I am wondering if someone already developed a set of makes to allow that happen.
I really don't want to use the Arduino IDE, and I am wondering if I there is a set of makefiles that could enable command line development.
THanks!
Arduino Dev without Arduino IDE using makefiles
Re: Arduino Dev without Arduino IDE using makefiles
It's not quite the same thing, but the Arduino core for ESP32 libraries is available as a component in esp-idf.
So if you add the arduino-esp32 repository a "components" directory inside an esp-idf project, you can use Arduino functions and code inside your esp-idf project (built with make.)
http://github.com/espressif/esp-idf
https://github.com/espressif/arduino-esp32
Angus
Angus
Not sure if this is exactly what you are after but you can use the excellent http://eclipse.baeyens.it/ Eclipse Arduino plugin. It will allow you to write code for the esp32, using arduino cores, but in a modern IDE.
Edit:
Why wouldn't this work ?
http://playground.arduino.cc/Learning/CommandLine
Install the cores via the usual methods and the use platformio or the other methods on that page
Edit:
Thanks to all for the answers.
I like the approach of using Arduino wrappers as a "component", since it does not add any extra dependency, and it seems inline with everything else.
But, I downloaded bot gits, and inside esp-idf "components" folder, I added a syslink to the "arduino-esp32", but something is not working correctly.
The "clean" target of make seems to work, but I can't build. Nothing happpens.
ESP-IDF/components/arduino
^---------- syslink to arduino-esp32
Any help on what I may be doing wrong, I would appreciate.
Rosimildo.
Rosimildo.
- ESP_Me-no-dev
Yes, thanks
Without the SysLink it works!
Thanks to all for the help!
