IDF 6.0.1 weird value in build/gdbinit/symbols
esp32.damiano
Postby esp32.damiano » Mon Jun 08, 2026 2:03 pm
What happens is that a slash is missing
    add-symbol-file /home/damiano/.espressif/tools/esp-rom-elfs/20241011esp32c6_rev0_rom.elf
should be
    add-symbol-file /home/damiano/.espressif/tools/esp-rom-elfs/20241011/esp32c6_rev0_rom.elf
anyone has a hint on how to fix the bad joining ?
adjusting it at every compile is ..... a PAIN
Thank you
MicroController
Re: IDF 6.0.1 weird value in build/gdbinit/symbols
Postby MicroController » Mon Jun 08, 2026 2:20 pm
https://github.com/espressif/esp-idf/issues/18418
Quick hack would be to insert a "\" in https://github.com/espressif/esp-idf/bl ... nit.py#L52, or
rom_file = os.path.join(rom_elfs_dir, f'{target}_rev{k["rev"]}_rom.elf')
r.append(indent(f'add-symbol-file {rom_file}', indent_str + base_ident))
esp32.damiano
Postby esp32.damiano » Mon Jun 08, 2026 6:52 pm
THANKS !
I will take a try tomorrow, the function should be generate_gdbinit_rom_add_symbols
(it is pretty late now)
thanks again
esp32.damiano
Postby esp32.damiano » Mon Jun 08, 2026 7:02 pm
could not wait, line 52 of gen_gdbinit.py becomes
        r.append(indent(f'add-symbol-file {rom_elfs_dir}/{rom_file}', indent_str + base_ident))
the missing slash is inserted
Users browsing this forum: dmaxben, Semrush [Bot] and 11 guests
