smartconfig_example Not successful
Devil月哥
Postby Devil月哥 » Mon May 28, 2018 2:38 pm
I used smart_config example to debug the distribution network, which has been abnormal.
Not normal after getting the WiFi and password
ets Jun 8 2016 00:22:57
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:5528
load:0x40078000,len:0
ho 12 tail 0 room 4
load:0x40078000,len:13724
entry 0x40078fb4
I (30) boot: ESP-IDF v3.0-rc1-229-g5ee7233b-dirty 2nd stage bootloader
I (30) boot: compile time 22:17:43
I (31) boot: Enabling RNG early entropy source...
I (36) boot: SPI Speed : 40MHz
I (40) boot: SPI Mode : DIO
I (44) boot: SPI Flash Size : 2MB
I (48) boot: Partition Table:
I (52) boot: ## Label Usage Type ST Offset Length
I (59) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (67) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (74) boot: 2 factory factory app 00 00 00010000 00100000
I (82) boot: End of partition table
I (86) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x0fb00 ( 64256) map
I (117) esp_image: segment 1: paddr=0x0001fb28 vaddr=0x3ffb0000 size=0x004e8 ( 1256) load
I (118) esp_image: segment 2: paddr=0x00020018 vaddr=0x400d0018 size=0x5814c (360780) map
I (249) esp_image: segment 3: paddr=0x0007816c vaddr=0x3ffb04e8 size=0x02c48 ( 11336) load
I (254) esp_image: segment 4: paddr=0x0007adbc vaddr=0x40080000 size=0x00400 ( 1024) load
I (256) esp_image: segment 5: paddr=0x0007b1c4 vaddr=0x40080400 size=0x1123c ( 70204) load
I (293) esp_image: segment 6: paddr=0x0008c408 vaddr=0x400c0000 size=0x00000 ( 0) load
I (304) boot: Loaded app from partition at offset 0x10000
I (304) boot: Disabling RNG early entropy source...
I (305) cpu_start: Pro cpu up.
I (309) cpu_start: Starting app cpu, entry point is 0x40080f38
I (300) cpu_start: App cpu up.
I (320) heap_init: Initializing. RAM available for dynamic allocation:
I (326) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (332) heap_init: At 3FFB8FE0 len 00027020 (156 KiB): DRAM
I (338) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (345) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (351) heap_init: At 4009163C len 0000E9C4 (58 KiB): IRAM
I (357) cpu_start: Pro cpu start user code
I (40) cpu_start: Starting scheduler on PRO CPU.
I (105) wifi: wifi firmware version: c98fbd5
I (105) wifi: config NVS flash: enabled
I (105) wifi: config nano formating: disabled
I (105) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (115) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (145) wifi: Init dynamic tx buffer num: 32
I (145) wifi: Init data frame dynamic rx buffer num: 32
I (145) wifi: Init management frame dynamic rx buffer num: 32
I (145) wifi: wifi driver task: 3ffc042c, prio:23, stack:4096
I (155) wifi: Init static rx buffer num: 10
I (155) wifi: Init dynamic rx buffer num: 32
I (165) wifi: wifi power manager task: 0x3ffc506c prio: 21 stack: 2560
I (195) phy: phy_version: 366.0, ba9923d, Dec 29 2017, 14:25:06, 0, 0
I (195) wifi: mode : sta (30:ae:a4:47:53:68)
I (255) smartconfig: SC version: V2.7.2
I (5075) wifi: ic_enable_sniffer
I (5075) sc: SC_STATUS_FINDING_CHANNEL
I (9285) smartconfig: TYPE: ESPTOUCH
I (9285) sc: SC_STATUS_GETTING_SSID_PSWD
I (11885) smartconfig: F|pswd: zyhwq1314
I (11885) smartconfig: F|ssid: Yuex.S_Wi-Fi
I (11885) smartconfig: F|bssid: 8c:a6:df:d6:12:4f
I (11885) wifi: ic_disable_sniffer
I (11885) sc: SC_STATUS_LINK
I (11895) sc: SSID:Yuex.S_Wi-Fi
I (11895) sc: PASSWORD:zyhwq1314
W (11955) wifi: lmac stop, discard packet
W (12075) wifi: lmac stop, discard packet
W (12195) wifi: lmac stop, discard packet
W (12315) wifi: lmac stop, discard packet
W (12435) wifi: lmac stop, discard packet
W (12555) wifi: lmac stop, discard packet
W (12685) wifi: lmac stop, discard packet
W (12805) wifi: lmac stop, discard packet
W (12925) wifi: lmac stop, discard packet
W (13045) wifi: lmac stop, discard packet
W (13165) wifi: lmac stop, discard packet
I (13285) wifi: n:11 2, o:1 0, ap:255 255, sta:11 2, prof:1
I (14265) wifi: state: init -> auth (b0)
W (14265) wifi: lmac stop, discard packet
I (15265) wifi: state: auth -> init (2)
I (15265) wifi: n:11 0, o:11 2, ap:255 255, sta:11 2, prof:1
W (15265) wifi: lmac stop, discard packet
I (15395) wifi: n:11 2, o:11 0, ap:255 255, sta:11 2, prof:1
I (15395) wifi: state: init -> auth (b0)
W (15395) wifi: lmac stop, discard packet
I (16395) wifi: state: auth -> init (2)
I (16395) wifi: n:11 0, o:11 2, ap:255 255, sta:11 2, prof:1
W (16395) wifi: lmac stop, discard packet
I (16515) wifi: n:11 2, o:11 0, ap:255 255, sta:11 2, prof:1
I (16515) wifi: state: init -> auth (b0)
W (16515) wifi: lmac stop, discard packet
I (17515) wifi: state: auth -> init (2)
I (17515) wifi: n:11 0, o:11 2, ap:255 255, sta:11 2, prof:1
W (17515) wifi: lmac stop, discard packet
I (17635) wifi: n:11 2, o:11 0, ap:255 255, sta:11 2, prof:1
I (17645) wifi: state: init -> auth (b0)
W (17645) wifi: lmac stop, discard packet
I (18645) wifi: state: auth -> init (2)
I (18645) wifi: n:11 0, o:11 2, ap:255 255, sta:11 2, prof:1
W (18645) wifi: lmac stop, discard packet
I (18765) wifi: n:11 2, o:11 0, ap:255 255, sta:11 2, prof:1
I (18765) wifi: state: init -> auth (b0)
W (18765) wifi: lmac stop, discard packet
Devil月哥
Re: smartconfig_example Not successful
Postby Devil月哥 » Mon May 28, 2018 2:39 pm
Do you have a normal test.
I don't know how you solve it
Devil月哥
Postby Devil月哥 » Mon May 28, 2018 3:34 pm
Update to [ESP-IDF v3.0-12-gdc304fb3a-dirty 2nd stage bootloader]
Now it's normal
Users browsing this forum: Bing [Bot], Bytespider, ChatGPT-User, Google [Bot] and 1 guest
