Problem with flashing ESP32
mosheb
Postby mosheb » Tue Aug 21, 2018 2:27 pm
I'm new in this ESP32 area, and I do not know if I'm in the right place
In addition, I apologize in advance for my English, I do Google translation.
About a month ago, I bought 2 ESP32 boards.
One like that, like the next link.
"ESP-32S ESP32 NodeMCU Development Board 2.4GHz WIFI+Bluetooth Dual Mode"
https://www.ebay.com/itm/ESP-32S-ESP32- ... 3f7b988bd8
And one like that.
"ESP32 ESP-32S NodeMCU Development Board 2.4GHz WiFi+Bluetooth Dual Mode"
https://www.ebay.com/itm/ESP32-ESP-32S- ... 3f8de0d7c9
(Yesss, the same name, but different board, HAHAHA)
And I have a problem with both of them.
With the First one, after I burn a program in IDE Arduino, the WIFI does not respond.
And in the Serial Monitor, data is constantly being run continuously.
With the second board,
Unable to burn program, even though I press the BOOT button.
And I get an error message like this.
"A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header"
How can I check, in any case, where the problem is?
Should I, do a manufacturer boot?
If so, how to do this?
I prefer to work with Arduino IDE, I'd be very happy if you can get help with Arduino IDE.
Only if not possible, I'd be happy for help with any possibility.
Thanks.
Re: Problem with flashing ESP32
Postby Sprite » Wed Aug 22, 2018 1:35 am
For the first board: Are you sure your power supply is powerful enough? If you're using USB, make sure that you're using good-quality cables that aren't too long, and with no (unpowered) hubs in between. If you want to be sure, power the board from a lab PSU.
dmdamen
Postby dmdamen » Wed Aug 22, 2018 6:22 am
The second might be due to wrong baud rate setting. You could try different settings.
mosheb
Postby mosheb » Wed Aug 22, 2018 1:18 pm
First of all, thank you both for your comments.
Regarding the first board,
Thanks for the solution, I switched cable, and plugged in external power, and it works.
I just have to go into the router every time to see which IP address the board has received.
But the main thing is that it works, and if there is a solution to see in the Serial Monitor what is running, it will be good.
As for the second board.
The solution of lowering the baud rate gave some progress, but still getting errors.
I attach the explanation of the error as obtained from the Verbose state in the IDE.
Code : GetChipID.ino
Arduino: 1.8.5 (Windows 10), Board: "DOIT ESP32 DEVKIT V1, 80MHz, 115200, None"
C:\Program Files (x86)\Arduino-185\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino-185\hardware -hardware C:\Users\Moshe\AppData\Local\Arduino15\packages -hardware C:\Users\Moshe\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino-185\tools-builder -tools C:\Program Files (x86)\Arduino-185\hardware\tools\avr -tools C:\Users\Moshe\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino-185\libraries -libraries C:\Users\Moshe\Documents\Arduino\libraries -fqbn=espressif:esp32:esp32doit-devkit-v1:FlashFreq=80,UploadSpeed=115200,DebugLevel=none -ide-version=10805 -build-path C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182 -warnings=none -build-cache C:\Users\Moshe\AppData\Local\Temp\arduino_cache_759870 -prefs=build.warn_data_percentage=75 -verbose C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32\libraries\ESP32\examples\ChipID\GetChipID\GetChipID.ino
C:\Program Files (x86)\Arduino-185\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino-185\hardware -hardware C:\Users\Moshe\AppData\Local\Arduino15\packages -hardware C:\Users\Moshe\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino-185\tools-builder -tools C:\Program Files (x86)\Arduino-185\hardware\tools\avr -tools C:\Users\Moshe\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino-185\libraries -libraries C:\Users\Moshe\Documents\Arduino\libraries -fqbn=espressif:esp32:esp32doit-devkit-v1:FlashFreq=80,UploadSpeed=115200,DebugLevel=none -ide-version=10805 -build-path C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182 -warnings=none -build-cache C:\Users\Moshe\AppData\Local\Temp\arduino_cache_759870 -prefs=build.warn_data_percentage=75 -verbose C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32\libraries\ESP32\examples\ChipID\GetChipID\GetChipID.ino
Using board 'esp32doit-devkit-v1' from platform in folder: C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32
Using core 'esp32' from platform in folder: C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32
Detecting libraries used...
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DHAVE_CONFIG_H "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/config" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bluedroid" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bluedroid/api" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/app_trace" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/app_update" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bootloader_support" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bt" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/driver" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/esp32" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/esp_adc_cal" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/esp_http_client" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/esp-tls" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/ethernet" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/fatfs" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/freertos" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/heap" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/jsmn" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/log" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/mdns" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/mbedtls" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/mbedtls_port" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/newlib" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/nvs_flash" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/openssl" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/spi_flash" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/sdmmc" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/smartconfig_ack" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/spiffs" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/tcpip_adapter" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/ulp" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/vfs" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/wear_levelling" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/coap" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/console" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/expat" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/json" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/lwip" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/newlib" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/nghttp" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/soc" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/wpa_supplicant" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti  -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10805 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="doitESP32devkitV1"  -DESP32 -DCORE_DEBUG_LEVEL=0  "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32\cores\esp32" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32\variants\doitESP32devkitV1" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\sketch\GetChipID.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DHAVE_CONFIG_H "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/config" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bluedroid" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bluedroid/api" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/app_trace" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/app_update" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bootloader_support" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bt" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/driver" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/esp32" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/esp_adc_cal" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/esp_http_client" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/esp-tls" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/ethernet" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/fatfs" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/freertos" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/heap" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/jsmn" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/log" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/mdns" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/mbedtls" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/mbedtls_port" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/newlib" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/nvs_flash" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/openssl" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/spi_flash" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/sdmmc" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/smartconfig_ack" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/spiffs" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/tcpip_adapter" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/ulp" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/vfs" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/wear_levelling" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/coap" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/console" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/expat" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/json" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/lwip" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/newlib" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/nghttp" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/soc" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/wpa_supplicant" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti  -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10805 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="doitESP32devkitV1"  -DESP32 -DCORE_DEBUG_LEVEL=0  "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32\cores\esp32" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32\variants\doitESP32devkitV1" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\sketch\GetChipID.ino.cpp" -o "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino-185\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DHAVE_CONFIG_H "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/config" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bluedroid" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bluedroid/api" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/app_trace" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/app_update" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bootloader_support" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bt" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/driver" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/esp32" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/esp_adc_cal" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/esp_http_client" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/esp-tls" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/ethernet" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/fatfs" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/freertos" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/heap" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/jsmn" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/log" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/mdns" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/mbedtls" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/mbedtls_port" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/newlib" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/nvs_flash" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/openssl" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/spi_flash" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/sdmmc" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/smartconfig_ack" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/spiffs" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/tcpip_adapter" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/ulp" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/vfs" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/wear_levelling" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/coap" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/console" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/expat" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/json" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/lwip" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/newlib" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/nghttp" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/soc" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/wpa_supplicant" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10805 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="doitESP32devkitV1"  -DESP32 -DCORE_DEBUG_LEVEL=0  "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32\cores\esp32" "-IC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32\variants\doitESP32devkitV1" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\sketch\GetChipID.ino.cpp" -o "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\sketch\GetChipID.ino.cpp.o"
Compiling libraries...
Compiling core...
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-adc.c.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-bt.c.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-dac.c.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-gpio.c.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-i2c.c.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-ledc.c.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-matrix.c.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-misc.c.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-psram.c.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-sigmadelta.c.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-spi.c.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-time.c.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-timer.c.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-touch.c.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-uart.c.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\stdlib_noniso.c.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\wiring_pulse.c.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\wiring_shift.c.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\libb64\cdecode.c.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\libb64\cencode.c.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\Esp.cpp.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\HardwareSerial.cpp.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\IPAddress.cpp.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\IPv6Address.cpp.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\MD5Builder.cpp.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\Print.cpp.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\Stream.cpp.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\StreamString.cpp.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\WMath.cpp.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\WString.cpp.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\base64.cpp.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\cbuf.cpp.o
Using previously compiled file: C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\main.cpp.o
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-adc.c.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-bt.c.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-dac.c.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-gpio.c.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-i2c.c.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-ledc.c.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-matrix.c.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-misc.c.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-psram.c.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-sigmadelta.c.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-spi.c.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-time.c.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-timer.c.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-touch.c.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\esp32-hal-uart.c.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\stdlib_noniso.c.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\wiring_pulse.c.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\wiring_shift.c.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\libb64\cdecode.c.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\libb64\cencode.c.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\Esp.cpp.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\HardwareSerial.cpp.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\IPAddress.cpp.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\IPv6Address.cpp.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\MD5Builder.cpp.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\Print.cpp.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\Stream.cpp.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\StreamString.cpp.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\WMath.cpp.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\WString.cpp.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\base64.cpp.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\cbuf.cpp.o"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\core\main.cpp.o"
Archiving built core (caching) in: C:\Users\Moshe\AppData\Local\Temp\arduino_cache_759870\core\core_espressif_esp32_esp32doit-devkit-v1_FlashFreq_80,UploadSpeed_115200,DebugLevel_none_7ebd712ce3ea409c4f8d33f286ffce3d.a
Linking everything together...
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc" -nostdlib "-LC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/lib" "-LC:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/sdk/ld" -T esp32_out.ld -T esp32.common.ld -T esp32.rom.ld -T esp32.peripherals.ld -T esp32.rom.spiram_incompatible_fns.ld -u ld_include_panic_highint_hdl -u call_user_start_cpu0 -Wl,--gc-sections -Wl,-static -Wl,--undefined=uxTopUsedPriority  -u __cxa_guard_dummy -u __cxx_fatal_exception  -Wl,--start-group "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182\sketch\GetChipID.ino.cpp.o" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/arduino.ar" -lgcc -lopenssl -lbtdm_app -lfatfs -lwps -lcoexist -lwear_levelling -lesp_http_client -lhal -lnewlib -ldriver -lbootloader_support -lpp -lmesh -lsmartconfig -ljsmn -lwpa -lethernet -lphy -lapp_trace -lconsole -lulp -lwpa_supplicant -lfreertos -lbt -lmicro-ecc -lcxx -lxtensa-debug-module -lmdns -lvfs -lsoc -lcore -lsdmmc -lcoap -ltcpip_adapter -lc_nano -lesp-tls -lrtc -lspi_flash -lwpa2 -lesp32 -lapp_update -lnghttp -lspiffs -lespnow -lnvs_flash -lesp_adc_cal -llog -lsmartconfig_ack -lexpat -lm -lc -lheap -lmbedtls -llwip -lnet80211 -lpthread -ljson  -lstdc++ -Wl,--end-group -Wl,-EL -o "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/GetChipID.ino.elf"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/gen_esp32part.exe" -q "C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/partitions/default.csv" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/GetChipID.ino.partitions.bin"
"C:\Users\Moshe\Documents\Arduino\hardware\espressif\esp32/tools/esptool/esptool.exe" --chip esp32 elf2image --flash_mode "dio" --flash_freq "80m" --flash_size "4MB" -o "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/GetChipID.ino.bin" "C:\Users\Moshe\AppData\Local\Temp\arduino_build_945182/GetChipID.ino.elf"
esptool.py v2.3.1
Sketch uses 178836 bytes (13%) of program storage space. Maximum is 1310720 bytes.
Global variables use 13904 bytes (4%) of dynamic memory, leaving 313776 bytes for local variables. Maximum is 327680 bytes.
esptool.py v2.3.1
Connecting........_____....._____....._____....._____....._____....._____....._Traceback (most recent call last):
  File "esptool.py", line 2637, in <module>
  File "esptool.py", line 2630, in _main
  File "esptool.py", line 2356, in main
  File "esptool.py", line 410, in connect
  File "esptool.py", line 387, in _connect_attempt
  File "esptool.py", line 341, in sync
  File "esptool.py", line 277, in command
  File "site-packages\serial\serialutil.py", line 352, in timeout
  File "site-packages\serial\serialwin32.py", line 222, in _reconfigure_port
serial.serialutil.SerialException: Cannot configure port, something went wrong. Original message: WindowsError(2, 'The system cannot find the file specified.')
Failed to execute script esptool
the selected serial port Failed to execute script esptool
 does not exist or your board is not connected
_
It seems there is a problem with the board, but do not understand where the problem is.
Correct me if I'm wrong, and how to solve the problem.
Thanks again for everything.
boarchuz
Postby boarchuz » Thu Aug 23, 2018 12:03 pm
Are you changing the port? Windows will probably assign it a different port, even if you plug it into the exact same USB port with the exact same cable that you just pulled out of the first board.
mosheb
Postby mosheb » Fri Aug 24, 2018 1:21 pm
I know, always when I reconnect, I check what port the board received.
dmdamen
Postby dmdamen » Thu Aug 30, 2018 7:35 am
Can you connect to the board using another tool like putty? Check this: https://docs.espressif.com/projects/esp ... ction.html
I also encountered boars with a different usb to serial controller. I needed to install these drivers for that: https://sparks.gogo.co.nz/ch340.html
Hope it helps.
mosheb
Postby mosheb » Thu Aug 30, 2018 3:09 pm
First of all Thanks.
I do not know how to check with Putty, I'd be happy if you could guide me how to check.
I installed the software, how do I check? What to check exactly?
With the driver there's no problem, because in Device Manager I see the connection to COM-3
Thanks.
mosheb
Postby mosheb » Thu Aug 30, 2018 4:44 pm
OK,
I found how to check with Potty.
And when I connected the board I got the result attached.
I do not know what that means.
Is it possible to understand why I can not get the BOOT click and burn?
rst:0x1 (POWERON_R.ets Jun  8 2016 00:22:57
configsip: 0, SPIWP:0x00
mode:DIO, clock div:2
load:0x3fff0008,len:8
load:0x3fff0010,len:3480
load:0x40078000,len:7804
ho 0 tail 12 room 4
load:0x40080000,len:252
entry 0x40080034
.[0;32mI (45) boot: ESP-IDF v2.0-3-gbef9896 2nd stage bootloader.[0m
.[0;32mI (46) boot: compile time 05:59:45.[0m
.[0;32mI (46) boot: Enabling RNG early entropy source....[0m
.[0;32mI (64) boot: SPI Speed      : 40MHz.[0m
.[0;32mI (77) boot: SPI Mode       : DIO.[0m
.[0;32mI (89) boot: SPI Flash Size : 4MB.[0m
.[0;32mI (102) boot: Partition Table:.[0m
.[0;32mI (113) boot: ## Label            Usage          Type ST Offset   Length.[0m
.[0;32mI (136) boot:  0 phy_init         RF data          01 01 0000f000 00001000.[0m
.[0;32mI (159) boot:  1 otadata          OTA data         01 00 00010000 00002000.[0m
.[0;32mI (182) boot:  2 nvs              WiFi data        01 02 00012000 0000e000.[0m
.[0;32mI (206) boot:  3 at_customize     unknown          40 00 00020000 000e0000.[0m
.[0;32mI (229) boot:  4 ota_0            OTA app          00 10 00100000 00180000.[0m
.[0;32mI (252) boot:  5 ota_1            OTA app          00 11 00280000 00180000.[0m
.[0;32mI (275) boot: End of partition table.[0m
.[0;32mI (289) boot: Disabling RNG early entropy source....[0m
.[0;32mI (305) boot: Loading app partition at offset 00100000.[0m
.[0;32mI (1481) boot: segment 0: paddr=0x00100018 vaddr=0x00000000 size=0x0ffe8 ( 65512) .[0m
.[0;32mI (1482) boot: segment 1: paddr=0x00110008 vaddr=0x3f400010 size=0x1c5f0 (116208) map.[0m
.[0;32mI (1498) boot: segment 2: paddr=0x0012c600 vaddr=0x3ffb0000 size=0x0215c (  8540) load.[0m
.[0;32mI (1528) boot: segment 3: paddr=0x0012e764 vaddr=0x40080000 size=0x00400 (  1024) load.[0m
.[0;32mI (1552) boot: segment 4: paddr=0x0012eb6c vaddr=0x40080400 size=0x1b028 (110632) load.[0m
.[0;32mI (1630) boot: segment 5: paddr=0x00149b9c vaddr=0x400c0000 size=0x00034 (    52) load.[0m
.[0;32mI (1631) boot: segment 6: paddr=0x00149bd8 vaddr=0x00000000 size=0x06430 ( 25648) .[0m
.[0;32mI (1648) boot: segment 7: paddr=0x00150010 vaddr=0x400d0018 size=0x7a56c (501100) map.[0m
.[0;32mI (1675) heap_alloc_caps: Initializing. RAM available for dynamic allocation:.[0m
.[0;32mI (1698) heap_alloc_caps: At 3FFBA6B8 len 00025948 (150 KiB): DRAM.[0m
.[0;32mI (1719) heap_alloc_caps: At 3FFE8000 len 00018000 (96 KiB): D/IRAM.[0m
.[0;32mI (1740) heap_alloc_caps: At 4009B428 len 00004BD8 (18 KiB): IRAM.[0m
.[0;32mI (1761) cpu_start: Pro cpu up..[0m
.[0;32mI (1773) cpu_start: Single core mode.[0m
.[0;32mI (1786) cpu_start: Pro cpu start user code.[0m
.[0;32mI (1846) cpu_start: Starting scheduler on PRO CPU..[0m
.[0;32mI (1909) uart: queue free spaces: 10.[0m
Bin version:0.10.0I (1911) wifi: wifi firmware version: c604573
I (1911) wifi: config NVS flash: enabled
I (1914) wifi: config nano formating: disabled
I (1922) wifi: Init dynamic tx buffer num: 32
I (1923) wifi: wifi driver task: 3ffc4eac, prio:23, stack:3584
I (1928) wifi: Init static rx buffer num: 10
I (1932) wifi: Init dynamic rx buffer num: 0
I (1936) wifi: Init rx ampdu len mblock:7
I (1939) wifi: Init lldesc rx ampdu entry mblock:4
I (1944) wifi: wifi power manager task: 0x3ffca254 prio: 21 stack: 2560
I (1950) wifi: wifi timer task: 3ffcb2d4, prio:22, stack:3584
.[0;31mE (1956) phy_init: PHY data partition validated.[0m
.[0;32mI (1975) phy: phy_version: 329, Feb 22 2017, 15:58:07, 0, 0.[0m
I (1975) wifi: mode : softAP (b4:e6:2d:c3:3c:4a)
I (1978) wifi: mode : sta (b4:e6:2d:c3:3c:49) + softAP (b4:e6:2d:c3:3c:4a)
I (1982) wifi: mode : softAP (b4:e6:2d:c3:3c:4a)
Thanks.
dmdamen
Postby dmdamen » Thu Aug 30, 2018 7:55 pm
I'm sorry this is beyond my knowledge level.
Users browsing this forum: Baidu [Spider], Semrush [Bot] and 2 guests
