ESP32 connect to mysql database
tullaMann
Postby tullaMann » Sun Mar 11, 2018 8:57 pm
Hallo,
i'm new her. I can`t find a solution for my problem. I use a esp8266 with the esp8266wifi.h and the mysql_connection.h and mysql_coursor.h in my scripts.
And now i want make the same with the esp32, but donsn`t work. I can`t include the wifi.h and the two classes from mysql_ .
He set a exception
Arduino: 1.8.5 (Windows 10), Board: "ESP32 Dev Module, QIO, 80MHz, 4MB (32Mb), 921600, None"
Arduino\libraries\MySQL_Connector_Arduino-master\src\old\MySQL_Connection.cpp: In member function 'boolean MySQL_Connection::connect(IPAddress, int, char*, char*)':
\Arduino\libraries\MySQL_Connector_Arduino-master\src\old\MySQL_Connection.cpp:74:25: error: 'check_ok_packet' was not declared in this scope
if (check_ok_packet() != 0) {
the sketch for this:
// LOAD CLASSES
#include "time.h"
#include <TimeAlarms.h>
#include <MySQL_Connection.h>
#include <MySQL_Cursor.h>
#include <WiFi.h>
//LOAD CONFIGRATION
#include "default.h"
#include "setup.h"
#include "db.h"
WiFiServer  server(80);
void setup(){
  //DEFINE IO's
  pinMode(ACTIV_LED, OUTPUT);
  pinMode(ACTION_LINE1, INPUT);
  pinMode(ACTION_LINE2, INPUT);
  pinMode(ACTION_LINE3, INPUT);
  pinMode(ACTION_LINE4, INPUT);
  pinMode(ACTIVELINE1, OUTPUT);
  pinMode(ACTIVELINE2, OUTPUT);
  pinMode(ACTIVELINE3, OUTPUT);
  pinMode(ACTIVELINE4, OUTPUT);
  pinMode(ALARM_ACTIV, OUTPUT);
  //ACTIVATE SERIAL MONITORING
  delay(10);
  Serial.println("setup - ok");
  Serial.println("connect to the network... ");
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  delay(2000);
    delay(500);
    Serial.print(".");
   Serial.println(" connection established !");
   Serial.println("\n read timestamp from ntpServer ...");
   configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
   printLocalTime();
   getConfiguration();
void loop(){
Anyone can help me?
ikram.benabd
Re: ESP32 connect to mysql database
Postby ikram.benabd » Wed Mar 14, 2018 11:30 am
did you find a solution ???
tullaMann
Postby tullaMann » Thu Mar 15, 2018 5:11 pm
No, sorry!
I hav a another version with php an json.
I read the data from database per php und print it as json argument in the html.
The esp32 read this file and get the data for declare the variable..
if you are interest it, i write the code her. but`s not really the result for this conent.
phscar_skuldtec
Postby phscar_skuldtec » Mon Feb 10, 2020 1:16 pm
I found a solution that worked in my case.
I use the following code
#include <WiFi.h>
const char* ssid = "your wifi name";
const char* password = "your wifi password";
char user[] = "root"; // MySQL user login username
char passwordSQL[] = ""; // MySQL user login password
char INSERT_SQL[] = "INSERT INTO dbi.PARAMETRO(CANTEIRO, TIPO, HORA_INICIO, HORA_FIM, UMIDADE_INICIO, UMIDADE_FIM) VALUES ('CENTRAL ESP32', 'UMIDADE', '11:00:00', '12:30:00', '50', '70');";
IPAddress server_addr(your MySQL ip like (8, 8, 8, 8); // IP of the MySQL server here
  //Código de configuração aqui
  connectToNetwork();
  mySqlLoop();
void connectToNetwork() {
    delay(1000);
    Serial.println("Establishing connection to WiFi..");
  Serial.println("Connected to network");
void mySqlLoop(){
  WiFiClient client;
  MySQL_Connection conn((Client *)&client);
  if (conn.connect(server_addr, 3306, user, passwordSQL)) {
    Serial.println("Database connected.");
  else{
    Serial.println("Connection failed.");
    Serial.println("Recording data.");
  // Initiate the query class instance
  MySQL_Cursor *cur_mem = new MySQL_Cursor(&conn);
  // Execute the query
  cur_mem->execute(INSERT_SQL);
  // Note: since there are no results, we do not need to read any data
  // Deleting the cursor also frees up memory used
  delete cur_mem;
  Serial.println("closing connection\n");
  //client.stop();
Work with MariaDB in xampp, and use direct connection without php neither json, just esp32 with arduino IDE
References: https://github.com/ChuckBell/MySQL_Conn ... issues/114
https://techtutorialsx.com/2017/06/29/e ... with-wifi/
arge06
Postby arge06 » Thu May 13, 2021 4:34 pm
Hi, with your code insert works well, did you manage to use select query with wifi ? Thanks in advance.
asifuz
Postby asifuz » Tue Feb 27, 2024 8:54 pm
So my code didn't working?
It don't even connect to the database? Why???
this is the code:
#include <WiFi.h>
const int soilMoisturePin = 34; // Replace with your actual pin
int soilMoistureValue;
const char *ssid = "JANINA";
const char *password = "sayma01720";
const char *host = "localhost";
const char *user = "fafafa";
const char *password_mysql = "Asif@0172";
const char *database = "dibl_projects";
IPAddress server_addr(44,206,65,171); // Replace with your MySQL server IP address
WiFiClient client;
    delay(1000);
    // Connect to Wi-Fi
        delay(1000);
        Serial.println("Connecting to WiFi...");
    Serial.println("Connected to WiFi");
    // Connect to MySQL database
    Serial.println("Connecting to MySQL Server...");
    if (conn.connect(server_addr, 3306, const_cast<char*>(user), const_cast<char*>(password_mysql), const_cast<char*>(database))) {
        Serial.println("MySQL Connected!");
        return;
    pinMode(soilMoisturePin, INPUT);
    soilMoistureValue = analogRead(soilMoisturePin);
    int moisturePercentage = map(soilMoistureValue, 0, 4095, 0, 100);
    if (isnan(moisturePercentage)) {
        Serial.println("Failed to read moisture data!");
        return;
    Serial.println("Moisture Percentage: " + String(moisturePercentage));
    updateDatabase(moisturePercentage);
    delay(2000); // Adjust delay as needed
void updateDatabase(int moisturePercentage) {
    String query = "UPDATE phec_livedata SET ph_value='" + String(moisturePercentage) + "' WHERE user_id=3";
    Serial.println("Query: " + query);
    cur_mem->execute(query.c_str());
    delete cur_mem;
grellclaus
Postby grellclaus » Sat Mar 02, 2024 1:25 pm
Hi asifuz
Did you find a soulution? I'm having the same problem.
if (conn.connect(server_addr, 3306, user, password)) {
delay(1000);
The terminal just keep saying "...trying..."
Claus
Aguilaaar
Postby Aguilaaar » Tue Jul 16, 2024 4:28 pm
Hi, has anyone found a solution to this problem? or can you point me to a different library for MySQL with google cloud...
I'm also getting "trying..." and I don't know what else to do.
Users browsing this forum: Baidu [Spider] and 3 guests
