Powering esp32 from battery doesn't work
mogplus8
Postby mogplus8 » Sat Jun 13, 2026 12:52 pm
Hi All,
I'm confused. I've developed a system (using Micropython) to write an output stream to a pin using the RMT function. It works perfectly when the ESP32 is plugged into my computer, but doesn't when it's plugged into a battery. I've confirmed the battery is fully charged and is delivering five volts to the usb plug (it has two 18650 cells). I have also confirmed that the code is executing with the battery by putting some led flashing code around the RMT write_pulses() command, and the led does flash so the command is definitely being executed. I'm using a logic analyser (cheap Chinses knockoff, but it works) connected to the output pin, and Saleae Logic Analyser 2 to display the output on my pc.
This is the code I'm running (without the led flashing stuff):
Works perfectly.
from esp32 import RMT
from machine import Pin
rmt = RMT(0, pin=Pin(23), resolution_hz=1_000_000, num_symbols=512, idle_level=False)
duration = (1000, 300, 2000, 300) * 4
duration = duration + (7800, 300)
print('enter loop')
while True:
    try:
        rmt.write_pulses(duration, True)
    except Exception as e:
        print('Fell over', e)
        rmt.deinit()
        break
    except KeyboardInterrupt:
        print('keyboard interrupt')
        rmt.deinit()
        print('rmt deinitialised')
        break
rmt.deinit()
print('program ended')
What am I doing wrong? or missing?
All advice gratefully received.
mgsecord62
Re: Powering esp32 from battery doesn't work
Postby mgsecord62 » Sat Jun 13, 2026 5:06 pm
Do you have the logic analyzer ground connected to the 3.3v ground on the ESP32 when running from the battery? When running power from the same computer as the logic analyzer, the ground of the USB logic analyzer and USB power are most likely connected.
Postby Sprite » Mon Jun 15, 2026 12:18 am
Also, could be that your board has capacitance on GPIO0. Try using the reset button when on battery power, if it springs to life then you'll need to remove a capacitor.
Users browsing this forum: Amazon [Bot], Applebot, PetalBot and 2 guests
