Hello ,
I want to connect vscode/platformio/continue to Espressif mcp servers. Although there is no precise description for this in Espressif documentation, I tried to modify the config.yaml file using mcp server adress but this is not working as I cannot reach the server.
Do I need to also install something at vscode level?
Connectin Espressif mcp servers to vscode/continue
Re: Connectin Espressif mcp servers to vscode/continue
Hello ob_seven,
Which particular MCP server do you mean? One of the listed at https://mcp.espressif.com/?
A quick way to get guidance is by asking a question at https://chat.espressif.com/
Hi again.
Continue is creating troubles, as I never managed to get MCP connection.
I managed to get Qwen3 code 30B as a local llm, working with Zoo code as a VScode agent. Zoo code does work with Espressif MCP server.
This is the best setup I managed to get, using my RTX 3090.
I got focused code correction done. It seems to work. I will now play with the settings, and make sure to always rely on MCP documentation.
So far so good, and a completely free setup.
Users browsing this forum: Amazon [Bot], ChatGPT-User and 2 guests
