ESP32 Mesh network throughput?
dimdim
Postby dimdim » Mon Jun 11, 2018 4:08 pm
What is the ESP32 Mesh throughput?
We are planning to have around 50 devices and need at least 250kbps total throughput.
yudong
Re: ESP32 Mesh network throughput?
Postby yudong » Fri Jun 15, 2018 10:21 am
Hi dimdim,
Confirm one thing to you:
"average 5kbps per device" or "250kbps per device with same data"?
The magnitude of ESP-MESH throughput is Mbps in the unicast case.
So it could easily satisfy the first case.
dimdim
Postby dimdim » Mon Jun 18, 2018 3:21 pm
Hi yudong,
We need an average 5kbps per device.
The maximum distance will be around 50 meters.
mach_doms
Postby mach_doms » Wed Jan 09, 2019 10:06 am
I have same question related to MESH throughput....
But, I look for some indication of the capability of the ESP32 running MESH, what is the "overhead" of the ESP-MESH on the ESP32.
I found this: ESP32 Wi-Fi Throughput
Type/Throughput Air In Lab Shield-box Test Tool IDF Version (commit ID)
UDP TX 30 MBit/sec 60 MBit/sec iperf example 05838641
What can I expect of throughput, maybe considering x number of hops?
What can I expect of throughput, best case?
Thanks....
