I have been working on a small open-source project called LWDT: https://github.com/oldrev/lwdt
It is a lightweight devicetree and driver framework for native ESP-IDF projects. The goal is to solve a problem I kept running into on ESP32-family boards: once you have more than one hardware variant, board-specific code tends to spread everywhere. GPIO numbers end up hardcoded in application logic, sdkconfig starts carrying board wiring, drivers grow #ifdef branches, and reusing the same custom driver across different boards becomes more painful than it should be.
The inspiration comes from Zephyr RTOS. I love Zephyr's board IDs, decoupled drivers, devicetree-generated macros, and priority-sorted init model. But for many production ESP32 projects, giving up native ESP-IDF is just not a option. ESP-IDF has excellent vendor support, solid Wi-Fi/BLE provisioning, mesh, optimization, and first-class support for new Espressif silicon.
So, LWDT tries to bring a subset of that Zephyr-style device-tree (in Jsonnet format) and driver framework into ESP-IDF instead of replacing it.
What it currently does:
- Board selection: Select boards with a stable vendor/model ID, similar Zephyr's west -b.
- Single source of truth: Keep board hardware description in a Jsonnet board.lwdt file instead of scattering it through C code, CMake, and sdkconfig.
- Target automation: Automatically sets the correct IDF_TARGET from board metadata during the CMake configure phase.
- Compile-time codegen: Generates C access macros from Jsonnet-backed devicetree files with zero runtime parsing overhead.
- Overlays support: Supports .lwdt.overlay files for project-level or environment-specific hardware overrides.
- Loosely-coupled drivers: Provides a small drvfx framework with static device objects.
A board configuration looks roughly like this (using Jsonnet for a cleaner):
local esp32c3 = import "soc/esp32/esp32c3.lwdt";
esp32c3 + {
board: {
label: "board",
led_gpio: 8,
led_active_low: 1,
led_name: "ESP32-C3 SuperMini",
#include <lwdt/lwdt.h>
#include "lwdt_generated.h"
#define BOARD_NODE LWDT_NODELABEL(board)
#define BLINK_GPIO LWDT_PROP(BOARD_NODE, led_gpio)
#define LED_ACTIVE_LOW LWDT_PROP(BOARD_NODE, led_active_low)Code: Select all
idf.py build -DLWDT_BOARD_ID=nologo/esp32-c3-supermini
This is still early stage and intentionally lean. Current built-in drivers include I2C, SPI, and RTC examples. The project currently focuses on proving the board/BSP, overlay, generated macro, and auto-sorting initialization model.
AI Disclosure
Parts of the drivers in this project were rewritten from my open-source Borneo-IoT LED Controller firmware (https://github.com/borneo-iot/borneo). The rewritten code has been further refined and optimized with the assistance of AI tools.
Have fun!
