Re: Steps to install Arduino ESP32 support on Windows
don.vukovic
Postby don.vukovic » Wed Apr 04, 2018 3:22 pm
I followed the instructions of this above web page, but have hit a problem I do not understand what to do next.
The line says:
open a Git Bash session pointing to ARDUINO_SKETCHBOOK_DIR and execute git submodule update --init --recursive
$ git submodule update --init --recursive
fatal: Not a git repository (or any of the parent directories): .git
I opened the Arduino IDE and checked the location of the : ARDUINO_SKETCHBOOK_DIR
Looks right to me.
How was the ARDUINO_SKETCHBOOK_DIR set to start with ?
Did I miss something in the instructions ?
What should I do now ?
kolban
Postby kolban » Wed Apr 04, 2018 4:14 pm
Howdy,
I didn't see a link to the instructions you referenced in your post. Could post a link? Maybe then we will have context to understand the context of the command. The error message seems to tell me that the directory in which you are running git does not contain a git project. Perhaps you ran a git clone and then did not change into the newly created directory?
Postby Sprite » Thu Apr 05, 2018 2:27 am
My guess is that you need to change directory (using the cd command) to the directory ARDUINO_SKETCHBOOK_DIR gives you first.
don.vukovic
Postby don.vukovic » Thu Apr 05, 2018 4:59 am
What command do I use to get BASH to tell me what ARDUINO_SKETCHBOOK_DIR is defined as ?
What command do I use to find what ARDUINO_SKETCHBOOK_DIR is defined as ?
How do I get BASH to tell me what ARDUINO_SKETCHBOOK_DIR looks like to it (BASH) ?
Is there a BASH command to tell me what it thinks ARDUINO_SKETCHBOOK_DIR is defined as ?
chegewara
Postby chegewara » Thu Apr 05, 2018 5:19 am
If you have arduino-ide installed with standard settings then this is folder you are looking for:
C:\Users\USER_NAME\Documents\Arduino\hardware\espressif\esp32
don.vukovic
Postby don.vukovic » Thu Apr 05, 2018 8:53 pm
OK,
I do have the Arduino IDE installed.
In Arduino Preferences -> Sketchbook location is: C:\Users\Donald\Documents\Arduino
The directory you shown: C:\Users\USER_NAME\Documents\Arduino\hardware\espressif\esp32
So if I understand, the esp32 sketchbook location is in the \hardware\espressif\esp32 directory
and not in the Arduino sketchbook location.
OK, I'll try it.
don.vukovic
Postby don.vukovic » Thu Apr 05, 2018 9:10 pm
@chegewara
This did not return anything on the Bash screen, but there are now a library directory in the:
C:\Users\USER_NAME\Documents\Arduino\hardware\espressif\esp32 path.
Thank You
Don
PS: I also noticed in the Bash window, the word (master):
Donald@Donald-PC MINGW64 ~/Documents/Arduino/hardware/espressif/esp32 (master)
Learn something new everyday !!
chegewara
Postby chegewara » Fri Apr 06, 2018 11:57 am
I dont understand why you are using MINGW with arduino-ide, easier is to use cmd on windows.
don.vukovic
Postby don.vukovic » Fri Apr 06, 2018 1:48 pm
