Using timerAttachInterrupt inside a library
dalvikvm
Postby dalvikvm » Wed Mar 14, 2018 7:19 am
I moved most of my code to a library but one particular function call gives me an error when compiling.
This is the function needed for the timerAttachInterrupt():
void IRAM_ATTR TriggerTimer::cdInterrupt(){
 //some codes
This is how I used the attachTimerInterrupt() function:
void TriggerTimer::startTimer(){
  timer = timerBegin(0, 80, true);
  timerAttachInterrupt(timer, &cdInterrupt, true);
  timerAlarmWrite(timer, 1000000, true);
  timerAlarmEnable(timer);
The compiler forbids me taking the address of an unqualified or parenthesized non-static member function to form a pointer to member function. It suggests me to use &TriggerTimer::cdInterrupt as a parameters which also gives me an error because the timerAttachInterrupt expects void(*)() and not void(TriggerTimer*)(). How do I solve this problem?
dalvikvm
Re: Using timerAttachInterrupt inside a library
Postby dalvikvm » Fri Mar 16, 2018 3:13 am
I was able to fix it by making the function static in the header file.
Users browsing this forum: ChatGPT-User, PetalBot and 1 guest
