I have a problem when try to use GPIO INPUT ONLY pins. I'm using DHT22 to do some tests in Esp32 boards. When I use GPIO normal pins I have correct informatios in serial monitor. But when I use pins INPUT ONLY all informations about temperature and humidity are ZERO. I tryed to use a pullup resistor un data pin, I used digitalread() and nothing.
I have been using ARDUINO IDE.
I did tests with others sensors and had the same problem. Anybody does know what happen?
GPIO INPUT ONLY
Re: GPIO INPUT ONLY
Which pins did you use? Could you post a snippet of your code?
___________________________________________________________________________________________________________________________
Tell me if you knows how to use the Programmer module of Windows Calc and I'm gonna say who you are.
Rodrigofraga
Re: GPIO INPUT ONLY
I was reading about sensors and discover that dht22 needs a normal GPIO ( input and output) because this sensor has a pritocol to comunicate with esp32.
Users browsing this forum: Applebot, Perplexity-User and 4 guests
