ESP-IDF 6.0.1 unable to compike/build project useinf fatfs.
DickyOZ
Postby DickyOZ » Tue Jun 16, 2026 9:55 am
lvgl 9.5
There is a bug in the fatfs code that causes a compile error at line 268 in lv_fs_fatfs.c
    do {
        res = f_readdir(dir_p, &fno);
        if(res != FR_OK) return LV_FS_RES_UNKNOWN;
        if(fno.fname[0] == 0) break; /* End of the directory */
        if(fno.fattrib & AM_DIR) {
            lv_snprintf(fn, fn_len, "/%s", fno.fname);
        else lv_strlcpy(fn, fno.fname, fn_len);
    } while(lv_strcmp(fn, "/.") == 0 || lv_strcmp(fn, "/..") == 0);
    return LV_FS_RES_OK;
If i fix the problem ninja detects a checksum fail and spits the dummy:
Bootloader binary size 0x5dc0 bytes. 0x240 bytes (2%) free.
[7/9] Linking CXX executable Test_fatfs.elf
FAILED: Test_fatfs.elf
No matter what I try I can't get round the problem. Sorry about the typos in the header, it's getting late in the day.
haberturdeur
Re: ESP-IDF 6.0.1 unable to compike/build project useinf fatfs.
Postby haberturdeur » Mon Jun 22, 2026 8:50 am
Hi, sorry for the delayed response.
This seems like an error in the LVGL library, not ESP-IDF itself.
I would recommend switching to the POSIX FS driver and using ESP-IDFs vfs and fatfs support, if at all possible.
Users browsing this forum: Applebot, ChatGPT-User, Google [Bot] and 1 guest
