Problem with mesh with sending to socket
ogrego
Postby ogrego » Thu May 31, 2018 9:11 am
Hello, I'm currently trying to modify the mesh example: https://github.com/espressif/esp-idf/tr ... ransceiver to send a messsage to my server, without success.
I checked the API's esp_mesh_send part: http://esp-idf.readthedocs.io/en/latest ... esh_opt_ti
It says "if the packet is outgoing to external IP network such as an IP server address, translate IPv4:PORT known as “to”."
I tried with data type MESH_PROTO_BIN, MESH_PROTO_JSON, MESH_PROTO_HTTP. The data content is a simple string.
The relevant part:
mesh_addr_t serverAddr;
IP4_ADDR(&serverAddr.mip.ip4, 192,168,0,132); // 192.168.0.132 is my pc
serverAddr.mip.port = 8089; // I'm running running a python script to handle requests
esp_mesh_send(&serverAddr, &data, MESH_DATA_TODS, NULL , 0);
Full code:
https://pastebin.com/Y9nLayKa
Python socket script:
https://pastebin.com/yLjAftWc
Users browsing this forum: Bing [Bot], coccocbot, Google [Bot], meta-externalagent, Perplexity-User, PetalBot and 3 guests
