3D}, 1, 0}, {0x76, (uint8_t[]){0x41}, 1, 0}, {0x77, (uint8_t[]){0x2A}, 1, 0}, {0x78, (uint8_t[]){0x44}, 1, 0},
    {0x79, (uint8_t[]){0x43}, 1, 0}, {0x7A, (uint8_t[]){0x44}, 1, 0}, {0x7B, (uint8_t[]){0x62}, 1, 0}, {0x7C, (uint8_t[]){0x52}, 1, 0}, {0x7D, (uint8_t[]){0x59}, 1, 0},
    {0x7E, (uint8_t[]){0x4C}, 1, 0}, {0x7F, (uint8_t[]){0x48}, 1, 0}, {0x80, (uint8_t[]){0x3A}, 1, 0}, {0x81, (uint8_t[]){0x26}, 1, 0}, {0x82, (uint8_t[]){0x00}, 1, 0},
    {0xE0, (uint8_t[]){0x02}, 1, 0}, {0x11, (uint8_t[]){0x00}, 1, 120}, {0x29, (uint8_t[]){0x00}, 1, 20},
void app_main(void)
    // --- 1. RÉTROÉCLAIRAGE EN PREMIER ---
    ledc_timer_config_t ledc_timer = {
        .speed_mode = LEDC_LOW_SPEED_MODE, .timer_num = LEDC_TIMER_0,
        .duty_resolution = LEDC_TIMER_13_BIT, .freq_hz = 5000, .clk_cfg = LEDC_AUTO_CLK
    ESP_ERROR_CHECK(ledc_timer_config(&ledc_timer));
    ledc_channel_config_t ledc_channel = {
        .speed_mode = LEDC_LOW_SPEED_MODE, .channel = LEDC_CHANNEL_0,
        .timer_sel = LEDC_TIMER_0, .gpio_num = LCD_BK_LIGHT_IO, .duty = 8191 // 100%
    ESP_ERROR_CHECK(ledc_channel_config(&ledc_channel));
    // --- 2. ALIMENTATION LDO ---
    esp_ldo_channel_handle_t ldo_mipi = NULL;
    esp_ldo_channel_config_t ldo_cfg = { .chan_id = MIPI_LDO_ID, .voltage_mv = 2500 };
    ESP_ERROR_CHECK(esp_ldo_acquire_channel(&ldo_cfg, &ldo_mipi));
    // --- 3. RESET ÉCRAN ---
    gpio_config_t rst_io_conf = { .mode = GPIO_MODE_OUTPUT, .pin_bit_mask = (1ULL << LCD_RST_IO) };
    gpio_config(&rst_io_conf);
    gpio_set_level(LCD_RST_IO, 0); vTaskDelay(pdMS_TO_TICKS(100));
    gpio_set_level(LCD_RST_IO, 1); vTaskDelay(pdMS_TO_TICKS(200));
    // --- 4. I2C BUS ---
    i2c_master_bus_handle_t i2c_bus = NULL;
    i2c_master_bus_config_t i2c_mst_config = {
        .clk_source = I2C_CLK_SRC_XTAL, .i2c_port = I2C_NUM_1,
        .scl_io_num = I2C_SCL_IO, .sda_io_num = I2C_SDA_IO,
        .glitch_ignore_cnt = 7, .flags.enable_internal_pullup = true,
    ESP_ERROR_CHECK(i2c_new_master_bus(&i2c_mst_config, &i2c_bus));
    i2c_device_config_t dev_cfg = { .device_address = 0x45, .scl_speed_hz = I2C_FREQ_HZ };
    i2c_master_dev_handle_t i2c_dev = NULL;
    ESP_ERROR_CHECK(i2c_master_bus_add_device(i2c_bus, &dev_cfg, &i2c_dev));
    // --- 5. BRIDGE TC358775 ---
    ESP_ERROR_CHECK(i2c_master_transmit(i2c_dev, (uint8_t[]){0x95, 0x11}, 2, 200));
    ESP_ERROR_CHECK(i2c_master_transmit(i2c_dev, (uint8_t[]){0x95, 0x17}, 2, 200));
    ESP_ERROR_CHECK(i2c_master_transmit(i2c_dev, (uint8_t[]){0x96, 0x00}, 2, 200));
    ESP_ERROR_CHECK(i2c_master_transmit(i2c_dev, (uint8_t[]){0x96, 0xFF}, 2, 200));
    // --- 6. DSI BUS ---
    esp_lcd_dsi_bus_handle_t mipi_dsi_bus = NULL;
    esp_lcd_dsi_bus_config_t dsi_bus_config = {
        .bus_id = 0, .num_data_lanes = 2,
        .phy_clk_src = MIPI_DSI_PHY_CLK_SRC_DEFAULT,
        .lane_bit_rate_mbps = VAL_BITRATE_MBPS,
    ESP_ERROR_CHECK(esp_lcd_new_dsi_bus(&dsi_bus_config, &mipi_dsi_bus));
    // --- 7. DPI CONFIG (60MHz + TIMINGS ARDUINO) ---
    const esp_lcd_dpi_panel_config_t dpi_config = {
        .dpi_clk_src = MIPI_DSI_DPI_CLK_SRC_DEFAULT,
        .dpi_clock_freq_mhz = VAL_PIXEL_CLK_MHZ,
        .video_timing = {
            .h_size = LCD_H_RES, .v_size = LCD_V_RES,
            .hsync_pulse_width = VAL_H_PULSE, .hsync_back_porch = VAL_H_BACK, .hsync_front_porch = VAL_H_FRONT,
            .vsync_pulse_width = VAL_V_PULSE, .vsync_back_porch = VAL_V_BACK, .vsync_front_porch = VAL_V_FRONT,
        .in_color_format = LCD_COLOR_FMT_RGB888,
    // --- 8. PANEL IO & JD9365 ---
    esp_lcd_panel_io_handle_t mipi_dbi_io = NULL;
    esp_lcd_dbi_io_config_t dbi_config = { .virtual_channel = 0, .lcd_cmd_bits = 8, .lcd_param_bits = 8 };
    ESP_ERROR_CHECK(esp_lcd_new_panel_io_dbi(mipi_dsi_bus, &dbi_config, &mipi_dbi_io));
    jd9365_vendor_config_t vendor_cfg = {
        .mipi_config = { .dsi_bus = mipi_dsi_bus, .lane_num = 2, .dpi_config = &dpi_config },
        .init_cmds = vendor_specific_init,
        .init_cmds_size = sizeof(vendor_specific_init) / sizeof(jd9365_lcd_init_cmd_t),
    esp_lcd_panel_dev_config_t panel_dev_config = {
        .reset_gpio_num = -1, .rgb_ele_order = LCD_RGB_ELEMENT_ORDER_RGB,
        .bits_per_pixel = 24, .vendor_config = &vendor_cfg,
    esp_lcd_panel_handle_t panel_handle = NULL;
    ESP_ERROR_CHECK(esp_lcd_new_panel_jd9365(mipi_dbi_io, &panel_dev_config, &panel_handle));
    // --- 9. INIT ET DESSIN ---
    ESP_ERROR_CHECK(esp_lcd_panel_init(panel_handle));
    ESP_ERROR_CHECK(esp_lcd_panel_disp_on_off(panel_handle, true));
    // Utilisation de heap_caps_malloc avec DMA pour l'affichage sur P4
    uint8_t *fb = (uint8_t *)heap_caps_malloc(LCD_H_RES * 100 * 3, MALLOC_CAP_DMA | MALLOC_CAP_INTERNAL | MALLOC_CAP_8BIT);
    if (fb) {
        memset(fb, 0xFF, LCD_H_RES * 100 * 3); // Test Blanc
        esp_lcd_panel_draw_bitmap(panel_handle, 0, 0, LCD_H_RES, 100, fb);
    while (1) vTaskDelay(pdMS_TO_TICKS(1000));
on the monitor:
I (27) boot: ESP-IDF v6.0-dirty 2nd stage bootloader
I (28) boot: compile time Apr 27 2026 08:33:41
I (28) boot: Multicore bootloader
I (30) boot: chip revision: v1.0
I (31) boot: efuse block revision: v0.3
I (35) boot.esp32p4: SPI Speed : 40MHz
I (38) boot.esp32p4: SPI Mode : DIO
I (42) boot.esp32p4: SPI Flash Size : 16MB
I (46) boot: Enabling RNG early entropy source...
I (51) boot: Partition Table:
I (53) boot: ## Label Usage Type ST Offset Length
I (59) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (66) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (72) boot: 2 factory factory app 00 00 00010000 00100000
I (80) boot: End of partition table
I (83) esp_image: segment 0: paddr=00010020 vaddr=40030020 size=0e0e0h ( 57568) map
I (103) esp_image: segment 1: paddr=0001e108 vaddr=30100000 size=00068h ( 104) load
I (105) esp_image: segment 2: paddr=0001e178 vaddr=4ff00000 size=01ea0h ( 7840) load
I (111) esp_image: segment 3: paddr=00020020 vaddr=40000020 size=20880h (133248) map
I (145) esp_image: segment 4: paddr=000408a8 vaddr=4ff01ea0 size=0d918h ( 55576) load
I (160) esp_image: segment 5: paddr=0004e1c8 vaddr=4ff0f800 size=034ech ( 13548) load
I (165) esp_image: segment 6: paddr=000516bc vaddr=50108080 size=00024h ( 36) load
I (170) boot: Loaded app from partition at offset 0x10000
I (171) boot: Disabling RNG early entropy source...
I (187) hex_psram: vendor id : 0x0d (AP)
I (187) hex_psram: Latency : 0x01 (Fixed)
I (187) hex_psram: DriveStr. : 0x00 (25 Ohm)
I (188) hex_psram: dev id : 0x03 (generation 4)
I (193) hex_psram: density : 0x07 (256 Mbit)
I (197) hex_psram: good-die : 0x06 (Pass)
I (201) hex_psram: SRF : 0x02 (Slow Refresh)
I (206) hex_psram: BurstType : 0x00 ( Wrap)
I (210) hex_psram: BurstLen : 0x03 (2048 Byte)
I (215) hex_psram: BitMode : 0x01 (X16 Mode)
I (219) hex_psram: Readlatency : 0x04 (14 cycles@Fixed)
I (224) hex_psram: DriveStrength: 0x00 (1/1)
I (228) MSPI Timing: Enter psram timing tuning
I (405) esp_psram: Found 32MB PSRAM device
I (405) esp_psram: Speed: 200MHz
I (406) hex_psram: psram CS IO is dedicated
I (407) cpu_start: Multicore app
I (1392) esp_psram: SPI SRAM memory test OK
I (1401) cpu_start: GPIO 38 and 37 are used as console UART I/O pins
I (1402) cpu_start: Pro cpu start user code
I (1402) cpu_start: cpu freq: 360000000 Hz
I (1404) app_init: Application information:
I (1408) app_init: Project name: esp_lcd_test
I (1412) app_init: App version: 1
I (1415) app_init: Compile time: May 2 2026 23:56:31
I (1421) app_init: ELF file SHA256: 207cf99bd...
I (1425) app_init: ESP-IDF: v6.0-dirty
I (1429) efuse_init: Min chip rev: v0.0
I (1433) efuse_init: Max chip rev: v1.99
I (1437) efuse_init: Chip rev: v1.0
I (1441) heap_init: Initializing. RAM available for dynamic allocation:
I (1448) heap_init: At 4FF14770 len 00026850 (154 KiB): RETENT_RAM
I (1453) heap_init: At 4FF3AFC0 len 00004BF0 (18 KiB): RAM
I (1459) heap_init: At 4FF40000 len 00060000 (384 KiB): RAM
I (1464) heap_init: At 501080A4 len 00007F5C (31 KiB): RTCRAM
I (1469) heap_init: At 30100068 len 00001F98 (7 KiB): TCM
I (1475) esp_psram: Adding pool of 32768K of PSRAM memory to heap allocator
I (1483) spi_flash: detected chip: gd
I (1485) spi_flash: flash io: dio
I (1488) sleep_gpio: Configure to isolate all GPIO pins in sleep state
I (1494) sleep_gpio: Enable automatic switching of GPIO sleep configuration
I (1501) main_task: Started on CPU0
I (1531) main_task: Calling app_main()
I (1931) jd9365: version: 1.0.4
I (1931) i2c_bus: I2C Bus V2 uses the externally initialized bus handle
I (3061) jd9365: LCD ID: 93 65 04
Any idea ?
thanks you for your help.
andromeda92
Re: ESP-IDF v6.0 refuses to initialize MIPI on Waveshare ESP32-P4 Dev Kit Module
Postby andromeda92 » Sun May 03, 2026 9:12 pm
I solved the problem by following an example, and the touch function also works, so problem solved.
Users browsing this forum: Bing [Bot], meta-externalagent, Qwantbot, YisouSpider and 2 guests
