ECO and Workarounds for Bugs in ESP32 This document details the silicon errata and workarounds for the ESP32.
PDF V 1.0 from 18. Nov 2016
be sure you allways check espressif resource for update information too
rudi
How is it possible for any ESP32 development board or module to function properly if the spurious reset on power up (I am seeing this on my board) cannot be worked around in software? Does this mean the 100 ESP32 chips i just bought are garbage? This is quite frustrating.
if you mean your other post..
The issue you seem to be having (judging from your other post) is related to the fact that after the initial RTCWDT reset the ESP32 can not load program from flash memory. I suggest that we proceed to troubleshoot that in the other topic you have opened or in the Github issue (i assume it is also opened by you).
Not sure is this general :I don't see register write bug mentioned about CAN peripheral listed in document.
perhabs we note this here for keep this in mind as a possible "workaround" :.. I'm not sure if the CAN controller is affected by this, but it may be good to keep this in mind...
and the next revision of the docu can append this then.if you write the registers too quickly, the 2nd write may be discarded.
This can be alleviated by putting aline between writes, if memory serves.Code: Select all
__asm__ __volatile__("nop;nop;nop;nop;nop;nop;nop;nop;");
Users browsing this forum: Applebot, PetalBot, Semrush [Bot] and 2 guests
