use (swap) static IRAM for static DRAM
davdav
Postby davdav » Wed Apr 18, 2018 2:11 pm
Hi everybody,
If I ask "make size" for my project I have the following:
Total sizes:
 DRAM .data size:   16444 bytes
 DRAM .bss  size:   74192 bytes
Used static DRAM:   90636 bytes (  24564 available, 78.7% used)
Used static IRAM:   85692 bytes (  45380 available, 65.4% used)
      Flash code:  747670 bytes
    Flash rodata:  198844 bytes
Total image size:~1048650 bytes (.bin may be padded larger)
I would like to use some of the static IRAM for DRAM. How can I do this? Or, is there a pragma for the compiler to inform that a variable (not a function) should be allocated in IRAM segment?
kolban
Re: use (swap) static IRAM for static DRAM
Postby kolban » Thu Apr 19, 2018 12:25 am
If we look at table 3 in the ESP32 Technical Reference Manual we see that there appears to be 128K pre-allocated to instruction ram (IRAM) between address range 0x4008 0000 and 0x4009 FFFF ... known as SRAM 0. If I were to guess, I'd say that this 128K is fixed for the purpose of instruction RAM with no obvious options to make it available in the DRAM address space.
Angus
Postby Angus » Thu Apr 19, 2018 5:42 am
Hi dav,
The IRAM_ATTR attribute which places code into IRAM can also be used to place static variables in IRAM:
http://esp-idf.readthedocs.io/en/latest ... uction-ram
You can also dynamically allocate from IRAM by using function calls like heap_caps_malloc(MALLOC_CAP_32BIT, size). More details here:
http://esp-idf.readthedocs.io/en/latest ... ecial-uses
(Note that all accesses to/from data in IRAM has to be 32-bit aligned word reads/writes or your program will crash with a fatal exception.)
davdav
[SOLVED] Re: use (swap) static IRAM for static DRAM
Postby davdav » Thu Apr 19, 2018 10:17 am
Thanks @Kolban and @ESP_Angus.
Static allocation with IRAM_ATTR works perfectly.
I need to figure out how to use dynamic allocation in particular the 32-bit access part in case I have "non-32 bit variable"
Anyway the question is solved.
davdav
Postby davdav » Thu Apr 19, 2018 2:38 pm
Sorry @ESP_Angus, probably I didn't understand last part of your post
Is it referred only to dynamic allocation or is it true also for static variables?
I have a variable defined as:
IRAM_ATTR MyType_struct Config;
where "MyType_struct" is a structure containg char, int, ecc...
typedef struct {
    	uint8_t	active;
    	char	master[16];
    	char	slave2[16];
    	char	slave3[16];
    	uint16_t slave_tag;
    }MyType_struct ;
As soon as I access the variable like
 memset(Config.master, 0x0, sizeof(Config.master));
I have a crash (I guess as you wrote)
Guru Meditation Error: Core  0 panic'ed (LoadStoreError)
How can I access with 32-bit aligned?
kolban
Postby kolban » Thu Apr 19, 2018 2:51 pm
My loose thinking is that you should think of each memory location as having an address ... for example:
A0 A1 A2 A3 A4 .....
For the IRAM data, you can only read and write data at addresses that are evenly dividable by 4 for example ...
0 4 8 12 16 20 ...
If I understand correctly, data on the instruction bus is read in units of 32bits ... 32 bits = 4 bytes. So "logically" instead of thinking of the memory as units of 8 bits, we "could" think of the memory as units of 32bits but still addressed by bytes.
So...
Unit 0 of IRAM can be found at address 0
Unit 1 of IRAM can be found at address 4
Unit 2 of IRAM can be found at address 8
If we ask IRAM to retrieve the unit of data found at address 1, 2, or 3 ... this has no meaning ... and an exception is thrown.
(my words are loose here).
davdav
Postby davdav » Fri Apr 20, 2018 9:03 am
Thanks @Kolban, your explanation is correct and I understand that a 32-bit access means that I can only "read 4 bytes at a time".
My problem is "operative": how to do that?
Just to let it simple: If I have a char array
IRAM_ATTR char Test[10];
How can I write/access it?
-Should I take care to pad it (in practice declare the variable as multiple of 4)?
IRAM_ATTR char Test[12];
-Should I declare it as an array of uint32_t (waste of memory)?
IRAM_ATTR uint32_t Test[10];
In practice, is there an example to understand how to manage this case? I have searched on all esp-idf components folder and the only use of IRAM_ATTR with static variable is here:
\esp\esp-idf\components\driver\test\test_spi_master.c
IRAM_ATTR  static uint32_t data_iram[320];
but it doesn't help so much. Also google didn't give any result.
Can someone provide an example of use a static variable placed in IRAM segment?
Users browsing this forum: Baidu [Spider], Bytespider and 2 guests
