Hi boss, I'm adding mqtt feature in ESP32 SDK but found some compatible issues when using it with mosquitto server. Does anyone know which version of esp-mqtt is good enough to use in customer's project? Now I am using https://github.com/tuanpmt/esp32-mqtt
thanks a lot.
MQTT support in latest ESP32 SDK
Nespressif
xiangcheng
Re: MQTT support in latest ESP32 SDK
Thanks a lot. Would you please tell me if this MQTT client version match with mosquitto? Which MQTT server do you recommend to use for testing? I'm porting it on my SDK but not ready for test yet.
The library works fine with the latest Mosquitto V1.4.14Thanks a lot. Would you please tell me if this MQTT client version match with mosquitto? Which MQTT server do you recommend to use for testing? I'm porting it on my SDK but not ready for test yet.
Paul.
Paul.
Users browsing this forum: Bytespider, DuckDuckGo [Bot], PerplexityBot, Semrush [Bot], YisouSpider and 7 guests
