Esp32 Led won't stop blinking if external power are used
Posted: Fri Apr 20, 2018 12:25 am
by paulohz2
Hi, I'm new here and also with the esp32.
I acquired two pieces not long ago and started playing with them. And now I'm having a problem with them, when I use an external power supply that's not usb, the led starts blinking and won't stop, and the program also won't run. If I use the usb, it works flawless. Anyone could help me with that?
Thanks!!!
Re: Esp32 Led won't stop blinking if external power are used
Posted: Fri Apr 20, 2018 12:56 am
by Sprite
What type of external power supply do you use and how is it connected? The ESP32 needs a power source that can source at least 500mA to function well.
Posted: Fri Apr 20, 2018 9:08 pm
by paulohz2
I tried some like 9v battery (with voltage regulator), 4 batteries (1,5v each) and 5v 700mah phone charger. None worked, only usb supply. BUT now I've tried the blink code on them, and it worked with those supplies, but the last code won't work. It's a bluetooth communication to control a robot car with a smartphone (l298n, esp32, 2 dc motors).
Posted: Mon Mar 04, 2019 9:41 pm
by jackdew22
To anyone having problems like this with the DevkitC board make sure to use another GND pin besides the one next to 5V and the reset button. I wasted hours debugging this issue using the wrong GND.. simply switching to the one 5 pins down fixed everything!
Posted: Fri May 03, 2019 3:39 pm
by kennycoder
Thanks a lot mate. You saved me quite some time! Indeed its a stupid missprint on some boards. Should be CMD and not GND.. who knows how this passed QC.
Anyway thanks again, owe you a beer.
Posted: Mon Dec 09, 2024 8:35 am
by saumik
But all other GND are not shorted with this pin. I was trying to control brushed motor using esp32 and a03400. whenever i am checking the voltage connecting it to usb it is all good, but powering with 3.7 v battery and booster it is not working also it is is continuously blinking. What should i do?
