Re-enable of interrupt is not working
Tushar Kanani
Postby Tushar Kanani » Wed Apr 04, 2018 3:53 am
I am working on Interrupt. I need to disable and enable the interrupt run time.
Here is a piece of code that I am using to initialize the interrupt.
#define GPIO_1 GPIO_NUM_25
gpio_set_direction(GPIO_1, GPIO_MODE_INPUT);
  gpio_set_pull_mode(GPIO_1,  GPIO_PULLUP_ONLY);
  attachInterrupt(digitalPinToInterrupt(GPIO_1), sw1_isr, CHANGE);
At some point of time I meed to disable the interrupt, for that I used.
gpio_intr_disable(GPIO_1);
And after some time I need to re-enable it again.I do it using,
gpio_intr_enable(GPIO_1);
But I found that, Once I disable the interrupt. I am not able to detect is even after I have enabled it as a mention.
WiFive
Re: Re-enable of interrupt is not working
Postby WiFive » Wed Apr 04, 2018 11:47 pm
Are you enabling it from a task running on a different core?
Tushar Kanani
Postby Tushar Kanani » Thu Apr 05, 2018 3:35 am
Thanks for response.
I am new to esp32 so, don't know how to make sure that "enabling it from a task running on a different core?"
But by another method, I am able to make it work as below.
gpio_set_intr_type(GPIO_1, GPIO_INTR_DISABLE);
and
gpio_set_intr_type(GPIO_1, GPIO_INTR_ANYEDGE);
insted of
and
Thanks.
