I have physically remove the led with a solder iron and it works fine.
I've also try to powered my esp32 dev kit (DOIT) with first a 3,7v battery (18650 - 3,7v - 4A) without removed the power led and the battery died after 4-5 days
https://www.banggood.com/fr/2PCS-MECO-3 ... 92718.html
I try with a 9v battery (the board was heating) after removed the power led and the battery died after 2 days
https://www.amazon.fr/gp/product/B00MH4 ... UTF8&psc=1
I try this two solutions with the same scenario :
ESPEasy Firmware with a DS18B20, and 1hour deep sleep, with 15sec awake between each deep sleep.
Connection to a broker MQTT by WiFi and send temperature data during the 15sec awake.
I don't understand which consumes so much energy and how I can reduce this consumption.
- Change firmware (ESP-IDF maybe) ?
- Add a voltage regulator and powered the board with 5v or 3.3v instead of the VIN pin ?
- Use a board with integrated battery port ? (like lolin32 with LiPo or lolin32 with Li Ion battery (18650))
https://www.banggood.com/fr/WeMos-WiFi- ... 64436.html
https://www.banggood.com/fr/WeMos-LOLIN ... 64252.html
- Use a specific power booster like this :
https://www.banggood.com/fr/Wemos-18650 ... 30963.html
- Increase the deep sleep ?
- Reduce awake time ?
If you have any idea
