How would one do the writing of EFUSE BLOCK 1/2/3 and then the reading of EFUSE BLOCK 1/2/3 (to check that the write was successful) in esp-idf?
I'm well aware of:
1. https://github.com/espressif/esp-idf/bl ... sp_efuse.h
2. https://github.com/espressif/esp-idf/bl ... om/efuse.h
3. viewtopic.php?f=13&t=2976
4. Technical Reference Manual chapter 19: eFuse Controller
Using espefuse.py to do so, is quite simple and straight forward as described over here: https://github.com/espressif/esptool/wiki/espefuse
However, doing so in esp-idf, proves a bit challenging, especially if you consider that the API referenced at 1 and 2 comes with no real example at all. Thus, the risk of bricking the ESP32 is quite high, if i go by trial and error.
Any esp-idf example code would be of great help!
EFUSE read/write BLOCK 1/2/3 from esp-idf
Re: EFUSE read/write BLOCK 1/2/3 from esp-idf
https://github.com/espressif/esp-idf/bl ... .c#L56-L58
https://github.com/espressif/esp-idf/bl ... .c#L83-L89
The only potential issue is
andWhen the value of BLK3_part_reserve is 1, coding_schemeBLOCK1BLOCK2 and BLOCK3 are controlled by 3/4 coding scheme. Meanwhile, BLOCK3[143 : 96], namely, eBLOCK3[191 : 128] is unavailable.
and there is no support for writing encoded parameters yet. I am not entirely sure how flash encryption and 3/4 coding scheme works. Are key lengths reduced?ESP32s with both Two Point Values and Vref burned into eFuse are required to also burn the EFUSE_BLK3_PART_RESERVE flag
@WiFive
Thank you sir!
That was exactly what I was looking for.
What's the main difference between calling:
and
They both seem to do the same thing.
In case anyone is looking for the esp-idf code I'm pasting it bellow and also attaching it to this reply.
Thank you sir!
REG_SET_FIELD(RTC_CNTL_SDIO_CONF_REG, RTC_CNTL_XPD_SDIO_REG, 1);Code: Select all
REG_WRITE(EFUSE_BLK0_WDATA4_REG, EFUSE_RD_XPD_SDIO_REG);In case anyone is looking for the esp-idf code I'm pasting it bellow and also attaching it to this reply.
#include <stdio.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_spi_flash.h"
#include "driver/gpio.h"
#include "sdkconfig.h"
#include "driver/periph_ctrl.h"
#include "soc/rtc_cntl_reg.h"
#include "rom/efuse.h"
#include "soc/efuse_reg.h"
#include "soc/soc.h"
#include "esp_efuse.h"
#include "esp_log.h"
static const char *TAG = "efuse";
void app_main()
bool burned = false;
printf("\nWarning! Once the eFuses are burned you cannot revert back!");
vTaskDelay(5000 / portTICK_PERIOD_MS);
//BLOCK3 is user reserved
//You can write whatever you want here.
//burning BLOCK3 bit0
if (!!(REG_READ(EFUSE_BLK3_RDATA0_REG) & BIT0) == 0) { //check if eFuse was previously burned (if not burned eFuse == 0)
ESP_EARLY_LOGI(TAG, "\nBurning BLOCK3 bit0 fuse to 1");
esp_efuse_reset();
REG_WRITE(EFUSE_BLK3_WDATA0_REG, BIT0);
esp_efuse_burn_new_values();
burned = true;
}else{
printf("\nBLOCK3 BIT0 already burned");
//Warning!!!
//Burning SDIO_FORCE and SDIO_REG will permanently set the flash voltage from 3.3V to 1.8V
//burning SDIO_FORCE
if (!!(REG_READ(EFUSE_BLK0_RDATA4_REG) & EFUSE_RD_SDIO_FORCE) == 0) {
ESP_EARLY_LOGI(TAG, "\nBurning EFUSE_BLK0_WDATA4_RE fuse EFUSE_RD_SDIO_FORCE to 1");
esp_efuse_reset();
REG_WRITE(EFUSE_BLK0_WDATA4_REG, EFUSE_RD_SDIO_FORCE);
burned = true;
}else{
printf("\nSDIO_FORCE already burned");
//burning SDIO_REG
if (!!(REG_READ(EFUSE_BLK0_RDATA4_REG) & EFUSE_RD_XPD_SDIO_REG) == 0) {
ESP_EARLY_LOGI(TAG, "\nBurning EFUSE_BLK0_WDATA4_RE fuse EFUSE_RD_XPD_SDIO_REG to 1");
esp_efuse_reset();
burned = true;
}else{
printf("\nSDIO_REG already burned");
if(burned)
printf("\nFuses burned!\n");
for (int i = 5; i >= 0; i--) {
printf("\nRestarting in %d seconds...\n", i);
printf("\nRestarting now.\n");
fflush(stdout);
esp_restart();
- efuse.zip
- (9.39 KiB) Downloaded 767 times
Users browsing this forum: meta-externalagent and 4 guests
