esp-idf or esp-iot-solution?
12pastnoon
The getting started guide for ESP-WROVER-KIT instructs to install esp-idf. I see that there is also esp-iot-solution, which includes esp-idf as a submodule. Is it better to get that instead? Getting started guide seems to make no mention of it.
Re: esp-idf or esp-iot-solution?
The esp-iot-solution provides a range of solutions, functions and drivers intended for IOT applications.
Review these solutions, functions and drivers, if this is what you may need in your projects.
Same with esp-adf, that is focused on using ESP32 for audio applications, or esp-mdf, that provides application examples using mesh networking.
All these repositories use esp-idf as a submodule. If none of your projects fall into the above categories, then get plain esp-idf.
12pastnoon
Users browsing this forum: Amazon [Bot], Google [Bot], PerplexityBot, PetalBot and 8 guests
