How to reinitialize BLE?
vonnieda
Postby vonnieda » Wed Apr 18, 2018 5:25 pm
Hi folks,
I'm trying to reinitialize (shutdown, restart) BLE and every method I try seems to cause an assert or crash. Is there any documentation anywhere that describes the right sequence of calls to bring down BLE after having brought it up and initialized a GATTS service?
My init process looks like this:
esp_bt_controller_mem_release(ESP_BT_MODE_CLASSIC_BT);
esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
esp_bt_controller_init(&bt_cfg);
esp_bt_controller_enable(ESP_BT_MODE_BLE))
esp_bluedroid_init())
esp_bluedroid_enable())
esp_ble_gap_register_callback(gap_event_handler))
esp_ble_gatts_register_callback(gatts_event_handler))
esp_ble_gatts_app_register(0))
esp_ble_gatt_set_local_mtu(500))
esp_ble_gap_start_advertising(&adv_params);
If I try to run those in reverse, like this:
esp_ble_gap_disconnect(connected_device_address);
esp_ble_gap_stop_advertising();
esp_ble_gatts_stop_service(gl_profile.service_handle);
esp_ble_gatts_delete_service(gl_profile.service_handle);
esp_ble_gatts_app_unregister(gl_profile.gatts_if);
esp_bluedroid_disable();
esp_bluedroid_deinit();
esp_bt_controller_disable();
esp_bt_controller_deinit();
I get:
assertion "config != NULL" failed: file "/Users/jason/esp/esp-idf/components/bt/bluedroid/btc/core/btc_config.c", line 312, function: btc_config_flush
abort() was called at PC 0x400f097f on core 0
0x400f097f: __assert_func at /home/jeroen/esp8266/esp32/newlib_xtensa-2.2.0-bin/newlib_xtensa-2.2.0/xtensa-esp32-elf/newlib/libc/stdlib/../../../.././newlib/libc/stdlib/assert.c:63 (discriminator 8)
Backtrace: 0x400967fc:0x3ffb3bf0 0x400969f7:0x3ffb3c10 0x400f097f:0x3ffb3c30 0x401310f2:0x3ffb3c60 0x40131103:0x3ffb3c80 0x4011916f:0x3ffb3ca0 0x401191b4:0x3ffb3cc0 0x40119245:0x3ffb3ce0
0x400967fc: invoke_abort at /Users/jason/esp/esp-idf/components/esp32/./panic.c:648
0x400969f7: abort at /Users/jason/esp/esp-idf/components/esp32/./panic.c:648
0x401310f2: btc_config_flush at /Users/jason/esp/esp-idf/components/bt/bluedroid/btc/core/btc_config.c:329
0x40131103: btc_config_shut_down at /Users/jason/esp/esp-idf/components/bt/bluedroid/btc/core/btc_config.c:329
0x4011916f: btc_disable_bluetooth at /Users/jason/esp/esp-idf/components/bt/bluedroid/btc/core/btc_main.c:47
0x401191b4: btc_main_call_handler at /Users/jason/esp/esp-idf/components/bt/bluedroid/btc/core/btc_main.c:105
0x40119245: btc_task at /Users/jason/esp/esp-idf/components/bt/bluedroid/btc/core/btc_task.c:101
The offending call seems to be esp_bluedroid_disable().
So, can anyone point me to information about how to properly shutdown and restart BLE?
Thanks,
Jason
kolban
Re: How to reinitialize BLE?
Postby kolban » Thu Apr 19, 2018 12:08 am
I may be completely off target here ... but a thought strikes me. Some of those commands may be asynchronous meaning that when you request something to be done, it is not immediately performed before return but instead you are notified by an event by callback when it is complete. Could it be that you have to wait for indication that the previous esp_ble_* function has completed before performing the next command?
vonnieda
Postby vonnieda » Thu Apr 19, 2018 9:27 pm
Hi kolban,
Thank you for your response. Your comment helped me get a little further, but I'm still stuck. I was able to finish the de-init process by moving some of the calls to the gatts_event_handler, but now when I try to re-initialize I get a number of errors.
I also found in the documentation that esp_bt_controller_deinit() is not really finished: "This function is not whole completed, esp_bt_controller_init cannot called after this function."
If I remove that call, then I get an error 0x0103 on esp_bt_controller_enable(ESP_BT_MODE_BLE), and if I remove that call I get an error 0x0103 on esp_bluedroid_init().
So, I'll repeat my question: Does anyone know how to correctly shutdown and then restart BLE?
sammaeliv
Postby sammaeliv » Mon Aug 10, 2020 6:09 am
im looking for the same thing i was able to stop ble to send http info so now i cant turn on ble again ...
i use this
[Codebox]
[/Codebox]
Gautier
Postby Gautier » Tue Aug 11, 2020 5:25 am
I'm working on patterns to reduce power and working on shutting down BLE but not putting chip to sleep. I am successfully shutting down bt radio I believe but struggling to bring back up the ble services.
I'm wondering what the suggested steps would be. I'm using ble server, callback and advertising.
chegewara
Postby chegewara » Tue Aug 11, 2020 12:44 pm
This is about bluetooth light sleep, not init/re-init bt, but maybe help you:
https://github.com/espressif/esp-idf/is ... -500312453
Ritesh
Contact:
Postby Ritesh » Sat Apr 05, 2025 10:59 am
Hello Team,
We are also facing issues to deinit and again init BLE Bluedroid Stack as per requirement. We are using ESP IDF 5.0 into our code.
Let me know if anyone has found any fix regarding this issue then let me know steps for the same.
Regards,
Ritesh Prajapati
Regards,
Ritesh Prajapati
Ritesh
Contact:
Postby Ritesh » Mon May 05, 2025 6:26 am
Hello Team,
We got success to deinit BLE successfully with the help of Espressif Team.
Thanks a lot to Espressif Distributer India Rabyte Team for your help and support to resolve it.
Below is code snippet which you can use into your application as per requirement.
esp_err_t Bluetooth_Deinitialize(void)
    esp_ble_gatts_stop_service(GlProfileTab[PROFILE_A_APP_ID].service_handle);
    esp_ble_gatts_delete_service(GlProfileTab[PROFILE_A_APP_ID].service_handle);
    esp_ble_gatts_app_unregister(GlProfileTab[PROFILE_A_APP_ID].gatts_if);
    esp_err_t ret = ESP_OK;
    ret = esp_bluedroid_disable();
    if (ret != ESP_OK) {
        printf("esp_bluedroid_disable FAILED = %d\n", ret);
        return ret;
    ret = esp_bluedroid_deinit();
        printf("esp_bluedroid_deinit FAILED = %d\n", ret);
        return ret;
    ret = esp_bt_controller_disable();
        printf("esp_bt_controller_disable FAILED = %d\n", ret);
        return ret;
    ret = esp_bt_controller_deinit();
        printf("esp_bt_controller_deinit FAILED = %d\n", ret);
        return ret;
    ret = esp_bt_controller_mem_release(ESP_BT_MODE_BLE);
        printf("esp_bt_controller_mem_release FAILED = %d\n", ret);
        return ret;
    return ret;
Regards,
Ritesh Prajapati
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 2 guests
