esptool fails sporadically, idf.py flash required
vbpieter
Postby vbpieter » Thu Jul 23, 2026 12:18 pm
After flashing ~150 custom ESP32C3 boards, 5 fail to connect using https://github.com/espressif/esptool v5.3.0/v5.3.1
They either: throw 'Possible serial noise or corruption (0x45)', 'Guru Meditation Error (illegal instruction)' or hangs after 'Running stub flasher...'
But flashing with https://github.com/espressif/esp-idf v5.5.5 `idf.py flash` works and after this successful flash, the esptool works as expected.
Any idea why this is the case?
jarda-burian
Re: esptool fails sporadically, idf.py flash required
Postby jarda-burian » Fri Jul 24, 2026 7:40 am
Hello @vbpieter, can you please tell me if you use UART or USB-Serial-JTAG for flashing? Also esptool version you have in the esp-idf v5.5.5, thanks.
vbpieter
Postby vbpieter » Fri Jul 24, 2026 8:24 am
We're using USB to flash.
The esptool.py bundled with ESP-IDF 5.5.5 is v4.12.0
jarda-burian
Postby jarda-burian » Sun Jul 26, 2026 9:59 pm
Can you please try esptool --no-stub option to see if that is the issue? V4 esptool always works and V5 always fails? If only stub fails I have a suspicion that CPU clock increase is the root cause, I can fix that quite soon, but need it to be tested if possible. If you are willing to try, can you please open issue in https://github.com/espressif/esp-flasher-stub? Only if the --no-stub works, thanks.
Users browsing this forum: Semrush [Bot] and 2 guests
