ESP32-S3 dual-core INT_WDT freeze correlated with SPI-GDMA (LCD) activity
jiauka
Postby jiauka » Tue Jul 07, 2026 10:40 am
## Summary
On an ESP32-S3 product we get an intermittent **hard freeze of both cores at
once**, caught by the interrupt watchdog (INT_WDT) with **no core dump** (the
panic handler never runs because both CPUs are wedged). The freeze is tightly
correlated with **SPI master GDMA activity used for an LCD panel flush**, and it
**disappears completely** when the second core is disabled
(`CONFIG_FREERTOS_UNICORE=y`). We have spent significant time isolating it and
would appreciate guidance on whether this matches a known ESP32-S3 erratum and
whether there is a workaround that preserves both cores.
## Environment
- **Target:** ESP32-S3 (dual-core). *Chip revision: <please fill from `esptool.py chip_id` / boot log>*
- **ESP-IDF:** v5.5.2
- **Flash:** XMC XM25QH32B (JEDEC 0x204016), **DIO @ 40 MHz**
- **PSRAM:** **disabled** (`CONFIG_SPIRAM` not set)
- **Watchdogs:** `CONFIG_ESP_INT_WDT=y` (timeout 2000 ms), `CONFIG_ESP_TASK_WDT_EN=y`
## Relevant peripherals running concurrently
- **LCD:** ILI9488 480×320, driven over **SPI master (GDMA)** via `esp_lcd`
  (`esp_lcd_panel_draw_bitmap`), LVGL 8.3.1. LVGL draw buffers are allocated in
  **internal DMA-capable SRAM** (`heap_caps_malloc(..., MALLOC_CAP_DMA)`), *not*
  PSRAM. Flush is asynchronous; completion via the `on_color_trans_done` ISR
  (which is `IRAM_ATTR`).
- **Addressable LED strip:** 51× WS2812 driven by the **RMT peripheral** (tested
  both with and without GDMA).
- **7-segment driver** on a second SPI host, **RS-485/Modbus** on UART1,
  Wi-Fi (AP/STA).
The LCD and 7-seg SPI hosts can be swapped (SPI2 ↔ SPI3); swapping them did not
change the behaviour.
## Symptom
- **Both cores stop executing simultaneously.** Per-core idle "heartbeat"
  timestamps (stamped from each CPU's idle hook into RTC RAM) both stop at the
  same time.
- Reset reason is the **interrupt watchdog**; **no core dump** is produced.
- Occurs during **normal operation** while the LCD is being refreshed and the
  LED strip / Modbus are active. Intermittent (minutes to hours).
## Diagnostic evidence (what changes the behaviour)
| # | Change | Result |
| 1 | Baseline: dual-core, LCD SPI-GDMA flush + RMT + Modbus active | **Freeze** (INT_WDT, both cores, no coredump) |
| 2 | `CONFIG_FREERTOS_UNICORE=y` (core 1 held in reset) | **No freeze** — stable for days. Proven repeatedly. |
| 3 | Dual-core, but **every application task pinned to core 0** (core 1 alive but runs only idle/tick/IPC) | **Freeze returns** |
| 4 | Earlier: application tasks split across cores (display tasks→core1, wifi/modbus→core0) | **Freeze** |
| 5 | Disable the LCD flush entirely (no SPI-GDMA traffic), keep everything else | **No freeze** |
| 6 | Move the LED strip from **GDMA-RMT** to **non-DMA RMT** (remove the 2nd GDMA channel) | Freeze got **more frequent** (added RMT-ISR / AHB load) |
| 7 | Software mutex serialising the LCD SPI-GDMA flush against the RMT-GDMA refresh (the two DMA channels never overlap) | **No effect** — still freezes |
| 8 | PSRAM: already **disabled** (draw buffers in internal SRAM) | N/A — see "ruled out" |
The key pair is **#2 vs #3**: disabling core 1 (unicore) fixes it, but merely
**pinning all tasks to core 0 while core 1 remains alive does not**. That points
at the second core's *presence* (its cache/bus activity from idle, the per-core
tick, IPC), not at any particular task, interacting with the SPI-GDMA flush.
## What we have ruled out
- **CACHE-126 ("Cache Hit Error During Cache Write-Backs").** With **PSRAM
  disabled** there is no writable cached memory, so there are **no dcache
  write-backs** (`esp_cache_msync` C2M is never invoked; the framebuffer is
  internal SRAM read directly by GDMA). The freeze still occurs, so this is not
  the write-back erratum.
- **Two concurrent GDMA channels.** A mutex that guarantees the LCD SPI-GDMA and
  the RMT-GDMA never run at the same time (evidence #7) does not help, so a
  simple two-channel GDMA collision is not the whole story — a single SPI-GDMA
  flush plus a live second core is enough.
- **A specific task.** Evidence #3/#4 (task placement doesn't matter, only core 1
  liveness does).
- **PSRAM contention** (it is off).
Our working hypothesis is contention between **SPI master GDMA** and the
**dual-core cache / instruction-fetch path** that only manifests when both CPUs
are active — but we cannot find a documented erratum or a Kconfig workaround, and
IRAM-placing the flush callbacks does not help because the vulnerable window is
the entire multi-millisecond background DMA transfer (during which arbitrary
flash-resident code runs on both cores), not the flush call itself.
## Secondary issue (may be related)
After such a freeze/watchdog reset, the **XMC flash is left in a state the ROM
bootloader cannot read**: the boot loops with repeated `invalid header: 0x…`
and `rst:0x7 (TG0WDT_SYS_RST)` (bootloader watchdog), and **only a full power
cycle recovers** — a clean `esp_restart()` never triggers this. So a warm/
watchdog reset does not reset the flash chip the way `esp_restart()` does.
`CONFIG_BOOTLOADER_FLASH_XMC_SUPPORT=y` and `CONFIG_SPI_FLASH_BROWNOUT_RESET_XMC=y`
are enabled but do not prevent it. This turns every freeze into a field failure
that needs manual power-cycling.
## Questions for Espressif
1. Is there a **known ESP32-S3 erratum** where **SPI-master GDMA** activity,
   concurrent with **both CPU cores active**, can hang the system (INT_WDT,
   both cores) — independent of PSRAM and independent of a second DMA channel?
2. If so, is there a **workaround that keeps both cores enabled** (e.g. a
   required interrupt/cache configuration, a GDMA setting, an alignment or
   memory-placement constraint for the SPI DMA buffers)?
3. Is there anything specific to **`esp_lcd` SPI + GDMA on dual-core S3** we
   should configure differently (e.g. the flush buffer placement, transaction
   queue depth, or interrupt priority/affinity)?
4. For the secondary issue: is there a supported way to **reset the (XMC) flash
   chip on a warm/watchdog reset** so the device self-recovers without a power
   cycle?
## What we can provide
We can prepare a **minimal reproducer** (LVGL flush loop on the ILI9488 over SPI-
GDMA + a background load on core 1) on request, plus the full `sdkconfig`,
`idf.py --version`, and exact chip revision. The behaviour is highly repeatable:
unicore = stable, dual-core = freezes.
jiauka
Re: ESP32-S3 dual-core INT_WDT freeze correlated with SPI-GDMA (LCD) activity
Postby jiauka » Wed Jul 08, 2026 7:34 am
CPU version is 0.2
I have refactor to use idf 6.0.2, with and withouT SMP
Same problem/symtomp, works ok as unicore, crashes when dualcore even if all tasks run into the same core
MicroController
Postby MicroController » Wed Jul 08, 2026 12:26 pm
The usual initial suspects are
- stable power supply?
- anything (soft- or hardware) interfering with any flash SPI pins?
If these can be ruled out, try a different chip to see if it may be a hardware defect.
If not successful, a bug in your application code is likely the culprit. A reproducible example would really help in locating it.
jiauka
Postby jiauka » Thu Jul 09, 2026 10:17 am
In unicore works fine, that should rulke out any hardware /voltage issue.
I tried with the 2 protos I have, they behave the same, I will try to make a reproducible example using a dev kit and a minimal source code
MicroController
Postby MicroController » Thu Jul 09, 2026 6:56 pm
The most significant difference between single- vs. dual-core is probably RAM. FreeRTOS & stuff require some RAM for every core. Enabling the second core thus changes the amount of available RAM as well as the location/layout of used/available RAM. My bet would be on some kind of memory corruption going on.
Differences in timing might also be relevant, but unlikely here. Power consumption is of course slightly higher with two cores up.
